22nd May 2010, 17:06 | #7721 | Link |
Firstly thank you for this great app, been using it for ages and its fantastic.
Can somebody please tell me why this version just will not work for me. If i use the inbuilt profiles its fine but im after great avchd quality. can you take a look at my 1080p profile and see why its not working with this version, but works with 1.15.0 --level 4.1 --aud --nal-hrd --vbv-bufsize 25000 --vbv-maxrate 25000 --rc-lookahead 50 --aq-mode 1 --aq-strength 0.8 --merange 64 --psy-rd 0.80:0.00 --no-dct-decimate --no-fast-pskip --filter -2,-2 --keyint 240 --min-keyint 24 --ref 3 --bframes 5 --b-pyramid strict --b-adapt 2 --direct auto --subme 9 --trellis 2 --partitions p8x8,b8x8,i4x4,i8x8 --me esa there must be something wrong in my profile....help and thank you |
22nd May 2010, 17:46 | #7723 | Link | |
Now personally I dont know much about either other than the spec for main profile says you should support both CAVLC and CABAC however Apple is known for not playing by the rules. On separate note do you think you could add 960x540 as a resize option for those of us that have aTV's and is only way to do hi res video at 30fps? |
22nd May 2010, 18:28 | #7724 | Link | |
22nd May 2010, 20:04 | #7727 | Link |
I dont care so should you
OK why is it in mkv if you ripped it from a disk. It should be m2ts.
My Installer's || |
22nd May 2010, 20:54 | #7728 | Link |
MakeMKV will rip directly to MKV.
Makes enforcing rule 6 problematic. That's why I always give people the chance to shoot themselves in the foot. One giveaway is the use of a standard torrent filename, which is not the case here. Looks legit. |
22nd May 2010, 22:06 | #7729 | Link |
@mmmmdonut and Ajax_Undone
here is new profile for ATV http://www.mediafire.com/file/mry0bygttjy/[MAIN 3.1] HD . AppleTV . iPAD.txt Also check if your ATV plays 720p@30fps.
22nd May 2010, 22:43 | #7730 | Link | |
Thx Ajax
your brilliant !! thx |
23rd May 2010, 03:09 | #7732 | Link |
@Atak - I did a test of Elephants Dream (http://orange.blender.org/download) which was a 1080p avi file.
Using the profile you uploaded, I noticed weightp was enabled which resulted in serious blockiness. With CABAC turned on the aTV seemed to struggle playing the video back. I did a second encode using same profile and turning off CABAC and Weightp and the video playback was much smoother and there was no blockiness. I created two 50MB sample files but am having difficulties getting them uploaded to mediafire. If I can get them uploaded later on I will post the links. http://www.mediafire.com/file/uwniwj...AD_profile.mp4 http://www.mediafire.com/file/nykfzm...eightp_off.mp4 As for 720p@30fps. Still a no go. Video doesnt show up as available for playback. Below is mediainfo from my two test encodes. Code:
General Complete name : D:\output\Elephants_Dream_HD.mp4 Format : MPEG-4 Format profile : Apple TV Codec ID : M4VH File size : 321 MiB Duration : 10mn 53s Overall bit rate : 4 114 Kbps Encoded date : UTC 2010-05-22 00:35:40 Tagged date : UTC 2010-05-22 00:35:40 Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : Main@L3.1 Format settings, CABAC : Yes Format settings, ReFrames : 3 frames Codec ID : avc1 Codec ID/Info : Advanced Video Coding Duration : 10mn 53s Bit rate mode : Variable Bit rate : 4 015 Kbps Maximum bit rate : 18.2 Mbps Width : 1 280 pixels Height : 720 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 24.000 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.182 Stream size : 313 MiB (98%) Title : Elephants_Dream_HD Writing library : x264 core 89 r1471M 1144615 Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x1:0x131 / me=umh / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=0 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=6 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=3 / b_pyramid=0 / b_adapt=1 / b_bias=0 / direct=1 / wpredb=1 / wpredp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=crf / mbtree=1 / crf=18.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / vbv_maxrate=14000 / vbv_bufsize=14000 / ip_ratio=1.40 / aq=1:1.00 / pulldown=0 / nal_hrd=vbr Encoded date : UTC 2010-05-22 00:35:40 General Complete name : D:\output\Elephants_Dream_HD_NoCabac_Weightp_off.mp4 Format : MPEG-4 Format profile : Apple TV Codec ID : M4VH File size : 353 MiB Duration : 10mn 53s Overall bit rate : 4 523 Kbps Encoded date : UTC 2010-05-22 01:45:21 Tagged date : UTC 2010-05-22 01:45:21 Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : Main@L3.1 Format settings, CABAC : No Format settings, ReFrames : 3 frames Codec ID : avc1 Codec ID/Info : Advanced Video Coding Duration : 10mn 53s Bit rate mode : Variable Bit rate : 4 424 Kbps Maximum bit rate : 18.0 Mbps Width : 1 280 pixels Height : 720 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 24.000 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.200 Stream size : 345 MiB (98%) Title : Elephants_Dream_HD_NoCabac_Weightp_off Writing library : x264 core 89 r1471M 1144615 Encoding settings : cabac=0 / ref=3 / deblock=1:0:0 / analyse=0x1:0x131 / me=umh / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=0 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=6 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=3 / b_pyramid=0 / b_adapt=1 / b_bias=0 / direct=1 / wpredb=1 / wpredp=0 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=crf / mbtree=1 / crf=18.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / vbv_maxrate=14000 / vbv_bufsize=14000 / ip_ratio=1.40 / aq=1:1.00 / pulldown=0 / nal_hrd=vbr Encoded date : UTC 2010-05-22 01:45:21 Last edited by mmmmdonut; 23rd May 2010 at 03:22. Reason: Add links |
23rd May 2010, 09:11 | #7733 | Link |
I've been using your app for some time now and am very happy with it. Great job.
I know you probably get a ton of requests but I have one I'd like to get on the record. I prefer the mkv container for my encodes but also want the flexibility to use an external Dolby/DTS decoder when watching the videos. MKV can now handle Dolby True HD and DTS-MS audio streams. Would you please allow for that in a future version? Correction, DTS-MA is what I meant to say above and that is actually not supported in mkv yet. Only Dolby True-HD. Hopefully the DTS-MA part will follow soon as well. Either way I'm actually fairly happy with the flac option. Just wanted to get my 2 cents in. Last edited by zumaval; 1st June 2010 at 06:54. |
23rd May 2010, 09:16 | #7734 | Link |
I have successfully encoded most of my m2ts files to mkv but the remaining ones always end up with the following AviSynth error message:
DirectShowSource: couldn't open file C:\Users\ADMINI~1\AppData\Local\Temp\RipBot264temp\job1\video.mkv: The system cannot find the file specified. (C:\Users\ADMINI~1\AppData\Local\Temp\RipBot264temp\job1\getinfo.avs, line 2) Please help. |
23rd May 2010, 16:25 | #7737 | Link |
We All Float Down Here
avs2avi.exe has stopped working
ripbot once it gets to a certain point in gathering data i get the error. any help with this would be greatly appreciated.
avs2avi.exe has stopped working Problem signature: Problem Event Name: APPCRASH Application Name: avs2avi.exe Application Version: 0.0.0.0 Application Timestamp: 40eb0522 Fault Module Name: DivXDec.ax_unloaded Fault Module Version: 0.0.0.0 Fault Module Timestamp: 4bb651da Exception Code: c0000005 Exception Offset: 04fd9292 OS Version: 6.1.7600.2.0.0.256.1 Locale ID: 1033 Additional Information 1: 0a9e Additional Information 2: 0a9e372d3b4ad19135b953a78882e789 Additional Information 3: 0a9e Additional Information 4: 0a9e372d3b4ad19135b953a78882e789 Windows 7 Ultimate Asus Rampage Formula Asus Nvidia 9500 - 512mb |
23rd May 2010, 17:27 | #7738 | Link | |
23rd May 2010, 18:58 | #7739 | Link | |
DirectShowSource : Timeout waiting for graph to start. (C:\Temp\RipBot264temp\job1\getinfo.avs, line 2) |
23rd May 2010, 19:01 | #7740 | Link | |
Same results as above. The old aTV profile has --no-cabac --weightp 0 It always seemed to work fine for me. Then again the vbv buf size and max have changed to 14000 each and so has the level from 3.0 to 3.1. I did as mmmmdonut did and got the same results. Only I used independents day. I don't think ATV was meant to play 30fps @ 720p.
My Installer's || |
