Old 28th April 2006, 01:51   #161  |  Link
danpos
BDVD Team
danpos's Avatar
Originally Posted by Wilbert
I modified the YV12 faq a bit, and moved it to avisynth.org. I hope some of you can read it through and tell me whether I need to change, add or remove anything. Thanks!
I just was reading the topics from this great community (which I always do everyday ) and saw this post and so I went there take an eye and I've to say that it's very pleasant to read out.
Thanks for your time to do our life easier.
Cheers,
danpos is offline   Reply With Quote
Old 28th March 2007, 04:35   #162  |  Link
GrofLuigi
Member of a Library
Originally Posted by Wilbert View Post
The YV12 FAQ is moved to avisynth.org:
http://www.avisynth.org/mediawiki/wiki/YV12_FAQ
I just found it's moved now http://avisynth.org/mediawiki/YV12_FAQ
GL
GrofLuigi is offline   Reply With Quote
Old 28th March 2007, 22:05   #163  |  Link
Wilbert
Thanks for mentioning it. I corrected the link.
Old 9th August 2012, 22:13   #164  |  Link
frustum
The SDK has functions like IsYUY2(), IsYV12(), IsRGB(), etc. At the script level, there is the Info() function, but it simply overlays the video image, and the information isn't easily available the script.
Is there a means whereby a script can determine the format of a video stream it has been handed? I'm hoping for something akin to IsYUY2() for use as a ConditionalFilter() selector.
Why do I want it? Because some plugins don't handle YUY2 but do handle YV12, or the two formats need different arguments. For instance, the RemoveDirt() script can process YV12 sources as-is, but YUY2 sources need to be converted to/from planar YUY2 format before/after RemoveDirt().
frustum is offline   Reply With Quote
Old 9th August 2012, 22:45   #165  |  Link
Have you read the documentation? The functions you ask for are available.
Old 10th August 2012, 01:12   #166  |  Link
frustum
Neuron2:
I looked at the places listed below, and then some. I know, judging by name, some of these don't make sense to look for IsYUV(), say, but since I didn't find it, I kept looking. I did google search on things like "avisynth isyuv" "avisynth determine video format", etc. No luck. I probably spent an hour browsing around and searching without finding it before coming here.
http://avisynth.org/mediawiki/Internal_functions/Boolean_functions
http://avisynth.org/mediawiki/Internal_functions/Runtime_functions
http://avisynth.org/mediawiki/Internal_functions/Script_functions
http://avisynth.org/mediawiki/Internal_functions/String_functions
In fact, I searched all pages under:
I looked under:
http://avisynth.org/mediawiki/Category:Internal_filters
http://avisynth.org/mediawiki/Category:External_filters
http://avisynth.org/mediawiki/YUY2
I have now found it here:
http://avisynth.org/mediawiki/Clip_properties
I just tried searching on "avisynth isyuy2" (without quotes), and google helpfully changed it to find "avisynth yuy2" instead. That must have happened to me before, but I didn't notice it. When I force it to search on isyuy2, then the last link above finally showed up.
Old 10th August 2012, 01:21   #167  |  Link
It's right there in the documentation that gets installed with Avisynth. For example, on my system:
E:\AviSynth 2.5\Docs\english\index.htm
Anyway, I'm glad you've got it sorted out.
Old 10th August 2012, 16:15   #168  |  Link
jmac698
I often have difficulties finding documentation. Ideally there would be an index to all keywords. Try to guess where to find LoadPlugin for example - what entry under table of contents would have it? I was looking for the other versions, load std call or whatever.
jmac698 is offline   Reply With Quote
Old 10th August 2012, 16:42   #169  |  Link
It was so hard:
Open index.html
Look at left menu
click on Getting Started/Plugins
I had to rest for hours after suffering through that.
Old 11th August 2012, 14:04   #170  |  Link
Wilbert
You know the mediawiki has a search bar right (under the 'in other languages' on the left hand side)?
Old 11th August 2012, 14:46   #171  |  Link
Unfortunately using search for "loadplugin" leads to this less-than-useful page:
http://avisynth.org/mediawiki/LoadPlugin
avisynth, faq
