31st July 2008, 19:40 | #1841 | Link | |
Original was 390 MB, created m2ts has been 410 Mb ; means ten percent increased. So it might be told that re-encoding to a 3.5 GB m2ts file will be safe enough for burning a DVD. (I was comparing the lenghts of m2ts file and created BD Folder.) Last edited by rica; 31st July 2008 at 19:42. |
31st July 2008, 20:12 | #1842 | Link | |
31st July 2008, 20:19 | #1843 | Link |
Location: The Great North (the better half of North America)
MKV-->m2ts/Blu-ray
The size increase has to do with the size of the source file, the larger you get the more room you'll need.
For a DVD9, the header space for m2ts/blu-ray muxing is 570mb. For a DVD5 it is 313mb. For a BD25 you're looking at just over 1GB. |
1st August 2008, 11:57 | #1845 | Link |
use 'r'
bug report
while removing pulldown from MPEG2 video stream (30fps) it must be also flagged as progressive. Else with created blu-ray output we got blu-ray with incompatible video stream (progressive 24 fps not marked as progressive) and stuttering playback on PS3 (and possibly all others stand alone br players).
1st August 2008, 14:10 | #1846 | Link | |
Taget size ---------- x 100 == "max size" before muxing into BR/AVCHD 110 Then before encoding do: Max size -/- (size audio + size subs) = max size for video. Give that number to the bitratecalculator (in Megui). |
2nd August 2008, 05:11 | #1850 | Link |
My best format to fit on a DVD is to get the audio down at least 300mb. Usually if I have a 640kb 6 channel I will convert 224kb 6 channel. Then TSmuxeR converts that close to 4.37gb. The video I never touch.
That's if the MKV you have is 4.37gb to begin with. Last edited by VintageGuy; 2nd August 2008 at 05:16. |
2nd August 2008, 15:57 | #1851 | Link | |
2nd August 2008, 16:48 | #1852 | Link | |
On the other hand, if all you are doing is converting (mkv-->m2ts) and streaming/copying, then yes I agree, the header will be proportional to the source file and it's streams. |
4th August 2008, 20:00 | #1854 | Link | |
I'm not trying to sound rude or cynical, but what exactly is a "header"... I thought knew what it was? |
5th August 2008, 06:58 | #1856 | Link |
For a 8150 MB target (2-layer DVD), I subtract the sizes of the "naked" AC3 and SUP tracks from 8150, and use the result to calculate the "ideal" bitrate for the .264 track. Then I multiply the "ideal" value by 0.95 and that's what I use for x264 in MeGUI.
So basically I assume there's a 5% overhead for one .264 track, one AC3 track, and one SUP track, muxed/authored with tsMuxer on a 8150 MB disk. Seems to work OK so far. |
7th August 2008, 05:53 | #1858 | Link | |
With TrueHD discs my Panasonic just refuses to play them, when remuxed with TsmuxeR, but if I remux them again with TsRemux and then replace the original m2ts stream from TsmuxeR with the new one from Tsremux and then burn it all is ok. The "funny" thing is that the Tsremux output, when burned to a BD-25 wont play on the Panasonic either, strange.... But if there is any one out there with a Panasonic DMP-BD50, I can confirm that this work around works for it |
8th August 2008, 10:04 | #1859 | Link | |
9th August 2008, 02:50 | #1860 | Link | |
tsmuxer |
