17th August 2017, 18:27 | #5541 | Link | |
This is my first AMD system in 15+ years and I can say unequivocally that I am very happy with it. |
18th August 2017, 15:15 | #5542 | Link |
x265 2.5+11-d58761d8db4a
supports some new SMPTE-ST/RP/EG colorimetry options and a new split RD skip command* (documented only in full help): Code:
--[no-]splitrd-skip Enable skipping split RD analysis when sum of split CU rdCost larger than none split CU rdCost for Intra CU. Default disabled --colorprim <string> Specify color primaries from undef, bt709, bt470m, bt470bg, smpte170m, smpte240m, film, bt2020, smpte-st-428, smpte-rp-431, smpte-eg-432. Default undef --colormatrix <string> Specify color matrix setting from undef, bt709, fcc, bt470bg, smpte170m, smpte240m, GBR, YCgCo, bt2020nc, bt2020c, smpte-st-2085, chroma-nc, chroma-c, ictcp. Default undef |
19th August 2017, 03:55 | #5543 | Link |
Yes, the splitRD-skip looks interesting, I wouldn't be surprised that if in the future it isn't enabled by default. I guess that comes down to user reports, or maybe they're waiting on the possibility of it being extended to inter-CU?
20th August 2017, 03:12 | #5544 | Link | |
20th August 2017, 05:52 | #5545 | Link | |
What a smart ass. What a dump ass What an asshole. Port 0 and 1 can dispatch SIMD integer and FMA for floating point, but not all hardware capable of SIMD integer can do SIMD floating point too. For example port 5 can do SIMD integer but not FMA for floating point in Haswell/Broadwell/Skylake/Kabylake architecture. Integer FMA is something very new to Intel's CPU architecture and part of AVX-512 instruction set only. It's called AVX512-IFMA and has 52 bit precision. Haswell/Broadwell/Skylake/Kabylake do not support AVX-512 and don't support integer FMA of course. Skylake-X (Skylake-SP core) added an FMA 512 bit unit in Port 5 (10 core and above) but for floating point only, as it supports a limited part of the huge AVX-512 family of instructions set variants, but not AVX512-IFMA. There are 12 levels of AVX-512 actually. Cannonlake will be the first mainstream CPU of Intel to support integer FMA. So, again. What a smart ass, a dump ass and an asshole. You should be banned from doom9 for ever.
Win 10 x64 (19042.572) - Core i5-2400 - Radeon RX 470 (20.10.1) HEVC decoding benchmarks H.264 DXVA Benchmarks for all |
21st August 2017, 06:00 | #5546 | Link | |
21st August 2017, 15:29 | #5548 | Link |
x265 v2.5+12-fcd9154fa4e2 (GCC 7.2.0, 32 & 64-bit 8/10/12bit Multilib Windows Binaries)
x265 [info]: HEVC encoder version 2.5+12-fcd9154fa4e2 x265 [info]: build info [Windows][GCC 7.2.0][32 bit] 8bit+10bit+12bit x265 [info]: using cpu capabilities: MMX2 SSE2Fast LZCNT SSSE3 SSE4.2 AVX FMA3 BMI2 AVX2 Code:
https://bitbucket.org/multicoreware/x265/commits/branch/default |
22nd August 2017, 07:52 | #5549 | Link |
Side note:
The German c't Magazine reports Ryzen Threadripper (1950X) as the generally fastest desktop CPU at the moment (including advantages of the TR4 platform connecting to PCIx SSD's and graphic cards, plus USB 3.1). Not so important for x265, specifically. Back to topic. |
22nd August 2017, 13:26 | #5550 | Link |
GPU Fork - x265 HEVC OpenCL or CUDA Encoder
gcc>=7 , -O2 -fopenacc https://bitbucket.org/vovagubin/x265...r-cuda-encoder |
22nd August 2017, 13:32 | #5551 | Link |
Interesting... I wonder if it is technically still as powerful as x265 (means, if GPGPU algorithms can still be as complex as CPU algorithms), and also if it is allowed to be still named something-with-x265. Just curious...
22nd August 2017, 15:07 | #5552 | Link | |
22nd August 2017, 17:44 | #5553 | Link | |
Hmmm......process that could be offloaded..... Motion search + estimation? All big three gpu have some sort of motion search/estimation code available. Maybe lookahead (didn't work well in x264), but somehow nvidia is able to implement it using CUDA cores in conjunction with its proprietary NVENC. The code ain't available from nvidia....hmmm....but being able to do it fast..... Maybe SAO? Some form of low complexity SAO like what nvidia used in Pascal? Or offloading adaptive quantization calculation like that nvidia did? *Gotta hand it off to Nvidia software engineers.....they are leading.......in GPGPU usage for video acceleration part....with its CUDA.... |
22nd August 2017, 18:12 | #5554 | Link |
or using FEI from intel if it come to HEVC .
I don't know if this could be interesting to mix with x264/X265 from https://github.com/01org/intel-vaapi-driver/issues/228 "The main highlight of FEI is the possibility to split the encoding process into two phases, first is ENC and the second is PAK.ENC is the operation which performs all motion vector calculation and prediction.PAK is doing all transformations and entropy coding. Without having FEI, the whole ENC+PAK is a black box to middleware, but with FEI user can extract the output of ENC and feed PAK with a custom enhanced motion vectors and macroblock prediction modes." |
22nd August 2017, 23:16 | #5556 | Link | |
Posts: n/a
22nd August 2017, 23:26 | #5557 | Link | |
Posts: n/a
GPUs are very good at work that can be highly parallelized, and not good at work that has serial dependencies. Video encoding has many serial dependencies. The block you're encoding right now makes reference to neighboring blocks, or blocks in other frames, all of which must be completely finished encoding before you can efficiently encode the current block. |
23rd August 2017, 06:11 | #5558 | Link |
Posts: n/a
Be sure to vote for x265 in the Streaming Media Reader's Choice poll... http://www.streamingmedia.com/Reader...2017/Vote.aspx
23rd August 2017, 08:56 | #5559 | Link |
I've made 10-bit "true placebo" 2500 kb/s test with Sintel movie (from 8-bit 4K png source).
Command line: Code:
f:\speed\Sintel>ffmpeg -framerate 24 -start_number 00000001 -i %08d.png -pix_fmt yuv420p16 -vf "scale=1920:-4:flags=bicubic+accu rate_rnd+full_chroma_int+full_chroma_inp:param0=-0.5:param1=0.25,setsar=1" -v warning -strict -1 -f yuv4mpegpipe - | x265 -D10 --bitrate 2500 -I480 --psnr --ssim -p9 --no-psy-rd --multi-pass-opt-distortion --rc-lookahead 120 --bframes 12 --ref 6 --subme 7 -F1 --y4m - w1.hevc --pass 1 [yuv4mpegpipe @ 00000000005603a0] Warning: generating non standard YUV stream. Mjpegtools will not work. y4m [info]: 1920x816 fps 24/1 i420p16 sar 1:1 unknown frame count raw [info]: output file: w1.hevc x265 [info]: HEVC encoder version 2.5+11-d58761d8db4a x265 [info]: build info [Windows][MSVC 1911][64 bit] 10bit+8bit x265 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX x265 [warning]: --psnr used with psy on: results will be invalid! x265 [warning]: --tune psnr should be used if attempting to benchmark psnr! x265 [info]: Main 10 profile, Level-4 (Main tier) x265 [info]: Thread pool created using 4 threads x265 [info]: Slices : 1 x265 [info]: frame threads / pool features : 1 / wpp(13 rows) x265 [info]: Coding QT: max CU size, min CU size : 64 / 8 x265 [info]: Residual QT: max TU size, max depth : 32 / 4 inter / 4 intra x265 [info]: ME / range / subpel / merge : star / 92 / 7 / 5 x265 [info]: Keyframe min / max / scenecut / bias: 24 / 480 / 40 / 5.00 x265 [info]: Lookahead / bframes / badapt : 120 / 12 / 2 x265 [info]: b-pyramid / weightp / weightb : 1 / 1 / 1 x265 [info]: References / ref-limit cu / depth : 6 / off / off x265 [info]: AQ: mode / str / qg-size / cu-tree : 1 / 1.0 / 32 / 1 x265 [info]: Rate Control / qCompress : ABR-2500 kbps / 0.60 x265 [info]: tools: rect amp rd=6 rdoq=2 psy-rdoq=1.00 tskip signhide tmvp x265 [info]: tools: b-intra strong-intra-smoothing deblock sao stats-write x265 [info]: frame I: 187, Avg QP:16.78 kb/s: 16314.61 PSNR Mean: Y:51.527 U:54.999 V:54.462 SSIM Mean: 0.994805 (22.844dB ) x265 [info]: frame P: 5475, Avg QP:18.42 kb/s: 6150.87 PSNR Mean: Y:50.783 U:54.985 V:54.451 SSIM Mean: 0.993361 (21.779dB ) x265 [info]: frame B: 15650, Avg QP:23.87 kb/s: 992.31 PSNR Mean: Y:50.160 U:56.112 V:55.537 SSIM Mean: 0.992487 (21.242dB ) x265 [info]: Weighted P-Frames: Y:10.6% UV:7.3% x265 [info]: Weighted B-Frames: Y:8.8% UV:5.7% x265 [info]: consecutive B-frames: 17.7% 9.1% 8.2% 42.3% 6.2% 9.2% 3.2% 2.5% 0.4% 0.2% 0.2% 0.2% 0.6% encoded 21312 frames in 135210.11s (0.16 fps), 2451.98 kb/s, Avg QP:22.41, Global PSNR: 51.632, SSIM Mean Y: 0.9927318 (21.386 d B) f:\speed\Sintel>ffmpeg -framerate 24 -start_number 00000001 -i %08d.png -pix_fmt yuv420p16 -vf "scale=1920:-4:flags=bicubic+accu rate_rnd+full_chroma_int+full_chroma_inp:param0=-0.5:param1=0.25,setsar=1" -v warning -strict -1 -f yuv4mpegpipe - | x265 -D10 --bitrate 2500 -I480 --psnr --ssim -p9 --no-psy-rd --multi-pass-opt-distortion --rc-lookahead 120 --bframes 12 --ref 6 --subme 7 -F1 --y4m - w2.hevc --pass 2 [yuv4mpegpipe @ 00000000004403a0] Warning: generating non standard YUV stream. Mjpegtools will not work. y4m [info]: 1920x816 fps 24/1 i420p16 sar 1:1 unknown frame count raw [info]: output file: w2.hevc x265 [info]: HEVC encoder version 2.5+11-d58761d8db4a x265 [info]: build info [Windows][MSVC 1911][64 bit] 10bit+8bit x265 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX x265 [warning]: --psnr used with psy on: results will be invalid! x265 [warning]: --tune psnr should be used if attempting to benchmark psnr! x265 [info]: Main 10 profile, Level-4 (Main tier) x265 [info]: Thread pool created using 4 threads x265 [info]: Slices : 1 x265 [info]: frame threads / pool features : 1 / wpp(13 rows) x265 [info]: Coding QT: max CU size, min CU size : 64 / 8 x265 [info]: Residual QT: max TU size, max depth : 32 / 4 inter / 4 intra x265 [info]: ME / range / subpel / merge : star / 92 / 7 / 5 x265 [info]: Keyframe min / max / scenecut / bias: 24 / 480 / 40 / 5.00 x265 [info]: Lookahead / bframes / badapt : 120 / 12 / 2 x265 [info]: b-pyramid / weightp / weightb : 1 / 1 / 1 x265 [info]: References / ref-limit cu / depth : 6 / off / off x265 [info]: AQ: mode / str / qg-size / cu-tree : 1 / 1.0 / 32 / 1 x265 [info]: Rate Control / qCompress : ABR-2500 kbps / 0.60 x265 [info]: tools: rect amp rd=6 rdoq=2 psy-rdoq=1.00 tskip signhide tmvp x265 [info]: tools: b-intra strong-intra-smoothing deblock sao stats-read x265 [info]: frame I: 187, Avg QP:15.44 kb/s: 18757.12 PSNR Mean: Y:53.007 U:56.245 V:55.748 SSIM Mean: 0.996481 (24.535dB ) x265 [info]: frame P: 5475, Avg QP:19.54 kb/s: 6299.14 PSNR Mean: Y:50.557 U:55.238 V:54.725 SSIM Mean: 0.994567 (22.650dB ) x265 [info]: frame B: 15650, Avg QP:25.57 kb/s: 977.83 PSNR Mean: Y:49.518 U:56.082 V:55.533 SSIM Mean: 0.993497 (21.869dB ) x265 [info]: Weighted P-Frames: Y:3.3% UV:2.1% x265 [info]: Weighted B-Frames: Y:1.0% UV:0.5% x265 [info]: consecutive B-frames: 17.7% 9.1% 8.2% 42.3% 6.2% 9.2% 3.2% 2.5% 0.4% 0.2% 0.2% 0.2% 0.6% encoded 21312 frames in 124205.99s (0.17 fps), 2500.86 kb/s, Avg QP:23.93, Global PSNR: 51.261, SSIM Mean Y: 0.9937978 (22.075 d B) Result movie -- www.msystem.waw.pl/x265/sintel2500.mkv |
23rd August 2017, 13:58 | #5560 | Link | ||
Testeur de codecs
|---------------------|---------|---------|---------|---------|---------|---------|---------|---------|---------|---------|---------|---------| | CPU | x264 | x265 | LAVC | auto | MMX2 | SSE | SSE2 | SSE3 | SSE4 | AVX | AVX2 | All | |---------------------|---------|---------|---------|---------|---------|---------|---------|---------|---------|---------|---------|---------| | Core i9-7900X | 32.97 | 6.24 | 157 | 4.70 | 1.57 | 1.58 | 2.50 | 2.74 | 4.07 | 3.98 | 4.82 | N/A | |---------------------|---------|---------|---------|---------|---------|---------|---------|---------|---------|---------|---------|---------| | Threadripper 1950X | 37.59 | 6.50 | 136 | 4.65 | 2.02 | 2.00 | 2.95 | 3.10 | 3.89 | 4.10 | 4.26 | N/A | |---------------------|---------|---------|---------|---------|---------|---------|---------|---------|---------|---------|---------|---------| at stock, core i9-7900X will be at 27.97 fps for x264 and 5.29 fps for x265 As I always say, massive instance encoding is real problem for Rysen. Anyway certainely that i9-7960X 16C/32T or i9-7980XE 18C/36T will make really better result than 1950X for x264 and x265 encoding. But it's not the case for i9-7800X 10C/20T even with massive OC at 4.5 Ghz.
Le Sagittaire ... ;-) 1- Ateme AVC or x264 2- VP7 or RV10 only for anime 3- XviD, DivX or WMV9 Last edited by Sagittaire; 23rd August 2017 at 14:23. |
