30th March 2016, 01:21 | #3521 | Link |
this is x264:
http://s12.postimg.org/4r368zrl9/SW_x264.png and this x265: http://s8.postimg.org/sldo3qj51/SW_x265.png No matter what I do, the transition on the banner (from red to black - highlighted) is smoother on x264. On x265 you the the squares after the close-up. What do you advice? My settings: Code:
--crf 22 --preset slow --output-depth 10 --tu-intra-depth 2 --rdoq-level 1 --qg-size 16 --ipratio 1.3 --pbratio 1.2 --max-merge 2 --rc-lookahead 60 --ref 3 --min-keyint 23 --keyint 240 --colorprim bt709 --colormatrix bt709 --transfer bt709 --deblock -3:-3 --psy-rdoq 5 |
30th March 2016, 01:24 | #3522 | Link | |
結城有紀
1) i7-4790 + B85 mobo + 8GB RAM + PSU 2) 2xE5-2670 (Used) + C602 mobo + Some ECC RAM (Used) + Good PSU First choice is about $450 without HDD, monitor and computer case. Second is about $600 without these craps. So if you have, let's say, 5 bluray to encode, distribute them to 5 different servers is going to maximize the speed. Given $3000, running 5 i7s will be faster than a single E7, let alone E7 being much more expensive. The whole point is that, you'll be paying a lot more for the high density (the amount of space on the rack). |
30th March 2016, 07:47 | #3523 | Link | |
Regarding my interest in regards to x265 in general, there are two things; Professionally, like, at my work, as my job, it's impossible for me to bring-in "fleaky hardware" from dubitous sources without proper invoices, warranties or without a corporate contract directly from HP, Dell or any other major retailers because it's actually a budget that has to be allocated and voted in city hall's court. Which implies, what hardware I will eventually get my hands on depends on things that are out of my control. Now what I have complete control over is what I do with my personnal funds, at home, as a leisure/hobby and what I have at the moment is a 3k budget to use as I see it at my own will and I have all reasons to believe, my best option at home is a Quad Xeon E7 v2 since I'm acquiring parts for reaaaaaaallly cheap compared to the official fares. But then again if someone has an idea of "what performs better than what for cheaper than whatever else grabbed from over here rather than over there", please let me know. I'm all ears. |
30th March 2016, 12:17 | #3524 | Link | |
User of free A/V tools
30th March 2016, 17:14 | #3525 | Link | |
結城有紀
For the professional part, unless you are running out of physical space, I'd not recommend using rack servers as they tend to be more expensive and less cost-effective. Buying multiple dell or hp i7s business level computer could be a good use of money, compared to those E5s (2x+ expensive with almost same performance). For the hobby part, if you can get dirty cheap E7 then go ahead. The E5 that I mentioned was also a quite cheap option for you. Just take care of the noise control and power consumption. For performance wise, google search "passmark <whatever cpu here>" and you can compare the score easily. |
30th March 2016, 18:43 | #3526 | Link | ||
No problems, no harm, I know you were trying to be helpful.
Regardless, thanks a lot for your input. Last edited by pingfr; 30th March 2016 at 19:16. |
30th March 2016, 20:26 | #3527 | Link | |
結城有紀
You're welcome. Hope it helps |
30th March 2016, 20:38 | #3528 | Link | |
It seems the best CPU power route from the worst to the best is: E5-2699 v3 x2 -> E7-4890 v2 x4 = E7-4850 v3 x4 -> E5-4669 v3 x4 -> E7-8895 v3 x8 -> Nothing yet? maybe some high-end E5 or E7 v4 around Q3-Q4 2016 -> E5 or E7 v5 with AVX512 H2-2017. Anything helps. Last edited by pingfr; 30th March 2016 at 21:02. |
31st March 2016, 00:53 | #3530 | Link |
Angel of Night
Another datapoint you might be interested in: VMWare, both ESXi and Workstation, gives you native encoding speed. Benchmarks of KVM and Xen show the same. Virtualbox you take a hit, unfortunately, but other virtual solutions allow 99%+ native speed in x264 and x265. (One of the benefits of heavy number crunching is that you don't need to call into the kernel or do I/O much.) You could use that to set up a test cluster for working out how a real cluster would perform at work, and get experience in setting it up.
I know Multicoreware has demonstrated a cluster, but I don't know how polished vs spit and duct tape it is, since they don't seem to offer it for sale. Aside from that, the only one I know of is lancoder, though there's x264farm & ELDER that might be modified to call x265 instead of x264, and Media Encoding Cluster that uses ffmpeg. None of those have been touched since 2009-2010 though, still a bit of a gap for someone who wants to come in and fill it. Maybe you can ask Netflix if they're willing to share part of their solution? You never know. |
31st March 2016, 17:30 | #3531 | Link | |
31st March 2016, 19:47 | #3533 | Link | |
Why would he hit thermal limits having a proper cooling? I can run my Ivy bridge 3770k @4.5 on air using a pretty high for these CPUs voltage (1.33V under 100% load -> unfortunately I haven't won the silicon lottery) and I still don't hit thermal limits. Ever. |
31st March 2016, 21:39 | #3534 | Link |
Angel of Night
I think the initial assumption was that it would be a pizza box (rack mount), which are much, much harder to cool that a standalone server, because there just isn't enough room. You don't see too many quad sockets that aren't racked these days. Only a heavy-duty watercooling can keep those running at full-tilt, and even that's not easy in the confines of the rack. Since it'll be standalone, though, it'll be loud but easily capable of being cooled.
31st March 2016, 22:04 | #3535 | Link | |
Posts: n/a
Your Core i7-3770K has a TDP of 77 watts, or roughly 19 watts per core. Many-core Xeons have higher TDPs, but much lower TDP per core (hence, the slower clock speeds). Fully saturating them with compute-intensive applications will heat them up good, and you are very unlikely to have enough thermal headroom to allow turbo mode to be engaged. |
1st April 2016, 09:07 | #3536 | Link | |
You are guessing wrong. I'm always running a monitoring tool(hwinfo). I always stay below my CPU's thermal limits and I have turbo clock at it's max (clocks & performance). Last edited by Vesdaris; 1st April 2016 at 09:11. |
1st April 2016, 20:12 | #3538 | Link | |
結城有紀
I know that some mobo can crack it a bit to have turbo boost running at all time. In this case the only requirement would be a decent sink and cooler. |
1st April 2016, 20:34 | #3540 | Link | |
Even with that, we see big throughput increases (>50%) on c4.8xlarge instances versus c3.8xlarge instances for x265 encoding with recent builds. C3.8xlarge: E5-2680v2 (Ivy Bridge), logical CPUs=32 C4.8xlarge: E5-2666v3 (Haswell), logical CPUs=36 While there are a few more cores, it's mainly going from v2 to v3. Last edited by benwaggoner; 1st April 2016 at 20:40. Reason: Added detail |
