17th December 2009, 09:23 | #1842 | Link | |
The reason I'm asking is because I can see the following lines in the madVR video properties: Code:
VIDEOINFOHEADER: rcSource: (0,0)-(1280,720) rcTarget: (0,0)-(1280,720) |
17th December 2009, 10:23 | #1843 | Link |
Press Ctrl+J and look for 'target rectangle'.
My test shows the following Code:
VIDEOINFOHEADER: rcSource: (0,0)-(0,0) rcTarget: (0,0)-(0,0) |
17th December 2009, 11:07 | #1844 | Link | |
Are those stats provided by madVR? |
17th December 2009, 19:17 | #1851 | Link | |
But now in the 32bit version of MPC I can select madVR but it is not used. I already tried disabling every output option of ffdshow other than YV12 but it didnt work. |
18th December 2009, 12:36 | #1853 | Link |
The testfile were various mkv files with H.264 (x264) Video (720p) and DTS or AC3 Audio The hardware is a Mobility Radeon 4650 with Catalyst 9.11. Output per HDMI into an AVR and from that per HDMI to the television. OS is still Windows 7 x64.
18th December 2009, 12:40 | #1854 | Link |
You are using 32-bit MPC-HC, and 32-bit FFDShow?
This should basically work with FFDShow default settings.. Make sure that Hardware Deinterlacing or anything like that is disabled, or just flush the settings and it should work. When you say MadVR is not being used, you mean that you can't select it, or it is selected, but instead 'Video Renderer' is used? Last edited by namaiki; 18th December 2009 at 12:43. |
18th December 2009, 12:48 | #1856 | Link |
But, FFDShow(or something) is definitely loading in MPC?
Check the 'pin info' for whatever video renderer is loading and search for "- Connection media type:" and under that is listed the colourspace. Last edited by namaiki; 18th December 2009 at 12:51. |
18th December 2009, 12:51 | #1857 | Link | ||
Colorspace output by ffdshow is YV12. Quote:
What do you mean by flush the settings? I can select it but standard video renderer is used instead. Last edited by PhoeniXYZ; 18th December 2009 at 12:53. |
18th December 2009, 12:57 | #1858 | Link | |
Windows Registry Editor Version 5.00 [-HKEY_CURRENT_USER\Software\GNU\ffdshow] |
