9th October 2017, 18:30 | #46383 | Link |
Using latest madvr and nvidia drivers. Now Windows will automatically turn on its hdr if I play a movie with madvr. I have it set to 'off' because I'm using a 980Ti. But no matter what setting I try (let madvr decide or passthrough hdr) Windows will automatically turn on its hdr.
9th October 2017, 18:50 | #46384 | Link |
Hi Madshi,
You appear to have introduced a new "bug" When optiming custom resolutions; When you press "Test Mode", it tests the new custom resolution. But "Stop Timer" doesn't restore the previous mode, only "No" does. When pressing "Yes" (to save the custom mode) it say's you can't save the active mode |
9th October 2017, 19:54 | #46387 | Link | |
Win8.1x64, Kaby Lake i5 7200U/HD620
yes, I did post freeze reports, but you came to the conclusion that madVR is mostly gone already and you can not pinpoint a reason, why MPC-BE should hang. |
9th October 2017, 20:00 | #46388 | Link | |||||||||||||||
Compression artifact reduction is run first, debanding afterwards. Quote:
FWIW, there's minor blocking and there's major blocking. For minor blocking, RRN might work well, but I think it will be out of its depth with major blocking. Sorry, I usually don't give out ETAs. Quote:
If the GPU driver refuses to save the mode that's a bug in the Nvidia GPU driver, unfortunately. It happens for me, too. Nvidia is aware of this bug and will hopefully fix it some time in the future. Argh, that's too bad... In that case, can you create some more freeze reports for me? This time it would help if you did this with the proper media player PDB debug symbols and LAV Video Decoder PDB debug symbols in the right folder. That way the freeze reports will also tell us what the media player and LAV were doing. Maybe that helps figuring out what's going on? |
9th October 2017, 20:17 | #46390 | Link | |
Is there a bug with D3D11 Windowed mode ? it's 8 bit , it's only Full Screen 10 bit. or this just how it was , I forgot.
I have some crashes with the new madvr when I'm closing potplayer same as Quote:
Is the version 92.6 hotfix suppose to fix this issue ? Faulting application name: PotPlayerMini64.exe, version: 0.0.0.0, time stamp: 0x592fd342 Faulting module name: ntdll.dll, version: 10.0.15063.608, time stamp: 0x8274fd8b Exception code: 0xc0000374 Fault offset: 0x00000000000f775f Faulting process id: 0x2084 Faulting application start time: 0x01d34133f3f2c707 Faulting application path: C:\Program Files\DAUM\PotPlayer\PotPlayerMini64.exe Faulting module path: C:\WINDOWS\SYSTEM32\ntdll.dll Report Id: da73f4a9-2604-45f5-a785-585d5d4a319f Faulting package full name: Faulting package-relative application ID: EDIT : Seems it does fix it. Thanks ! Last edited by x7007; 9th October 2017 at 20:28. |
9th October 2017, 20:38 | #46391 | Link |
You double click "activate debug mode.bat", then you reproduce the problem, then you double click "activate release mode.bat". Done. Now you should have a monster sized debug log on your desktop. Zip it up and upload it somewhere, don't attach it to this forum.
9th October 2017, 20:39 | #46392 | Link |
madVR v0.92.6 released
http://madshi.net/madVR.zip Code:
* fixed crash introduced in v0.92.5 * algos "reduce compression artifacts + random noise" now faster for chroma * added "deblockChroma" and "denoiseChroma" file tags |
9th October 2017, 20:40 | #46393 | Link | |
Well, you know, Windows has a toggle to turn on hdr. I always have that off. I use nvidia. But now when I play a movie, Windows will turn on that setting -if I go to the menu I can see it's on. And the colours when I stop playing a movie will wash out: I have to go to the menu and turn off hdr everytime I stop playing a film. It starts on its own. This is also causes the screen to sometimes not display hdr colours correctly. Sometimes it works, sometimes it looks washed out. |
9th October 2017, 20:42 | #46394 | Link | |
9th October 2017, 20:45 | #46395 | Link |
Yea, I'll try to get to it in the next couple days when I get a free minute. The source material that is my goto testing for these kinds of improvements is the Highlander Endgame DVD upscaled to 1080p. I threw in Remo Williams just to see cause I know how bad that DVD is mastered and that really surprised me. I'll see what I can do for screenshots soon.
9th October 2017, 20:47 | #46396 | Link |
I'm really glad to see you've created a RCA and a RRN, I can finally get rid off ffdsohw... Well not yet.
First, I want to precise I'm not a huge fan of processing filters. But some DVDs are so noisy... It's almost unwatchable on a large 4K screen. So in that case, I'm willing to sacrifice some little details if the whole picture seems better. RCA is great! It does a wonderful job at reducing the compression artifacts while preserving a very good level of details. It's very good for DVDs, I'm using strength 2. But even at 1, the difference is easily visible. I thing the highest values are useless, I would prefer one level below level 1 to fine tuning some videos. RRN was one of the algos I was waiting for the most. For now, I'm a little disappointed with this one. Ok it does a very good job at denoising the picture but the cost in details and sharpness are way too high for me even at strength 1. Maybe is it just a matter of strength? Could you create a strength some levels below 1? For now, I prefer TTempSmooth. It's a good denoiser, it doesn't clear all the noise but it stabilize it while preserving most of the details. But I would prefer to use only MadVR because ffdshow is quite buggy! Anyway, thanks a lot for all your work. I hope you can improve RRN in a future build but you definitely made MadVR more incredible once more
Windows 8.1 and 10 x64 - Intel Core i5-4670K (4.2 GHz) - 8 GB DDR3 - MSI Geforce GTX 1080 8 GB - Sony KD-55A1 - Denon AVR-X3600H |
9th October 2017, 21:04 | #46397 | Link | |
https://drive.google.com/open?id=0By...3BsV3QzdFp3OGc PS: You didn't say anything else about the process I should follow so I activated debug mode, started Potplayer, produced the hang, killed off potplayer, then deactivated debug mode. Last edited by mzso; 9th October 2017 at 21:06. |
9th October 2017, 21:10 | #46398 | Link | |
9th October 2017, 21:16 | #46399 | Link |
Hi madshi,
Wont quote the entire post. This error is the new error when you can't save because the NVIDIA driver bugged up? doesn't look like the/a GPU/driver error. After clicking "Ok" it reverts back to the previous resolution Edit: If I stop the timer, change the resolution in the NVIDIA control panel I get a very different message. (logical probably because I change resolutions in between) Edit 2: It just appears to be still in "test mode" in the NVIDIA API and thus not allowing to save it Edit 3: Checked with MadVR 0.9.2.0.3, it is 99% sure a MadVR bug. On that version I can set pretty much any resolution and it will save it. Going back to 9.2.0.6 gives me the same behavior/error again. So can you please fix that? Looks to not exit/still be in "test mode" when you click save, thus giving the error it cannot save the active mode. Last edited by Sarlaith; 9th October 2017 at 21:49. |
9th October 2017, 21:23 | #46400 | Link | |
Test patterns: Grayscale yuv444p16le perceptually spaced gradient v2.1 (8-bit version), Multicolor yuv444p16le perceptually spaced gradient v2.1 (8-bit version) |
