Go Back   Doom9's Forum > General > Linux, Mac OS X, & Co
Old 11th August 2010, 15:13   #1  |  Link
Get Go
Anyone know of a free OS X app to demux HD h.264 .ts files?
Hi. Any one know of a free app to demux HD .ts file for OS X? I came across this blog that recommends MeGUI but Me GUI is Windows only.
I tried ProjectX but it doesn't work with h.264.
Thanks
Get Go is offline   Reply With Quote
Old 11th August 2010, 16:21   #2  |  Link
nm
tsMuxeR can demux TS files and it comes with a nice GUI. More generic command-line alternatives are ffmpeg and mplayer.
FFmpeg:
ffmpeg -i input.ts -an -vcodec copy -f rawvideo video.264
ffmpeg -i input.ts -vn -acodec copy -f rawvideo audio.ac3
Tracks can be chosen with -map 0:TID
MPlayer:
mplayer input.ts -dumpvideo -dumpfile video.264
mplayer input.ts -dumpaudio -dumpfile audio.ac3
Programs and tracks are chosen with -tsprog, -vid and -aid.
Old 11th August 2010, 17:20   #3  |  Link
Get Go
Thanks for the reply nm,
Unfortunately tsMuxeR doesn't work with snow leopard.
I'm a bit of an OS X newbie and really don't have a clue about comandline stuff.
Thanks for the info anyway.
Old 11th August 2010, 17:38   #4  |  Link
nm
VoxMac has fixed the tsMuxeR Qt GUI issues on Snow Leopard in his build: http://forums.macrumors.com/showthre...41#post9003541
User comments in the SmartLabs blog may also help:
http://blog.smartlabs.tv/2009/03/new...available.html
http://blog.smartlabs.tv/2009/03/new...-released.html
Old 12th August 2010, 11:35   #5  |  Link
Get Go
Thank you nm
I installed VoxMac's unofficial version and it's working.
(Note to any one else doing the same you must remove/delete two Korean fonts from your library for VoxMacs version to work-details in the read me. And don't bother with the older official versions like version 1.8.24 which will load up but can't process files or 1.8.8b which is windows only!
For anyone who cares and for what its worth the checksums from my copy of VoxMac's tsMuxeR_1.10.6_VoxMac_Unofficial_Build.dmg from MegaUpload
SHA1: 5f6e0436e898db1a350eeb4e22aae4fcd7d5fb8c
MD5: 8664387063e5065b684182d37f72173f )
Thanks again for your help nm
Old 1st September 2010, 18:42   #6  |  Link
snherbst
snherbst's Avatar
What about using VLC
Free software the best thing happend.
Debian and a system update is as simple as
apt-get update && apt-get upgrade
snherbst is offline   Reply With Quote
Old 1st September 2010, 18:52   #7  |  Link
nm
It should work, but both the GUI and CLI are bit too complex for simple demuxing tasks. I'd rather use ffmpeg or MPlayer on command line.
.ts, demux h.264, free app, os x, transport stream
