Old 3rd October 2004, 01:38   #101  |  Link
mikewillnot
I just checked again, and everything was done according to the guide exactly, including changing the still time to zero. Notable: the PGC Command Table includes 64 pre-commands, 43 post-commands, and my 1 added cell command.
"Education alone is not enough. The world is full of educated derelicts."
..... Calvin Coolidge
mikewillnot is offline   Reply With Quote
Old 3rd October 2004, 02:01   #102  |  Link
2COOL
PGC Navigator in Training
2COOL's Avatar
@mikewillnot
Check your PM.
2COOL
Old 3rd October 2004, 04:05   #103  |  Link
DMagic1
DMagic1's Avatar
@mikewillnot
Sounds like you missed the step where you put the new cell number in. This step is easy to miss. I believe its after you change the still time to 0.
DMagic1 is offline   Reply With Quote
Old 3rd October 2004, 04:29   #104  |  Link
2COOL
2COOL's Avatar
@mikewillnot
Though I don't have your DVD, it may be possible that you might have more than one Aspect Ratio Menu? I've encountered some DVDs with intros to the ARM with the buttons displaying late in the intro cell.
2COOL
Old 16th October 2004, 05:02   #105  |  Link
mikewillnot
2cool: correct as usual. I redid this one and discovered another identical aspect ratio menu in another cell. applied the changes to that cell, and the guide indeed works as advertised. Thanks for the PM help, BTW.
Old 16th October 2004, 05:28   #106  |  Link
2COOL
2COOL's Avatar
I'm glad things worked out for you! I have since updated the guide I sent you and if you didn't know it by now, it's found here.
2COOL
Old 16th October 2004, 05:31   #107  |  Link
2COOL
2COOL's Avatar
<EDIT>
2COOL
Old 24th December 2004, 05:43   #108  |  Link
rpboy
Re: Finally! My guide on how to remove ANY Aspect Ratio or Language Start Menu!
Originally posted by 2COOL
[11/11/2004]: New and improved HTML guide using better tools to do the job.
2COOL,
The HTML guide is nice though I just tried it with the latest DVDRemakePro demo and its not the same as you illustrate in your guide. There doesn't appear to be any option to view the PGCs in tree form in the left column, at least not that I could see.
I figured it out, but you may want to update your guide with the new way that the software has been implemented.
Thanks for all your hard, and creative, work here.
rpboy is offline   Reply With Quote
Old 3rd January 2005, 20:57   #109  |  Link
2COOL
2COOL's Avatar
@rpboy
There is a new version out using just PgcEdit. http://forum.doom9.org/showthread.php?threadid=87619
2COOL
Old 6th January 2005, 06:29   #110  |  Link
rpboy
Cool, will have to check it out next time I need to do one.
Old 7th January 2005, 20:44   #111  |  Link
2COOL
2COOL's Avatar
If you use the v3.0 guide, please post your comments in the appropriate thread.
2COOL
