22nd February 2013, 19:55 | #6981 | Link | |
21 years and counting...
Let's say I want to create a qp file from a source file with time-codes. Therefor I need a frame rate setting to get the correct conversion from time-code to the corresponding frame-number. |
23rd February 2013, 08:23 | #6982 | Link |
I see no use beating my head against the wall over AVSource, DSS and let go of my OLD Fliker Building methods in Win7 [64] and accept the "File Indexer" is the Button to click in MeGUI. Perhaps as I get use to the OS I may find some of my old encoding practices still alive in there - somewhere.
Needless to say I am impressed with that File Indexer Button. It is easy to learn and Encodes are great. Taking LigH's advice, I used Xvid Codec set Default/Unrestricted/RealTime/Q2 and restricted the Scrn Recorder app to capture a Max of 630MB's at 30FPS. A 720x296 Res Capture yielded a 33min/18.7MBpermin Stream (That's Max's my 121KBps Download Link). The Scrn Recording Utility is restricted to a 1900MB limit for AVI. Rather then diluting the Quality of the Xvid CBR Enc, I elected to use Q2 and divide the Capture into 3 or 4 Parts. Depending the length of the movie, say 1:40Hrs for 3 x 33min Captures and 2:12Hrs for 4 x 33min Captures. NOTE: Each capture has to run the Full 33mins or you will loose Audio Sync when Editing, Splicing and Appending the Parts with VirtualDub into ONE Xvid mPeg4/PCM.AVI Source File ready for AVC x264 encoding or making a DVD. The Soruce AVI File will have these Properties, with a 121KBps DL Link: 1188Kbps Video Bitrate - 720 x 296 (or > divided by 2 or 4) - 44.1KHz PCM Stereo Audio Track and approx 2.35GB's for a 2:12Hr Capture. Lots of Data for working with ;o) I've concluded that other then MS mPeg4 Encoders Win7 [64] natively does not support the use of AVISource or DirectShowSource for any AVI file made by other mPeg4 Encoders; SO USE Zathor's File Indexer Button ;o) I can't believe the power of this i7 2700k. I did manage to MAX all 8 threads with a x264 encode for 15 mins and ended up with a 701MB - 2:09Hr V_MPEG4/ISO/AVC with a 694Kbps Video Bitrate. Perfect for burning onto a 700MB CD - If you can find them anymore - LOL. That Enc would have taken my Barton XP a Day or more to process - Love it. Capturing Scrn Recording at 30FPS isn't all that bad. Due to the 30FPS shutter, you do notice some strobing in scenes when large objects sweep across the background; but, it isn't all that bad. I'm going to try Higher shutter speeds in the future. Come to think about it as long as you can render video the speed of your Download link would not have anything to do with it. That's the purpose of Screen Recording ;o) You Guys are Great - THANKS ;o) PS: Found a BT848 64-Bit Dvr for my Old ATi Tv-Wonder PCI - YaHoo! I've been looking at the Hauppauge WinTV-HVR-1250 Low Profile TV Tuner PCI-E - Really Cheap like $23 - Anyone have experience with it - Does it have Stereo Audio? Last edited by Tiny Mud; 23rd February 2013 at 15:46. |
23rd February 2013, 09:36 | #6983 | Link |
Read yourself: Hauppauge WinTV-HVR-1250
23rd February 2013, 14:08 | #6985 | Link |
Thanks Ligh - Stereo and HD - That's nice for $23 on eBay.
Administrators have warned me that my posting in this Thread is irrelevant to MeGUI but I posted here initially because Zathor's "AVISource" Button does not work in Win7 [64] as it does in Win7 [32]. Well I got answers that lead me to understand that it's not a MeGUI issue. I will have to be more selective where I post in the future but I don't think I would have found a better answer if I had not posted here. Thanks Guys. Last edited by Tiny Mud; 23rd February 2013 at 14:23. |
24th February 2013, 00:51 | #6986 | Link | |
Notice that only 1 sub is shown as selected (Finnish) Attachment included are: Megui logfile: Notice that more subs than 1 are being processed. Mediainfo of encoded file. This time now the correct one: Notice that more than 1 sub is in the final encode. |
25th February 2013, 11:18 | #6988 | Link | |
Source can be found here: http://eth0.dk/files/meguisubfun.rar Please note this is only for testing purposes. Best regards |
2nd March 2013, 12:18 | #6992 | Link |
I saw x264 was updated to rev2273, however there seem to be an encoding bug in that revision, according to the latest commit :
http://git.videolan.org/?p=x264.git;...0cb2288e8a650a |
2nd March 2013, 19:40 | #6995 | Link |
Increase the Resolution
I've been working with Megui to re encode my video files .
I want to increase the resolution of a video to 1280x720 from 848x480. But Megui seems to lock me on the same Resolution without allowing to increase it. Please Unlock This field |
megui |
