Old 15th May 2011, 05:04   #7741  |  Link
Hypernova
Originally Posted by hawkson View Post
What is the minimum system to achieve MadVR and FI such Interframe/SVP?
Please list the least expensive configurations neccessary to achieve Madvr+FI on 1080p
Thanks
Also, which is best bang for the buck for HTPC applications
NVIDIA or AMD?
I can't exactly answer that question, but I have some input. I tried SVP yesterday just to see how it looks. My setup barely made it for 720p and default profile for i7-920. You can choose other profile I guess.
Spec: Intel Core i5-3570K, 8g ram, Intel HD4000, Samsung U28D590 4k monitor+1080p Projector, Windows 10.
Last edited by Hypernova; 16th May 2011 at 02:19. Reason: Take out some off-topic | 2nd: add "can't"
Hypernova is offline   Reply With Quote
Old 15th May 2011, 22:25   #7742  |  Link
zamadatix
fairchild: I have the power but not the skill apparently, I installed it and set everything up but I am lost as to how to use the avsi script with mpchc?!
zamadatix is offline   Reply With Quote
Old 15th May 2011, 22:32   #7743  |  Link
Thunderbolt8
after switching over to win 7 64 from XP, the performance has decreased quite a bit for me and I now get dropped and delayed frames which has not been the case with XP before. windows mode is especially bad. Ive already set disable desktop composition which helped a little, but only for exclusive mode, as I dont really want this to happen in general, when I can still see the desktop in windowed mode. any more ideas?
Laptop Acer Aspire V3-772g: i7-4202MQ, 8GB Ram, NVIDIA GTX 760M (+ Intel HD 4600), Windows 8.1 x64, madVR (x64), MPC-HC (x64), LAV Filter (x64), XySubfilter (x64)
Old 15th May 2011, 23:55   #7744  |  Link
ryrynz
ryrynz's Avatar
I have a similar system and everything runs excellent, make sure you have Smoothvision Anti-Aliasing and Anisotropic set to Application settings.
If your still getting dropped frames play round with the options under and including 'present several frames in advance' personally I don't need to touch any of them and have 3 frames presented in advance.
Under General settings you could also try 'use a separate device for presentation and use D3D11 but again I have not needed to use these to get problem free playback.
Check your CPU and GPU load (Task manager/Resource Monitor, GPU-Z) to make sure something something else isn't eating your CPU and to see how your GPU is coping with your settings.
Lastly you could also look at your scaling algorithms but given the performance of the 4770 you you shouldn't have any issues running at the most demanding settings here.
Old 16th May 2011, 09:33   #7745  |  Link
Thunderbolt8
max GPU load with default settings is only max. 60%. so I guess that CPU load is a bit higher here with win7.
Old 16th May 2011, 09:42   #7746  |  Link
VresiBerba
Anyone?
Originally Posted by VresiBerba View Post
How do you get subtitles when using madVR. I have MPC-HC 3104 (x86) and madVR 0.61 and I just can't get subtitles to work. The .srt file has the same file name and is in the same folder but still it doesn't load, and when I drag and drop the .srt file into the MPC-HC window, playback stops and it says 'cannot render the file'.
Help.
VresiBerba is offline   Reply With Quote
Old 16th May 2011, 10:13   #7747  |  Link
Thunderbolt8
is auto load subtitles in mpc-hc playback options ticked? or directvobsub installed? if so, try out another subtitle file and/or movie.
Old 16th May 2011, 10:53   #7748  |  Link
VresiBerba
Yes and yes. Neither the built-in subtitle engine in MPC-HC, nor directvobsub is working, the latter I don't even want to use. The subtitle works, just not when using madVR, and now I found out it doesn't work when using Haali either. It only works with WMR and EVR.
Old 16th May 2011, 11:40   #7749  |  Link
ryrynz
ryrynz's Avatar
I find I have to keep my CPU load below 60% or so with post-processing or I get dropped frames, there is no option that fixes that, obviously one or more of the cores is maxed out in that situation.
My 6670 however is cruising along at only around 30% usage with my current settings. You could give madVR061vsync a go on page 378 if you haven't already.
Old 16th May 2011, 14:31   #7750  |  Link
Thunderbolt8
what exactly does it do differently compared to the normal madvr version?
try changing to another version of mpc-hc, maybe its a bug. or try complete uninstall and then reinstall mpc-hc again.
Old 16th May 2011, 14:47   #7751  |  Link
hawkson
Whats a better upgrade path to get Madvr and SVP/FI on 1080p? 100$ for a more expensive CPU or 100$ for better GPU.
I bought a i3 2300 and a 5450. Its not enough, I'll return it and buy something better.
Please give suggestions.
hawkson is offline   Reply With Quote
Old 16th May 2011, 15:16   #7752  |  Link
mindbomb
return the 5450, buy a nvidia gt 430 ( zotac has a passive one), and use it to run lav cuvid with madvr.
mindbomb is offline   Reply With Quote
Old 17th May 2011, 01:49   #7753  |  Link
VresiBerba
what exactly does it do differently try changing to another version of mpc-hc, maybe its a bug. or try complete uninstall and then reinstall mpc-hc again.
Ah, it works. I downloaded 3112 and 'installed' it instead of unzipping it into a folder, so I'm not sure which actually resolved the problem. But now I have tearing instead
Old 17th May 2011, 07:45   #7754  |  Link
ryrynz
ryrynz's Avatar
Process priority is set at maximum with that build.
Old 17th May 2011, 13:20   #7755  |  Link
Budtz
Hmm seems like its bin a while since there have bin any updates to madvr. Any1 know anything?
Budtz is offline   Reply With Quote
Old 17th May 2011, 14:10   #7756  |  Link
cyberbeing
Broadband Junkie
VSync thread priority is set to maximum. madVR's five other threads are unchanged.
I said I was going out of town this past 3 weeks, so madshi decided to take a break from madVR development as well.
No, seriously, this is more the norm for madshi. Frequent releases are a special treat, a new build ever few months or once a year is what you should get used to. Right now he is probably just trying to get his mind off the stressful work needed to troubleshoot and fix all those bugs and issues people reported over the last few revisions. Who knows, maybe he got really really bored and started coding up GPU deinterlacing algorithms, 3D support, or yRGB support. New features are always more fun than bug-fixing.
Old 17th May 2011, 14:24   #7757  |  Link
CruNcher
CruNcher's Avatar
DXVA takes time
It is about Time
Old 17th May 2011, 15:09   #7758  |  Link
ney2x
Is there a workaround to use madvr with WMP12 bypassing the built-in EVR?
ney2x is offline   Reply With Quote
Old 17th May 2011, 15:53   #7759  |  Link
nevcairiel
No, WMP cannot use any other renderer.
Old 18th May 2011, 07:18   #7760  |  Link
ianken
my display will do 1080p50, is there a way to get madvr to switchto that for 25p content? I've added that mode to the list but it does not switch.
lol. nevermind. started working.
ianken is offline   Reply With Quote
