Old 20th July 2016, 00:00   #38821  |  Link
Asmodian
Originally Posted by pose View Post
Asmodian, can i also ask you which settings you prefer for anime?
For 720p24 to 2560x1440@144Hz I am currently using:
Chroma Upscaling: Reconstruction SharpAR + SR1
Luma Doubling: NNEDI3 256
Chroma Doubling: NNEDI3 32
Image Upscaling (not used): JincAR
Thin Edges: 0.6
Smooth Motion: On
Dithering: ED1, colored noise OFF, change dither OFF
Ordered dithering is also good. I have all artifact removal options disabled for this one, I will turn them on if the source needs it. I also play with the upscaling refinement options for different sources, I have never found a good set of 'default' settings for the refinement options. No trade quality for performance options checked.
madVR options explained
Old 20th July 2016, 00:03   #38822  |  Link
pose
Asmodian, what card allows you to use so much neurons?
pose is offline   Reply With Quote
Old 20th July 2016, 01:02   #38823  |  Link
seiyafan
Originally Posted by Sunset1982 View Post
I ordered a GTX1060 today. Will add it to my comparison end of this week...
Thanks!
seiyafan is offline   Reply With Quote
Old 20th July 2016, 01:22   #38824  |  Link
ryrynz
ryrynz's Avatar
He has a 980 Ti.
Old 20th July 2016, 10:09   #38825  |  Link
AntonP
I have 2 problems with 3D playback using LAV + madvr.
Config i7-2600k + gtx980 + win 8.1, latest nightly builds of MPC-HC and LAV.
1. nvidia refresh rate problem - 23.971 instead of 23.976. in 2D mode i fixed it with 24Hz monitor refresh rate (24p instead of 23p in madvr settings) + reclock
in 3D i cant set 24Hz in madvr - 23p mode switches on automaticaly.... how can i set 24p in 3D?
2. artefacts in 3D mode in some scenes (every time in same moment). red car on screenshot is example of it. in powerdvd 16 all is ok, so its not BD3D problem. I think its decoder's problem, but not sure. how to fix this bug?
AntonP is offline   Reply With Quote
Old 20th July 2016, 11:15   #38826  |  Link
chros
chros's Avatar
Thanks!
Ryzen 5 2600,Asus Prime b450-Plus,16GB,MSI GTX 1060 Gaming X 6GB(v398.18),Win10 LTSC 1809,MPC-BEx64+LAV+MadVR,Yamaha RX-A870,LG OLED77G2(2160p@23/24/25/29/30/50/59/60Hz) | madvr config
Old 20th July 2016, 21:02   #38827  |  Link
Warner306
Originally Posted by seiyafan View Post
Thanks!
I'd like to know if the GTX 1060 is capable of 1080p -> 2160p with these settings:
Chroma: super-xbr100 + AR
Luma Doubling: NNEDI3 32 neurons
Image: Jinc + AR
Artifact Removal - Debanding On
Upscaling Refinement: SuperRes (3)
Dithering: Error Diffusion 2
Old 21st July 2016, 00:33   #38828  |  Link
aufkrawall
Most certainly it is impossible unless you remove Error Diffusion from that list (and probably even without it).
Edit: Ok, with <= 30fps it might work.
Old 21st July 2016, 00:47   #38829  |  Link
i don't think error diffusion is a good idea at UHD
Old 21st July 2016, 10:08   #38830  |  Link
XTrojan
Care to explain? Is there a major drawback except performance hit?
Is there a major difference with error diffusion from 1080->2160p?
XTrojan is offline   Reply With Quote
Old 21st July 2016, 10:33   #38831  |  Link
Sunset1982
Image: Jinc + AR
ok, I will test it. Card will arrive today
Edit:
Tested for you. File was 1920x1080 (with black bars), 23,976, 8 Bit AVC, D3D11 FSE, 10Bit mode:
27,04 ms / 140 w (with automatically detect hard coded black bars feature & crop black bars)
33,45 ms / 170 w (without detecting hard coded black bars)
tested with 1920x1080 (Avatar Mkv, real 16.9 fullscreen without black bars), 23,976, 8 Bit AVC:
34,1 ms / 172 w
Intel i5 6600, 16 GB DDR4, AMD Vega RX56 8 GB, Windows 10 x64, Kodi DS Player 17.6, MadVR (x64), LAV Filters (x64), XySubfilter .746 (x64)
LG 4K OLED (65C8D), Denon X-4200 AVR, Dali Zensor 5.1 Set
Sunset1982 is offline   Reply With Quote
Old 21st July 2016, 11:58   #38832  |  Link
Sunset1982
guys, my gtx1060 arrvied. Started my testings but I have a problem:
Somone knwos how to deactivate the different powerstates of this card?
gtx1070's performance looked stable and it were scalable with powerconsumption.
with gtx1060 if got the problem, that in my first test, it starts with poerconsumption of 62 w and performance of 9,3 ms, but after some seconds it jumps form 62w to 41 w, and performance drops to 16,2 ms. seems to use a different power state. how can I deactivate this?
Old 21st July 2016, 13:53   #38833  |  Link
PetitDragon
try to install NVIDIA Inspector and run the following command line:
nvidiaInspector.exe -forcepstate:0,0
PetitDragon is offline   Reply With Quote
Old 21st July 2016, 18:16   #38834  |  Link
pirlouy
_
Why would you want that ?
If power states are well done, you have nothing to do, you won't see a difference on your screen.
Old 21st July 2016, 21:23   #38835  |  Link
Sunset1982
for normal viewing it would be good. But for my comparison it is not, because I can't compare its performance with different settings to the other cards I've tested.
And what command I have to write to reset it to default after my testings?
Old 21st July 2016, 21:48   #38836  |  Link
Asmodian
It is only a matter of diminishing returns and increasing performance requirements.
As the pixels get smaller the benefits of ED over ordered dithering decrease and while the number of pixels goes up the performance hit does too. At UHD the first thing I would drop would be error diffusion in favor of ordered dithering.
Old 21st July 2016, 23:02   #38837  |  Link
PetitDragon
"That's the problem, sir. We don't know."
Old 21st July 2016, 23:37   #38838  |  Link
Asmodian
Just reboot.
Old 21st July 2016, 23:46   #38839  |  Link
Knight77
Edit:
34,1 ms / 172 w
Could you please tell me the GPU/engine load and fan speed? My GTX 960 can manage this kind of settings but with high load and, by consequence, a high fan speed... meaning noise.
Knight77 is offline   Reply With Quote
Old 22nd July 2016, 00:32   #38840  |  Link
ryrynz
ryrynz's Avatar
1060 is about twice as fast as a 960, if you've got the cash it's a worthwhile upgrade. It may be better to give yourself headroom and a good cooler to avoid noise/heat.
Anyway.. may wish to avoid excessive talk about the 1060 here.
