23rd August 2010, 17:43 | #142 | Link |
Some other change i did could've already fixed that. But i am still looking for a quick sample to verify that is not ts/m2ts, just to be sure.
Turns out, remuxing a m2ts file is not done with 3 clicks, i have to download several tools =( I never really cared for remuxing things before.. meh
23rd August 2010, 17:53 | #143 | Link |
4:2:0 hater
eac3to + mkvmerge is where the beacon is, eac3to from the command line (with scripts to make things easy if you don't want to type the stuff all the time) and then mkvmerge it's not 3 clicks, maybe 10 or so
23rd August 2010, 18:27 | #144 | Link | |
Matroska find' ich toll
bluray to mkv is an easy job and you have the best quallity. for the most of movies i use this way. |
23rd August 2010, 18:51 | #145 | Link |
Good news: I found the change thats causing TrueHD to break.
Bad news: Its the change that was meant to fix the stutter issue =( I'll dig into that, i guess. Edit: After reverting the old "fix" i still don't see the stuttering issue. Possible another change i did also fixed it. I even increased the number of buffers to some incredibly high amount, and they slowly filled up. So i'll keep the fix disabled and release a new version for testing, maybe i was just too blind to see it! PS: git bisect ftw
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 23rd August 2010 at 19:13. |
23rd August 2010, 19:20 | #146 | Link |
LAVFSplitter 0.7
- Further improvements to aspect ratio detection - Restore old FPS detection - Adjusted flushing to fix subtitle delays - Reverted a timing change that broke TrueHD Download: 32-bit & 64-bit Please pay attention to the stuttering problem, it may be back in this version. The fix i previously applied completly broke TrueHD playback, but i couldn't reproduce the issue anymore, so maybe one of the other optimizations fixed it too. I didn't work on the other things i wanted to get done because i want feedback on the stuttering thing as soon as possible. So next version will have new features again.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 23rd August 2010 at 19:29. |
23rd August 2010, 20:22 | #147 | Link |
4:2:0 hater
I don't get any stuttering with 0.7, TrueHD and subtitle delay is fixed. Looks good
BTW, did you do anything to the SSA fonts? I get correct fonts in some files, but incorrect in others! |
23rd August 2010, 20:25 | #148 | Link |
I don't think i could even do anything to change the fonts of SSA subs.
I think i changed the mediatype from SSA to ASS some time ago, if that changes anything. I should patch up ffmpeg to differentiate between SSA and ASS, so its always the correct thing. What exactly is the problem? Files with embedded fonts? Or system fonts that just don't get choosen correctly?
23rd August 2010, 20:39 | #149 | Link |
4:2:0 hater
Files with embedded fonts, like that Haruhi sample.
I just noticed in one of your commits that ffdshow is not happy if you send TrueHD as TrueHD, can you PM me a build that sends it as TrueHD? Maybe I can debug it. |
23rd August 2010, 21:00 | #150 | Link |
Its not only ffdshow, MPC-HC internal as well, but sure, i'll send it your way.
I just noticed that i can teach it to send 2 media types now, so it can always fall back to the AC3 media type if needed. =) I send you a PM with the adjusted .ax, just take the av* dlls from 0.7
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 23rd August 2010 at 21:05. |
24th August 2010, 08:00 | #151 | Link |
I'm trying your splitter and it is very good, thanks!
But I have the same issue which MPC internal one for VC-1 video in m2ts from my Blu-ray. If you use an external VC-1 decoder (so no the MPC internal one, because so no problem), the frame rate is badly jerky. Some renderer (EVR-CP, Madvr recently,...) use some "dirty" trick to find the correct original frame rate but not all (as EVR-Sync which is currently use). I try also your splitter with KMP and same issue, jerky frame rate again. I don't know if you already know this issue. |
24th August 2010, 08:16 | #152 | Link |
What external decoder did you use?
I know it works fine with ffdshow, at least, but its pretty similar to the internal decoder. The internal splitter can't even get it right with the internal decoder, so at least thats a improvement.
24th August 2010, 08:19 | #153 | Link |
@nevcairiel:
Hi. You can close issue 5, it was fixed already. I updated my "tests" post - this time i tested some *.MPG samples. BTW, by some reason, there is no free m2ts splitter right now able to connect to "CyberLink Video Decoder (PDVD10)" to decode VC-1i using DXVA. By some reason MPC splitter fail to connect. Only working solution is to use Cyberlink CLDemuxer2 demultiplexet for m2ts files, but then there is no support for subtitles and no way to switch between multiple audio streams. By other words - will be posiible to modify LAVF splitter to be usable with CyberLink Video Decoder (PDVD10) decoder for VC-1i DXVA playback?
Working machine: Win10x64 + Intel Skull Canyon My HTPC. How to start with Bitcoin |
24th August 2010, 08:21 | #154 | Link |
The cyberlink decoder might require a custom media type. I would have to get my hands on a copy of the splitter and decoder to see whats being send around there. I guess there are trials of PDVD10?
24th August 2010, 08:24 | #155 | Link |
I wil PM link to Cyberling demultiplexer and decoder.
24th August 2010, 08:28 | #156 | Link |
Oh also a VC-1i sample would be good, i don't think any of my blurays was actually interlaced.
BTW, i thought the gabest splitter would work, but maybe not with PDVD10 anymore.
24th August 2010, 08:40 | #157 | Link | |
I am just uploading m2ts VC-1i sample for you. BTW, there is another problem with VC-1 files + FFDshow decoder - there is no way (at last i didnt found it) how to block FFDshow decoder to load for VC-1i and keep it for VC-1p - there is no "is/is not interlaced" condition in proflies :/ EDIT: Here is VC-1i sample.
Working machine: Win10x64 + Intel Skull Canyon My HTPC. How to start with Bitcoin Last edited by hoborg; 24th August 2010 at 08:50. |
24th August 2010, 09:25 | #158 | Link | |
For Cyberlink VC-1 and Arcsoft decoders, they are not directly usable in MPC, you need to use loaders. Last edited by Matching_Mole; 24th August 2010 at 09:32. |
24th August 2010, 09:34 | #159 | Link | ||
Anyway, thanks for the sample, i'll check it out after work. Quote:
I'll double check again. That might as well be another issue, and the decoder strictly limiting which splitter it connects to. In that case, i wouldn't be able to fix it, and you would have to rely on a loader.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 24th August 2010 at 09:38. |
24th August 2010, 09:59 | #160 | Link | |
You're completely right, these decoders are "normally" not usable with other splitters than their ones and the goal of the loader is to "cheat" them. But currently it exists only loaders for MPC splitter and Haali Splitter and so maybe a specific loader should be developped / updated for LAVFSplitter but I don't know who can do this. These loaders are pretty old now Last edited by Matching_Mole; 24th August 2010 at 10:10. |
