9th September 2010, 12:57 | #2041 | Link |
hi, im wondering if my problem is best placed here as this is the version of ffdshow i use from xvidvideo.ru
ANy idea why any AVI's i have with a DTS track in them stutter at the start of the video and about 60 mins into the film everytime guranteed this is when when using bitsteaming via FFDSHow? I do not get this issue bitstreaming with MS audio decoder or MPC-HC own decoders.. I have FFDSHow audio decoder setup as an external filter in MPC-HC. I do not get this issue with DD 5.1 or HD audio i use a an ATI 5670 via HDMI out to SOny 2400ES reciever |
16th November 2010, 09:00 | #2042 | Link |
I´m trying to bitstream DTS-HD MA to my onkyo 5007 receiver through an HD5450 @ HDMI with MPC-HC but when i enable the bitstream in the ffdshow it simply won´t play the video correctly !
It just stutters and stop playing, but the receiver correctly recognizes the HD stream, by it´s blue "HD" led that turns on. Here´s what happens (this video is from a guy, who have the same proble like me): http://www.youtube.com/watch?v=zDKHt2Zve7g Any thoughts? |
16th November 2010, 10:37 | #2043 | Link |
FWIW, I was only able to get bitstreaming to work to my Onkyo R380 after installing the following.
EDID override for Onkyo (see Tulli's thread on AVSForum.com) (must do Onkyo and current ATI drivers) Realktek audio driver R2.54 (must do) ATI 10.10d You must select ATI HDMI driver as Realtek HDMI doesn't bitstream. |
16th November 2010, 10:54 | #2044 | Link | |
Cheers, Damian Blog - http://www.adigitalhomeblog.com MSS.net blog (contributing editor) - http://www.mediasmartserver.net |
19th November 2010, 15:25 | #2045 | Link | |
AV heretic
19th November 2010, 20:07 | #2047 | Link |
Yes, a lot of issues with DTS(MA) in particular for mkvs that were created with mkvmerge
19th November 2010, 22:36 | #2049 | Link |
There's a bunch of ways to handle it. Solveig, MPC-HC internal splitter, LAVF....all work well. And DTS-HD MA works with Haali *IF* it's created with MakeMKV. But if it's touched by mkvmerge, it breaks. Don't ask me to explain it. Mosu says it's a Haali problem, and given that it's the only splitter that behaves like that I have to believe him.
19th November 2010, 23:03 | #2050 | Link | |
http://www.mediasmartserver.net/2010...kvs-using-mpc/
20th November 2010, 00:03 | #2051 | Link |
I've tried using the mpc internal matroska splitter with pgs subtitles, but it didnt work too well. MPC would basically freeze up for a minute, then the video would play but seeking would be broken.
I've since assumed that you can't use the internal mkv splitter with pgs subtitles, but this is not the case? edit: yea, i was wrong, it had more to do with how the mkv was made, the pgs subtitles were a red herring. Last edited by mindbomb; 21st November 2010 at 19:35. |
9th January 2011, 14:29 | #2052 | Link |
Do we have any news about DTS-MA through analog outputs??
I mean like DTS-HD which is converted to LPCM Uncompressed and delivered to analog outputs..... For those who don't have amplifier with HD capabilities... Thank you... |
9th January 2011, 14:35 | #2053 | Link |
It's not an open spec. Therefore there's no open source decoder for it. I'm unaware of anyone working on one, either.
10th January 2011, 20:53 | #2055 | Link |
I share your sentiment about that info, just for the record. I wish there was an OSS decoder for it, as well. So far the ONLY commercial decoder that works for 7.1 that I know of is ArcSoft's. indeed!
11th January 2011, 00:04 | #2056 | Link | |
But my main problem is with the subs in MPC which i cannot make them work(with the EVR Custom) because of Mpeg Demux of arcsoft... Thanks for your consideration although.... |
15th February 2011, 06:39 | #2057 | Link | |
ATI Catalyst version 10 and above, does support bitstreaming Dolby Digital Plus. Have successfully tested it with Splash Player Pro. |
23rd February 2011, 16:18 | #2058 | Link |
Help with setting up Vista Media Player/Media Center
After much time I have finally managed to bitstream Dolby True HD and DTS MA HD via Xunar HDAV (Old Driver 6.12.8.1764 ) to my Onkyo TSRX606 reciever via MPC-HC (latest version avaivable) !!!. I was so glad that I immediately tried to make it work with VMC/VMP (on Vista 32bit OS), however after many tries I have sadly failed. What I did notice is that somehow MPC-HC force ffdshow-audio to "out" "Dolby AC3 SPDIF" where in regular rendering in graphstudio (or VMP) the "out" keep it as DVD LPCM. Attached pics of the graphs of both mpc-hc and rendering-graphstudio and the screenshots of ffdshow-audio "out" properites. can anyone explain how MPC-HC force it like this ??? Any advice on how to make it work in VMC/VMP ??? Appriacte any help thx Roei. |
6th March 2011, 23:12 | #2059 | Link | |
in "Output format for uncompressed or decoded streams" check only 16bit LPCM I just tested and its connecting like what you wanted in your print screen |
7th March 2011, 10:04 | #2060 | Link |
Thanks for the advise. I also manage to achieve it last night after removing all startup services from "msconfig". (The configuration you stated is the only one that works with MPC-HC and so I have been using only it ever since I started testing) But the problem still exist in Windows Vista Media Player / Media Center (32bit), probably because these lousy apps uses "DirectSound Audio Renderer". I have tried to replace the CLSID of: Defualt DirectSound Device Defualt MidiOut Device Defualt WaveOut Device Digital Output (ASUS Xonar HDAV 1.3 DirectSound: Digital Output (ASUS Xonar HDAV 1.3 to the CLSID of ASAudioRenderer.dll (Arcsoft Renderer) and succedd in the replacement ! (now Gspot shows ASAudioRenderer.dll instead of Quartz.dll in the proper devices) BUT Vista Media Player/Media Center still not sending bitstream to the reciever but only PCM 5.1 with noieses (for Dolby TrueHD) or SPDIF with no sound (for DTS-MA HD). These apps probably (I assume) load Quartz.dll directly instead of relying on the registry information. Do you or anyone know on how to Bitstream in Vista MP/MC BUT on the XONAR card ??? Anyone have an idea on how to force Visat MP/MC to use Arcsoft Audio Renderer rather than default DirectSound Renderer (Assumable Quartz.dll) ???? I have no more ideas ?? any advise is appreciated Thx |
