29th November 2011, 22:41 | #13661 | Link |
Well if ya need me for testing or changing things, ya know where to find me. (though i'll understand if ya don't, probably would need source code access). Now get to work on that output path( jk lol) ^^. Wish i could donate but i don't have the funds. All i can offer for now is my utmost respect & gratitude for this wonderfull piece of freeware
29th November 2011, 23:21 | #13662 | Link | |
30th November 2011, 01:52 | #13665 | Link |
@jdobbs
Both v.39.03 and 39.04 show the same information under the "Stream" tab regarding the original "Planet of the Apes" (1968). The actual primary movie M2TS is 00055.M2TS approximately 27Gb: 1) If BD-25 is selected, the "Stream" tab lists VID00081 through VID00150 2) If BD-9 is selected, the "Stream" tab lists the "full shot" of VID00012 through VID00150 I'll attempt to do a 25Gb FULL DISC backup to see if it's actually limited to only the listed items. Result with v.39.04 as well as with v.39.03 is that it cannot be done! Error message, "Target too small to continue" Last edited by setarip_old; 30th November 2011 at 02:07. |
30th November 2011, 02:04 | #13666 | Link | |
I thought I had that disc, but it doesn't so... I ordered it and it should get here in a few days. I like the original version best anyway ("Damn dirty ape!"). Last edited by jdobbs; 30th November 2011 at 02:06. |
30th November 2011, 03:14 | #13667 | Link | |
@jdobbs
I'm extremely curious to hear what you find out about "Planet of the Apes". BTW - I also tried v.39.03 and 39.04 with DTSExpress turned on and off. Made no difference... Last edited by setarip_old; 1st December 2011 at 00:20. Reason: Correct typo re: Commandments |
30th November 2011, 15:28 | #13669 | Link |
Yeah. I'm still not sure what to do about that one. The only alternative that comes to mind is to scan each section and look for gaps that have to be filled, and that could get really messy. I may have to look at the connection_condition, and sometimes rebuild as multipart -- even in movie-only.
1st December 2011, 14:30 | #13672 | Link |
Remember The Quiet American (from Amazon UK, not US) and how BD-RB dug up something which is not seen on the original? I figured I'd run it through v0.39.04 to see if it performed any differently. The process finished a moment ago and I haven't played it back yet, but I noticed that the output is quite massively oversized. I use a custom size of 24000MB and in 99% of cases output comes to within 200MB of a full BD25, but in this case it came to 24.9GB which is more than a gigabyte too large for BD25.
update: No difference in backup from the earlier version of BD-RB. Select Play Movie in Main menu, and you first get color bars followed by a master tape information screen listing frame rate, aspect ratio, length and audio information, then 20 seconds of black before Miramax logo appears. Original skips directly to Miramax logo even though the m2ts file contains color bars, info screen and the lead-in. It's apparently possible to program the playlist so playback begins not from the start of an m2ts file. BD-RB for some reason does not copy that programming to the backup. Last edited by colinhunt; 1st December 2011 at 14:39. |
1st December 2011, 15:56 | #13674 | Link |
Two pass is the only option that will be fairly accurate for sizing prediction. You did not report your settings, but this method has never been that far off for me!
Every movie will compress differently, so your setting of 24000MB is not leaving much of a safety margin, as you have unfortunately discovered. |
1st December 2011, 16:29 | #13675 | Link | |
As for "The Quiet American" -- since it apparently isn't available on blu-ray in the US (or at least on Amazon)... there really isn't much I can do. I couldn't find either the John Wayne version or the Michael Caine version. Last edited by jdobbs; 1st December 2011 at 16:32. |
1st December 2011, 16:43 | #13676 | Link | |
1st December 2011, 16:54 | #13677 | Link | ||
2nd December 2011, 00:01 | #13678 | Link |
Pes packet len too large ( >100Mb)
Hi
Tried to do the classic disney movie Pinocchio, but I'm getting this error: Pes packet len too large ( >100Mb). Bad stream or invalid codec speciffed. Tried as this fora suggested to rip again, got same error, ripped it again in another drive, same error again. Ripped it with anydvd 6.8.8.0. INF: Code:
[Status] LABEL=PROJ424 VERSION=v0.39.04 (beta) SOURCE_SIZE=29705893527 SOURCE_VIDEO_SIZE=27886374912 TARGET_SIZE=24956108800 REDUCTION=.829673640192075 RESIZE_1080=0 AUDIO_TO_KEEP=dan;eng; KEEP_HD_AUDIO=-1 SUBS_TO_KEEP=all BACKUP_MODE=0 MOVIEONLY_TYPE=0 USE_LAVF=-1 QUICK=0 ENCODE_STEP=4 [00001] AUDIO=10100010100 PGS=1111111111111111111111111 VIDEO2=351078663.865546 V2MBRATE=7000 M2TS_TARGET=22296040572 RATE=25495 Code:
[02:12:38] BD Rebuilder v0.39.04 (beta) - Source: PROJ424 - Input BD size: 27,67 GB - Approximate total content: [01:49:54.879] - Target BD size: 23,24 GB - Windows Version: 6.1 [7601] - Auto Quality: Good (Very Fast), Two Pass - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [02:12:52] PHASE ONE, Encoding - [02:12:52] Processing: VID_00001 (1 of 18) - [02:12:52] Extracting A/V streams [VID_00001] - [02:30:15] Reencoding video [VID_00001] - [02:30:15] Reencoding secondary video [TRK_02] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 126.216 frames - Bitrate: 25.495 Kbs - [02:34:54] Reencoding: VID_00001, Pass 1 of 2 - [03:36:33] Reencoding: VID_00001, Pass 2 of 2 - [04:44:13] Video Encode complete - [04:44:14] Processing audio tracks - Track 4352 (eng): Keeping original audio - Track 4353 (nor): Keeping original audio - Track 4354 (dan): Keeping original audio - Track 4355 (swe): Keeping original audio - Track 4356 (fin): Keeping original audio - Track 4357 (isl): Keeping original audio - Track 4358 (eng): Keeping original audio - Track 4359 (nor): Keeping original audio - Track 4360 (dan): Keeping original audio - Track 4361 (swe): Keeping original audio - Track 4362 (fin): Keeping original audio - [04:44:14] Multiplexing M2TS - Error in attempt to multiplex: MUX_00001.meta - Pes packet len too large ( >100Mb). Bad stream or invalid codec speciffed. [04:45:54] - Failed to build structure, aborted Code:
MUXOPT --no-pcr-on-video-pid --new-audio-pes --blu-ray --vbr --auto-chapters=5 --vbv-len=500 V_MPEG4/ISO/AVC, "D:\BDWORKING\WORKFILES\VID_00001.AVS.264", fps=23.976, insertSEI, contSPS V_MPEG4/ISO/AVC, "D:\BDWORKING\WORKFILES\VID_00001_2.AVS.264", fps=23.976, secondary, insertSEI, contSPS A_DTS, "D:\BDWORKING\WORKFILES\00001.track_4352.DTS", timeshift=-7ms, lang=eng A_AC3, "D:\BDWORKING\WORKFILES\00001.track_4354.AC3", timeshift=-18ms, lang=dan A_AC3, "D:\BDWORKING\WORKFILES\00001.track_4358.AC3", timeshift=-18ms, lang=eng A_AC3, "D:\BDWORKING\WORKFILES\00001.track_4360.AC3", timeshift=-18ms, lang=dan S_HDMV/PGS, "D:\BDWORKING\WORKFILES\00001.track_4608.sup", lang=eng S_HDMV/PGS, "D:\BDWORKING\WORKFILES\00001.track_4609.sup", lang=eng S_HDMV/PGS, "D:\BDWORKING\WORKFILES\00001.track_4610.sup", lang=nor S_HDMV/PGS, "D:\BDWORKING\WORKFILES\00001.track_4611.sup", lang=dan S_HDMV/PGS, "D:\BDWORKING\WORKFILES\00001.track_4612.sup", lang=swe S_HDMV/PGS, "D:\BDWORKING\WORKFILES\00001.track_4613.sup", lang=fin S_HDMV/PGS, "D:\BDWORKING\WORKFILES\00001.track_4614.sup", lang=isl S_HDMV/PGS, "D:\BDWORKING\WORKFILES\00001.track_4615.sup", lang=isl S_HDMV/PGS, "D:\BDWORKING\WORKFILES\00001.track_4616.sup", lang=nor S_HDMV/PGS, "D:\BDWORKING\WORKFILES\00001.track_4617.sup", lang=dan S_HDMV/PGS, "D:\BDWORKING\WORKFILES\00001.track_4618.sup", lang=swe S_HDMV/PGS, "D:\BDWORKING\WORKFILES\00001.track_4619.sup", lang=fin S_HDMV/PGS, "D:\BDWORKING\WORKFILES\00001.track_4620.sup", lang=isl S_HDMV/PGS, "D:\BDWORKING\WORKFILES\00001.track_4621.sup", lang=eng S_HDMV/PGS, "D:\BDWORKING\WORKFILES\00001.track_4622.sup", lang=nor S_HDMV/PGS, "D:\BDWORKING\WORKFILES\00001.track_4623.sup", lang=dan S_HDMV/PGS, "D:\BDWORKING\WORKFILES\00001.track_4624.sup", lang=swe S_HDMV/PGS, "D:\BDWORKING\WORKFILES\00001.track_4625.sup", lang=fin S_HDMV/PGS, "D:\BDWORKING\WORKFILES\00001.track_4626.sup", lang=isl S_HDMV/PGS, "D:\BDWORKING\WORKFILES\00001.track_4627.sup", lang=eng S_HDMV/PGS, "D:\BDWORKING\WORKFILES\00001.track_4628.sup", lang=nor S_HDMV/PGS, "D:\BDWORKING\WORKFILES\00001.track_4629.sup", lang=dan S_HDMV/PGS, "D:\BDWORKING\WORKFILES\00001.track_4630.sup", lang=swe S_HDMV/PGS, "D:\BDWORKING\WORKFILES\00001.track_4631.sup", lang=fin S_HDMV/PGS, "D:\BDWORKING\WORKFILES\00001.track_4632.sup", lang=isl Code:
MUXOPT --no-pcr-on-video-pid --new-audio-pes --demux --vbr --vbv-len=500 V_MPEG4/ISO/AVC, "G:\BDMV\STREAM\00001.m2ts", fps=23.976, track=4113 V_MPEG4/ISO/AVC, "G:\BDMV\STREAM\00001.m2ts", fps=23.976, track=6912 A_DTS, "G:\BDMV\STREAM\00001.m2ts", track=4352, lang=eng A_AC3, "G:\BDMV\STREAM\00001.m2ts", track=4354, lang=dan A_AC3, "G:\BDMV\STREAM\00001.m2ts", track=4358, lang=eng A_AC3, "G:\BDMV\STREAM\00001.m2ts", track=4360, lang=dan S_HDMV/PGS, "G:\BDMV\STREAM\00001.m2ts",fps=23.976, track=4608,lang=eng S_HDMV/PGS, "G:\BDMV\STREAM\00001.m2ts",fps=23.976, track=4609,lang=eng S_HDMV/PGS, "G:\BDMV\STREAM\00001.m2ts",fps=23.976, track=4610,lang=nor S_HDMV/PGS, "G:\BDMV\STREAM\00001.m2ts",fps=23.976, track=4611,lang=dan S_HDMV/PGS, "G:\BDMV\STREAM\00001.m2ts",fps=23.976, track=4612,lang=swe S_HDMV/PGS, "G:\BDMV\STREAM\00001.m2ts",fps=23.976, track=4613,lang=fin S_HDMV/PGS, "G:\BDMV\STREAM\00001.m2ts",fps=23.976, track=4614,lang=isl S_HDMV/PGS, "G:\BDMV\STREAM\00001.m2ts",fps=23.976, track=4615,lang=isl S_HDMV/PGS, "G:\BDMV\STREAM\00001.m2ts",fps=23.976, track=4616,lang=nor S_HDMV/PGS, "G:\BDMV\STREAM\00001.m2ts",fps=23.976, track=4617,lang=dan S_HDMV/PGS, "G:\BDMV\STREAM\00001.m2ts",fps=23.976, track=4618,lang=swe S_HDMV/PGS, "G:\BDMV\STREAM\00001.m2ts",fps=23.976, track=4619,lang=fin S_HDMV/PGS, "G:\BDMV\STREAM\00001.m2ts",fps=23.976, track=4620,lang=isl S_HDMV/PGS, "G:\BDMV\STREAM\00001.m2ts",fps=23.976, track=4621,lang=eng S_HDMV/PGS, "G:\BDMV\STREAM\00001.m2ts",fps=23.976, track=4622,lang=nor S_HDMV/PGS, "G:\BDMV\STREAM\00001.m2ts",fps=23.976, track=4623,lang=dan S_HDMV/PGS, "G:\BDMV\STREAM\00001.m2ts",fps=23.976, track=4624,lang=swe S_HDMV/PGS, "G:\BDMV\STREAM\00001.m2ts",fps=23.976, track=4625,lang=fin S_HDMV/PGS, "G:\BDMV\STREAM\00001.m2ts",fps=23.976, track=4626,lang=isl S_HDMV/PGS, "G:\BDMV\STREAM\00001.m2ts",fps=23.976, track=4627,lang=eng S_HDMV/PGS, "G:\BDMV\STREAM\00001.m2ts",fps=23.976, track=4628,lang=nor S_HDMV/PGS, "G:\BDMV\STREAM\00001.m2ts",fps=23.976, track=4629,lang=dan S_HDMV/PGS, "G:\BDMV\STREAM\00001.m2ts",fps=23.976, track=4630,lang=swe S_HDMV/PGS, "G:\BDMV\STREAM\00001.m2ts",fps=23.976, track=4631,lang=fin S_HDMV/PGS, "G:\BDMV\STREAM\00001.m2ts",fps=23.976, track=4632,lang=isl
Good Luck JJ |
2nd December 2011, 00:16 | #13680 | Link | |
In this particular instance, reduce target size by 1.7 GB to 22250MB using all the other same settings, should end up with a near perfect sizing. FWIW |
