24th September 2012, 10:18 | #14061 | Link | |
Edit, Changed answer : Yes, it does affect the Zoom Player control buttons as they move & react much slower with the new overlay area enabled. I see that most clearly now Last edited by andybkma; 24th September 2012 at 11:22. |
24th September 2012, 10:21 | #14062 | Link |
Still need to know whether it's just the visible video which seems to go away slower, or whether the ZoomPlayer buttons also react slower? Basically I need to know if madVR only updates the video area slower with Overlay enabled, or whether madVR also slows down ZoomPlayer, when closing the file.
24th September 2012, 10:45 | #14063 | Link |
Broadband Junkie
With 0.83.1, occasionally I'll briefly see what I assume is a small madVR waiting(?) window pop-up for a split-second in the background while closing MPC-HC from windowed mode. Is that something you added? It flashes on-screen very quickly, so I've yet to get a good look, but I'm thinking it's a waiting dialog similar to one used for 3DLUT creation?
24th September 2012, 11:20 | #14064 | Link | |
24th September 2012, 11:56 | #14065 | Link | |
Ok, thanks. Please try v0.83.2 (soon out in a couple of minutes). If that's not faster then that might just be the way it is. |
24th September 2012, 12:05 | #14067 | Link |
madVR v0.83.2 released
http://madshi.net/madVR.zip Code:
* some more Overlay improvements |
24th September 2012, 12:17 | #14068 | Link |
Certainly improved. Still get the black screen on shutdown and playback. Stretching isn't updated in realtime thus a picture of the larger image is shown along with the smaller image overlayed on it when resizing and with fullscreen the window is shown before it goes into fullscreen. I wonder how much of this is driver related..
24th September 2012, 12:22 | #14069 | Link |
And i still have problems with a black screen / freeze. when i switch to another video in the folder. I cant seem to get debugging to work. could any1 try and reporduce this. its fairly simple. go into a folder with several files and switch between them from withing the player
24th September 2012, 12:22 | #14070 | Link |
V83.2 looks great on my 2 Monitor Setup (550Ti) with the new Overlay mode. Rock solid queues and when testing resizing it worked fine for me with the only oddity (and I don't care) is that if I position the playback window over the two monitors then the video only shows on one part, the other part is green... but who is going to watch a video like that anyway. Now to kick off the familly to test on the HTPC (IGP 3000).
One thing I don't get is in the options you have two checkboxs to select "enable windowed overlay" and also "enable auto fullscreen exclusive", should this not be a drop down as how can you have both? |
24th September 2012, 12:29 | #14071 | Link |
Seeing that much of the discussion was about gamma recently I was wondering hot to configure it properly. (Can anyone link to a giude?) Or why isn't it enough to change the monitor settings? This area is kind of misty for me.
Somewhat related: How do I set the display to correct/accurate colours. (without some sort of hardware device which I don't have) |
24th September 2012, 12:58 | #14072 | Link | |||
Can you describe this in a bit more detail, please?
So 3 issues? Are we just talking about minor cosmetical issues? Or bigger problems? How does that compare to standard windowed mode? How can I reproduce these problems? Quote:
Overlay covers both windowed and fullscreen playback. Fullscreen exclusive mode works only in fullscreen playback. Personally, I'm using fullscreen exclusive mode for fullscreen playback and Overlay mode if the media player doesn't cover the whole screen. Works just fine in this combination, so both options are independent of each other. |
24th September 2012, 13:01 | #14073 | Link |
Broadband Junkie
I'll see if I can catch a screenshot of it.
It seems like it says something like "Please wait while" Edit: After about 50 tries I got it... It doesn't say anything useful though. Edit2: I'm unable to reproduce it when changing renderers before I switch files as you suggested. Should I make a debug log, or would it not show anything meaningful? From what I can tell, that madVR dialog box doesn't have a chance of appearing until the MPC-HC window has completely disappeared after being closed. Last edited by cyberbeing; 24th September 2012 at 13:31. |
24th September 2012, 13:21 | #14074 | Link |
Software Developer
Here's some issues myself and the team encountered with v0.83.2:
Tried the new overlay mode on an NVIDIA GT520, checked debugging mode, overlay is a "+". 1. Resizing is much smoother compared to 0.83.1. 2. Enabling overlay mode when a video is playing resulted in a black screen until the video was reloaded (and graph re-created). 3. When switch the video from fullscreen on monitor 2 to windowed on monitor 1 (both FSE and Overlay checkboxes enabled), playback pauses. I think some red text appears for a split second before the image returns with the video paused. 4. It takes longer to clear the graph (About 1 second longer than v0.82.5), which appears as a black screen between track or just a black screen before ZP is closed. I didn't see any affect on the GUI responsiveness compared to 0.82.5, but I have only tested for a few minutes so far. |
24th September 2012, 13:22 | #14075 | Link |
My entire screen goes black, doesn't do that on my HD4000 though only the HD3000. Will need more testing (I'll look into it later)
The other issues (resizing (slow refresh), moving whilst paused and going fullscreen) are here in these videos. Screen capturing wouldn't pick up any of them. The fullscreen issue is a minor nitpick (small blank window at the top left hand corner before maximize) The videos were done on the HD4000. Yup. Last edited by ryrynz; 24th September 2012 at 13:24. |
24th September 2012, 13:39 | #14076 | Link |
[QUOTE=madshi;That works just fine here. Are you using NVidia or Intel? You sure you updated to v0.83.2?[/QUOTE]
Yes im sure im using 83.2. it has worked flawlessly for many months untill now where i get a black screen and hang every time i switch video. using nvidia gt570 card. any chance for a testbuild with the old code maybe as it was before with the old shutdown behaviou maybe? |
24th September 2012, 13:59 | #14077 | Link |
Broadband Junkie
@Budtz
If it only happens with fullscreen exclusive mode, it's probably the same issue I reported. Freeze with black screen 100% of the time when switching or reloading videos in fullscreen exclusive mode. Last edited by cyberbeing; 24th September 2012 at 14:08. |
24th September 2012, 14:16 | #14080 | Link | ||||||
http://madshi.net/madVRpreventClose.rar You'll have to manually terminate the media player with the task manager with this build. Maybe this build allows the exception report to be properly created? Quote:
Do you have Aero enabled or disabled? I've yet to try with Aero on. Maybe that's the difference... Quote:
Unfortunately I can't go back to the previous shutdown behaviour. Due to the changes I did to support multiple madVR instances at the same time, when I go back to the old behaviour, there would be an instant crash now. The old behaviour was really bad, it was pure luck that it worked at all. |
