8th May 2008, 21:11 | #961 | Link |
Mr. Sandman
most of them will be trashed in the next megui version.
the new profiles will be hardware-oriented and with clearer names. HQ-Insane will still be around (with a new name)... and it will be REALLY INSANE (a torture test for your CPU and your patience!)... and obviously not compatble with HW devices (it will be stated in the profile name).
MPEG-4 ASP Custom Matrices: EQM V1(old), EQM AutoGK Sharpmatrix (aka EQM V2), EQM V3HR (updated 01/10/2004), EQM V3LR, EQM V3ULR (updated 04/02/2005), EQM V3UHR (updated 17/12/2004) and EQM V3EHR (updated 05/10/2004) Info about my ASP matrices. MPEG-4 AVC Custom Matrices: EQM AVC-HR Info about my AVC matrices My x264 builds. Mooo!!! Last edited by Sharktooth; 8th May 2008 at 21:14. |
8th May 2008, 22:10 | #962 | Link | |
Forum Member
9th May 2008, 13:50 | #963 | Link |
Mr. Sandman
actually, not too far. i and the other devs just need some time to code.
9th May 2008, 19:40 | #964 | Link | |
Forum Member
Alright, I'll wait for the next version before I start full production on my videos. Sounds like it offers some improvements. Why is it that 4:2:2 is not supported with x264? I guess it is how the codec was designed, but it unfortunate to have sacrifice 1/6 of the raw color levels. I mean, you can see a good bit of color difference in these two samples. Is there anyway to retain the true color levels? Also, what inloop filter setting would you suggest for 480p/720p console game-play (3d rendered graphics - fast motion)? I'm using HQ-Slowest as a base (would HQ-Insane be worth the extra encode time?). Last, can you ever use too high of a bit-rate? Is 7,500 for 480p/720p too much or is more always better if you can deal with the extra file size? Demo 720p Capture - 100MB Thanks Here is a another console game demo using HQ-Slowest as a base but at 10,000 bit rate. 137MB Download Last edited by Seraphic-; 21st May 2008 at 17:54. |
11th May 2008, 22:35 | #966 | Link |
Profile for video coaching dv archive
Hi all. What do you think of this as a profile for video coaching dv archiving? I need it to be clear as possible and allow smooth frame stepping forwards and backwards preferably with smooth progress bar mouse dragging while paused.
Freel free to hack it up. I'm not an expert with x264 profiles. Thanks in advance |
11th May 2008, 23:19 | #967 | Link |
Really!? Which should I use, how can I know which settings I cant use, like number of b-frames or number of ref frames, m.e. range (I'm using 16), subpel ref. and everything? Could you help me pls? I want to run my files after conversion on hware. Thank you in advance, thx God I didnt delete the original files
"After all, Love remains, burned into our memories. We all search for love. But some of us, after we found it, wish we hadn't." |
12th May 2008, 00:52 | #968 | Link |
HQ-DXVA profile
12th May 2008, 18:53 | #969 | Link |
Thank you! DXVA-SD-HQ has the exact same settings I used before! On this profile, b-frames number is 3 and subpel ref is 6. Can't these numbers be raised? Like 16 b-frames, subpel 7 or 16 ref frames (at least 10 for anime content)??? I presume 16 ref frames and subpel 7 are dumb then? But what about 16 b-frames? Cause Shark said is better
Btw, what about anime content? Should I use the same profile? P.S.: At least my previous encodings will play, I was worried Edit.: What about fast p-skip, can it be disabled, or shouldn't I disable this at all?
"After all, Love remains, burned into our memories. We all search for love. But some of us, after we found it, wish we hadn't." Last edited by Weltall; 12th May 2008 at 19:18. |
13th May 2008, 00:40 | #970 | Link |
Don't touch ref frames! Unless you want to break compatibility with DXVA! subpel 7 is very slow so it is up to you.
13th May 2008, 02:49 | #971 | Link |
Mr. Sandman
b-frames and ref-frames influence the hardware compatibility. so if you care about it, dont touch them.
13th May 2008, 07:32 | #972 | Link |
Can I use DXVA-SD-HQ profile with constant quality mode?
I have a lot short-vob files like music video, (idol)event tour, .. So I don't want to specific file size. CQ-ASP_Q2_eq(crf) is great but I need more compatibility. Thanks |
13th May 2008, 07:43 | #973 | Link | |
x264 developer
x264 doesn't support other color spaces because it would take a lot of code to do so and ffmpeg (AFAIK) doesn't support it either. |
13th May 2008, 09:54 | #974 | Link |
Ok, then I'll stick with 3 b-frames and 8 ref frames for both movie/tv show and anime content.
What about fast p-skip, shoud it be always enabled? Not using it would give me hw incompatibility?
13th May 2008, 14:26 | #976 | Link | |
too much lurking
How are ref frames not only an analysis option? Or maybe I should say, how do they have any bearing on playback? I thought that they were only for the encoder to seek backwards and forwards during encoding? |
13th May 2008, 16:02 | #977 | Link |
Old computers? Aren't we talking devices, such as hand-helds, PDA's, mobiles here too?
PC specs for bug reports: Intel Core i7-4790K @4Ghz Win10(Linux VM) PCI express NVIDIA RTX 2060 SUPER graphics card http://twitter.com/cwebdesign |
13th May 2008, 17:07 | #978 | Link |
too much lurking
Yes. And I address that at the end of the paragraph. But, several of the preceding posts were discussing DXVA in particular and since this topic has personal interest for me I chose to pontificate on it.
14th May 2008, 15:54 | #980 | Link | |
MPC-HC Project Manager
DXVA is being used a lot in posts, this does not mean the posts are only about pc-acceleration, the DXVA settings guarantee playback on all hardware based devices. the fact that you can select out of spec settings for encoding a video does not mean you should, as software decoders become more and more true to the standards so does the need for videos encoded with a standard. According to a lot of tests, going beyond the limits of hardware compatibibily have little to no effect on the percieved quality of the resulting file (with the exception of ref frames with animated low detail full hd content) Now anyone that want's to use different setting can always manually do so, these profiles are not hardcoded into x264 with no way around them. finally, even you're q6600 can have some minor frame-drops when it comes to high bitrate encodes that are on the edge of hardware compatibility (especially original blu-ray discs that add the overhead of decrypting), that said there are no discs out there yet that are unwatchable on a system like your's personally i am one of those persons with a slow pc, and a dxva videocard, i eventually intend to buy a standalone player so personally i have 2 reasons to use DXVA compatible settings. As x264 is going to be the standard for a very long time there is a big chance that anyone with a fast enough pc will one day come eye to eye with a hardware decoder, it's for those moments that you'll be glad you encoded with DXVA settings. Last edited by tetsuo55; 14th May 2008 at 16:02. |
