Old 2nd December 2019, 01:50   #781  |  Link
hntc255
hntc255's Avatar
AMD HDR requires 10-bit output from madVR (D3D11). Did you do that?
I tried the color format ycbcr 422 10 bit / 12bit , 420 10bit / 12bit in AMD driver.
And set "the native display bitdepth is '10bit or higher' "
As I say , it works fine after refresh the HDMI , really strange.
hntc255 is offline   Reply With Quote
Old 2nd December 2019, 06:15   #782  |  Link
Klaus1189
Other devices do work fine? I can also think of a reset of the TV, because I had strange things occuring on different manufactures after software update of the TV.
Old 3rd December 2019, 18:56   #783  |  Link
Klaus1189
AMD released new Radeon Driver 19.12.1
Old 4th December 2019, 12:35   #784  |  Link
Grimsdyke
Does anyone maybe know why the exe-installer of the intel-vga-driver does not work anymore on my system ?? It seem to open but then nothing happens.
So I have to use the zip-version, un-pack, and start the installer within. This works without any problems.
Is Win10-64bit security blocking the normal exe ? But why ? Any ideas ? Thx
Grimsdyke is offline   Reply With Quote
Old 4th December 2019, 13:41   #785  |  Link
Klaus1189
Perhaps corrupted file, check the size of exactly your downloaded file and download another copy again, compare the size of these two. It can happen from time to time, when something went wrong in the data transmission.
Old 4th December 2019, 18:43   #786  |  Link
ced007
I'm not sure to understand correctly the Nvidia table in the first post, I have a 1060 GTX with latest drivers. Is the 398.11 driver the latest version with correct HDR passthrough? Do I need to switch back to it?
Thanks in advance
ced007 is offline   Reply With Quote
Old 4th December 2019, 19:46   #787  |  Link
Klaus1189
Hi ced007, it depends:
If you want to use HDR passthrough for Nvidia and want correct metadata you need either 398.11 from 2018-06-05 if you need/want to be able to use 3D or, if you don't need 3D, you can use 430.39 from 2019-04-23 or any newer version than that, preferred the newest for now, since there are no issues, at least I am I am aware of. RTX owners have no choice if they want both 3D and correct metadata, since there is no driver for RTX cards which can do both
Old 4th December 2019, 20:30   #788  |  Link
ced007
Thank you Klaus1189, it helps a lot. I don't need 3D so I stay with the latest version 441.41.
Old 5th December 2019, 11:08   #789  |  Link
Warner306
You might consider adding this link to the first post. This is a software fix that adds back 3D Vision support to newer Nvidia drivers. I have not tested it myself, but someone at AVS Forums says it works:
http://helixmod.blogspot.com/2017/05...x-manager.html
Someone here would have to test it.
Old 5th December 2019, 11:28   #790  |  Link
Klaus1189
I added it, but I had to shorten some things because I used to many characters
See here
Old 5th December 2019, 17:13   #791  |  Link
brazen1
I think that software is for gaming 3D only. 416.81 is still a good choice for 3D and HDR imo.
W10 1909 960-4GB RGB 4:4:4 @Matched Refresh Rates 8,10,12bit
KODI MPC-HC/BE PDVD19 DVDFab 3 & 5 PotPlayer
65JS8500 UHD HDR 3D
Old 5th December 2019, 17:33   #792  |  Link
i already tested the helixmod a couple of months after nvidia removed 3D.
it doesn't work with madVR it only trigger 3d on my screen but doesn't send it and the OS doesn't know about 3D.
it could be used to add 3d back into madVR because all games work but that's it for now.
Old 11th December 2019, 00:38   #793  |  Link
SamuriHL
SamuriHL's Avatar
New nVidia driver. Doesn't appear to impact HTPC....let's hope it doesn't break anything. LOL
https://www.neowin.net/news/nvidia-4...-optimizations
HTPC: Windows 10, I9 9900k, RTX 2070 Founder's Edition, Pioneer Elite VSX-LX303, LG C8 65" OLED
Old 11th December 2019, 01:04   #794  |  Link
the new amd driver has a great start: https://abload.de/img/amdriverivkfy.png
that's with disabled overlay.
Old 11th December 2019, 01:24   #795  |  Link
SamuriHL
SamuriHL's Avatar
I don't think that word means what they think it means. LMAO
Old 11th December 2019, 13:30   #796  |  Link
mclingo
Klaus1189, is the issue with raised blacks in EVR and incorrect colour space on 5700s worth a mention on your driver page?
OLED 4k HDR EF950-YAM RX-V685-WIN10 444 RGB 60hz-AMD RX 580 19.12.2 KODI DS - MAD/LAV 92.17/0.74.1 - 3D MVC / FSE:On / MADVR 10bit
Old 11th December 2019, 17:37   #797  |  Link
Klaus1189
I thought of that already, but since this thread is meant for use with madVR and if you use either madVR or also MPC Video Renderer with D3D11 you don't have this issue. But I can add it if you wish. Just let me know.
Old 11th December 2019, 18:17   #798  |  Link
mclingo
the EVR is definately affecting all 5700 cards so I'd deinately put that one down. The MADVR issue, even though we are not 100% sure it affects all cards, only one person has come back and said it isnt affecting them and they havent yet given us all their hardware details,I think right now we should assume its all 5700 cards.
- All 5700 series cards have elevated blacks withe EVR renderer: Workaround - use MPC or MADVR renderer.
- All NAVI based cards are outputting an incorrect colour space via the AMD HDR API, colours are greatly unsaturated - workaround; use a filter to correct or use Windows HDR
its your thread though mate, its up to you
Old 11th December 2019, 19:52   #799  |  Link
Klaus1189
Can you give me some info for the affected driver versions? Can you also give me a link for the demo footage video where the sidebyside comparison was made? I want to take a look at the video.
Old 11th December 2019, 20:29   #800  |  Link
mclingo
Hi, this is a new card, as far as I know both issues affect all driver versions. Not sure which footage you are referring to, I took pictures and mocked one up to try and show what the saturatiuon issue looks like. DMU and ALEXTRAL seem to have more detailed info on the HDR issue.
