Old 7th March 2010, 14:37   #1  |  Link
kr0k0f4nt
DirectShow playback of VC-1 (WVC1) with Haali and ffdshow doesn't work?
Hey Guys,
I am trying to encode some HD content (it's not copy protected) to XviD. I am using therefore usually an AviSynth Script and open that in VirtualDub. So that's no problem here, works fine with all MPEG2 and .h264 sutff.
But I've got a couple of content now that is encoded in VC-1, which fails to get rendered on DirectShow.
I also tracked it down, but I wonder that the solution is here. Let me try to explain.
I've the latest fddshow installed (2010-03-01) and the latest Haali (2009-12-19). I've installed fddshow and picked the WMV9 to decode VC-1. Haali is installed default, with MPEG-TS checkbox set.
Then I am using Media Player Class Home Cinema AND have the internal Filter for MPEG-PS/TS/PVA not enabled the Playback fails. It takes a while to come and then there is only the first frame, but neither in the correct aspect ratio nor does it play. It's also just a part of the overal image.
If I enabled the Filter for MPEG-PS/TS/PVA the video starts right away and works fine. So the Problem seem so be Haalis PS Splitter here, or I am wrong here?
I also ran MatroskaDiag on that File that comes up with that, while having the Haali PS-Splitter checkbox set on during the Setup:
Matroska file info : J:\BDMV\STREAM\00000.m2ts
File size : 20.35 GB
TEbmlReader.ReaderHeader : EBML header ID not found (found 0x1468E800)
DirectShow RenderFile check :
Matroska Splitter : Gabest's Matroska Splitter
   - Installed : no
   - Can be created : no
Matroska Splitter : Haali's Matroska Splitter
   - Installed : no
RenderFile with DirectShow : Unbekannter Fehler (0x80004005)
DirectShow detailed rendering :
0> MyRenderFile : J:\BDMV\STREAM\00000.m2ts
0> Creation of GraphBuilder : OK
0> Creation of FilterMapper2 : OK
16> Adding graph to ROT : OK
7738> Creation of source filter : Unbekannter Fehler (0x80004005)
Btw: Unbekannter Fehler = Unknow Error
What's pretty weired for me is the fact that it thinks that Haali isn't installed? But it's installed for sure, as I can open up any h264 AVC stuff easily on DirectShow.
Does anyone have an idea? I would appriciate any help here
kr0k0f4nt is offline   Reply With Quote
Old 7th March 2010, 15:56   #2  |  Link
bigotti5
Spielberger
bigotti5's Avatar
Latest Haali does not support VC1 - use an older one e.g this one
bigotti5 is offline   Reply With Quote
Old 7th March 2010, 16:44   #3  |  Link
kr0k0f4nt
Okay that did the trick - that really was an easy one
I really wonder why it says nothing about this in the Change Log? But thanks for solving my Problem here!
Old 7th March 2010, 20:04   #4  |  Link
Snowknight26
Because its a bug.. and no one mentions bugs in changelogs.
Snowknight26 is offline   Reply With Quote
Old 2nd April 2010, 13:03   #5  |  Link
kr0k0f4nt
The latest Version (27/03/2010) of Haali still seems to have this Bug
directshow, haali, vc-1, wvc1
