Old 5th November 2015, 11:52   #34061  |  Link
aufkrawall
Postprocessing isn't evil by definition. Hardly anyone would suggest to use Jinc or super-xbr without AR filter. In fact, afair it is always enabled for super-xbr in the image doubling settings, since it rings so terribly.
Old 5th November 2015, 21:39   #34062  |  Link
Warner306
Originally Posted by JarrettH View Post
I can't see wanting to use additional post processing on top of a sharp scaler. A picture should look effortless.
SuperRes softens super-xbr. So the picture is not oversharpened. It is actually improved.
Old 5th November 2015, 22:18   #34063  |  Link
Thunderbolt8
but if its really improved from a rather objective point of view then it would be a default setting, wouldnt it?
Laptop Acer Aspire V3-772g: i7-4202MQ, 8GB Ram, NVIDIA GTX 760M (+ Intel HD 4600), Windows 8.1 x64, madVR (x64), MPC-HC (x64), LAV Filter (x64), XySubfilter (x64)
Old 5th November 2015, 22:34   #34064  |  Link
aufkrawall
As I already said, SuperRes doesn't like ringing.
I wouldn't use SuperRes with super-xbr. Instead I'd use super-xbr with a low sharpness setting + Adaptive Sharpen, then ringing is far less of a problem.
NNEDI3 64 quadrupling + SR (strength 3, sharpness 1, ll off):
super-xbr 100 + SR:
Jinc AR + SR:
super-xbr simply looks terrible in this example. I'd even prefer Jinc, as it has less ringing problems.
NNEDI3 + SuperRes is best by far.
Old 5th November 2015, 22:56   #34065  |  Link
Warner306
Your findings back-up the previous test images. super-xbr has more ringing but less aliasing. That seems pretty clear. SuperRes was said to have the most problems with aliasing, which is why it was recommended to be used with NNEDI3 or super-xbr.
The simple nature of animation makes it unappealing as a test for image upscaling. Faces and detailed backgrounds with many surfaces show the differences in detail far better. But that is just my opinion.
I still like super-xbr. I don't think there is a right or wrong answer. The desire to have a sharp vs soft picture would have a lot to do with this preference.
Old 5th November 2015, 23:12   #34066  |  Link
har3inger
As far as I've seen, super-XBR doesn't really add much ringing from upscaling, but rather preserves source ringing a lot more than nnedi3 does. Also, in terms of sharpness, SuperXBR 75 is about the same as jinc3, so those two would be a fairer comparison for how badly each rings.
A bigger problem seems to be the way small details with high contrast (pupils in eyes) get fairly messed up when sharpness is set lower than 2 for superres. In the blonde's eyeballs, the pupils get extra white dots in them that shouldn't be there. If it's anything like the images I've been testing, the problem fixes itself at sharpness 2 and 3 (but 3 tends to be pretty aliased).
For clean sources, SuperXBR + SuperRes for 720p->1080p (CR downscale) has no ringing problems in my experience. I don't think it's fair to compare it to nnedi3, which is a lot better at cleaning up source ringing artifacts compared to any other madvr scaler.
har3inger is offline   Reply With Quote
Old 5th November 2015, 23:16   #34067  |  Link
Warner306
At 720p -> 1080p, I notice the image appears "fatter" when Jinc is used with SuperRes as opposed to super-xbr + SuperRes. I assuming this difference comes down to aliasing on edges.
Old 5th November 2015, 23:25   #34068  |  Link
Ver Greeneyes
That's pretty interesting. I've been wondering what settings for the new SuperRes would be good - I figured Sharpness = 1 was just a reasonable default, but it sounds like that's not the case (I didn't try resetting my settings to find out what the defaults were).
Old 5th November 2015, 23:42   #34069  |  Link
aufkrawall
I suspect this is a huge misunderstanding in general regarding SuperRes.
SuperRes reintroduces aliasing of the source when it has been filtered away by upscaling (NNEDI3 has a very strong AA effect).
I haven't seen a single case where SuperRes really introduces aliasing which isn't supposed to exist.
There have been ground truth comparisons here which showed aliasing problems with SuperRes, yes. But the aliasing was probably introduced by downscaling the image with linear light first.
This is e.g. the case with the lighttower example of leeperry. When you downscale it in gamma light, there is no aliasing visible when upscaling it again and applying SuperRes.
We btw. also still have the radius option in madVR, a higher value will lead to less aliasing (but probably also less sharpness).
In fact, SuperRes can even repair aliasing introduced by upscaler. But this functionality is not endless, so an upscaling algorithm with fewest aliasing is still preferred (which is again NNEDI3 with enough neurons).
I have to disagree. (Mostly) clean lines show the characteristics of an algorithm very well, which makes it easy to spot weaknesses.
Of course this alone is not comprehensive enough to judge finally, but I still find it very important.
I'd rather call it boost instead of preserve.
But on the other hand it's true that NNEDI3 filters away ringing, yes. SuperRes reintroduces some of it, since it's like correcting an upscaling error.
It was meant in context of SuperRes fixing upscaling errors.
I think it just doesn't work well with super-xbr, as even tiny amounts of ringing can get nasty with super-xbr + SR (even with a sharpness option of 1, default is 2 which boosts ringing a lot more).
I think it's a problem of the source, I wouldn't put too much meaning into it.
Old 6th November 2015, 04:08   #34070  |  Link
x7007
Does anyone have issue with Potplayer and the new drivers nvidia 358.87 ? I have prender always at 0 ( GPU 95% with madvr and EVR , non CUVID or DXVA Back-to)
EDIT Never mind, I think something with Asus GPU Tweak 2 messed thing up, after restart everything ok including the overclock
x7007 is offline   Reply With Quote
Old 6th November 2015, 04:15   #34071  |  Link
JarrettH
I'd like to see more film examples too. Are there not any movie watchers here?
From Cube (1997)
Original at 100%
https://c2.staticflickr.com/6/5743/2...133b4b6a_o.png
xbr75 doubling, then Catmull + LL+AR downscaling
https://c1.staticflickr.com/1/746/22...6e5980ff_o.png
xbr100 doubling, then Catmull + LL+AR downscaling
https://c1.staticflickr.com/1/627/22...845b12c0_o.png
No upscaling refinement, sorry.
I think 100 is more faithful, but a tad too sharp.
Old 6th November 2015, 06:58   #34072  |  Link
Warner306
From Cube (1997)
Original at 100%
The ringing is much harder to detect in that image. If anything, the 100 seems to mask the ringing better than 75 due the extra sharpness.
But the image is definitely not offensive. It is very sharp, though, to be certain.
Old 6th November 2015, 19:31   #34073  |  Link
seiyafan
For 1080 to 1440, has there any effort been done in comparing one step upscaling vs. doubling then downscaling? (Jinc vs. xbr/NNEDI3 then Catmull)
seiyafan is offline   Reply With Quote
Old 6th November 2015, 21:17   #34074  |  Link
har3inger
I did some comparisons with SuperRes and nnedi3 (32 neuron) to demonstrate the problem with Sharpness 1. All of these are also radius 0.66 and linear light unless otherwise indicated.
No SR (alignment off because nnedi3 introduces pixel shift) : http://i.imgur.com/wS8TZUw.png
Str 4 Sharp 1: http://i.imgur.com/q9Q0elg.png
Str 4 Sharp 2: http://i.imgur.com/Q9IP9JU.png
Str 4 Sharp 3: http://i.imgur.com/pQdX4EW.png
Str 4 Sharp 4: http://i.imgur.com/86MVCvM.png
Str 4 Sharp 1 Radius 0.33: http://i.imgur.com/zCoqUCg.png
Str 4 Sharp 1 Radius 0.33 (extremely obvious bugs on the old man): http://i.imgur.com/W2xMJJF.png
For all of these, the easiest area to spot the enhancements/bugs is around the white hat.
IMO, Sharp 2 is closest to the original in terms of edge enhancement. Sharp 1 looks broken. Sharp 3 and 4 are similar sharpness, and enhance the ringing beyond what's in the source.
Old 6th November 2015, 23:58   #34075  |  Link
bozokaydin
Anyone can tell me what is the best setup for 1080p content? For 1080p content on 1080p screen does chroma superres work without upscaling? And i am a bit confused what is the difference in chroma superres and upscaling refinement superres?
HTPC:
Windows 8 64bit
Nvdia GTX 690
i7 3570k
Corsair H100 Water Cooling
Corsair 128 Gb Force SSD x 2 Raid 0+ Samsung 2 TBx 2 Hard Disc Raid 0
Creative Titanium HD
bozokaydin is offline   Reply With Quote
Old 7th November 2015, 01:05   #34076  |  Link
Warner306
There will be little to no difference unless you are using SuperRes. SuperRes is more effective when used with Image Doubling.
Old 7th November 2015, 12:36   #34077  |  Link
aufkrawall
I've never seen a real difference between Jinc AR or image doubling for 1080p -> WQHD, neither with SuperRes. I'm watching every 1080p video upscaled to WQHD.
Jinc AR + SR (strength 3, sharpness 2, LL off):
superxbr 100 + SR:
Old 7th November 2015, 14:13   #34078  |  Link
madshi
Originally Posted by aufkrawall View Post
But are you sure that you put the right Adaptive Sharpen version into it?
It still gives me a very noticeable brightness increase with a strength of 0.5, which is not the case with the shaders linked by bacondither.
Are you sure you used the same strength in both? I've double checked and compared and if I setup the same strength, I get a similar increase in brightness in madVR's version and the latest experimental shaders. Please note that madVR runs the shaders in TV levels instead of PC levels, which means you may have to fine tune strength a bit to get the same effect. I think I used 1.0 strength in the shaders, and 0.9 in madVR, and got pretty much identical results.
The brightness increase totally vanishes if I run AdaptiveSharpen in linear light. So my impression is that the fix implemented by bacondither is not sufficient yet.
If you have a different opinion then please post comparison screenshots where using the shader HLSL files shows less brightness increase than madVR's implementation, although you've carefully matched sharpeness strength.
Originally Posted by FreeFall View Post
Thanks madshi and nevcairiel, subtitle positioning is working well. The keep black bars visible if they contain subtitles option has stopped working in newer builds, none of the settings are working.
Are you sure? It seems to work fine here. If you can reproduce it, please send me a small sample of the video with which I can reproduce the problem on my PC, and tell me which exact checkboxes are set in the "zoom control" page.
Originally Posted by Arm3nian View Post
I've watched LOTR 1000 times, but now I can watch it 1000 more times upside down! Sweet
Haha, yes! Will you lie upside down when watching it, though?
Would be scaling, can't duplicate the issue with previous or latest build.
Ok, if you can't duplicate then let's ignore it for now.
Originally Posted by KoD View Post
A feature request, if possible: some keyboard shortcut to switch the display refresh rate.
Maybe later. There's no easy way to implement it now.
Originally Posted by Ver Greeneyes View Post
Is there a keyboard shortcut to toggle black bar detection or cropping? I don't need black bar detection that often, and there will probably always be videos on which it doesn't quite work, but I'd like to be able to enable it easily when the black bars are obvious and consistent.
Wouldn't it make more sense to try and perfect the detection so that it "always" works? Then you wouldn't ever have to switch it off. I don't really like if algos are unstable, so that you have to manually enable/disable them. I want madVR you to be able to configure madVR once and then never touch the settings again.
I would welcome a proper implementation of frame duration display [more than ...]
Such an implementation already exists: Switch your display to 60Hz and enable smooth motion FRC.
Originally Posted by SweetLow View Post
Umm... If this is my wish realization - it's work not as expected. In my case this variable always equal to the name of first device in devices list, not actual device of player window
Yes, that was meant to be your wish realization. Oh, will have to double check that.
Originally Posted by pankov View Post
is it intentional that the hidden option to show the black bar detection using the ShowBlackBars empty file doesn't actually work if the "crop black bars" option is not enabled?
No, it's supposed to always work. Will check that.
I'd like also to ask a question about the new rotation feature.
Is it intentional that the subtitles (both external and internal ones) are rotated together with the picture ... and moved almost to the center of the image?
Honestly, do you have any videos which need rotation *and* have subtitles?? I thought about subtitles, but it's pretty hard to implement correctly, and my thinking was that videos that need rotation are very unlikely to have subtitles. So I simply didn't spend any time on working on rotated subtitles. If you have legit files which need rotation and have subtitles, please let me know where they come from and why they are rotated. Then I'll think about whether it's worth spending time on...
Originally Posted by AngelGraves13 View Post
Fair enough. I'd settle a simple deblocker that has 3 settings like the debanding.
Unfortunately there is no good deblocker available anywhere that I've seen. So I'd have to invest one myself. Maybe some day, but not soon.
Originally Posted by kolak View Post
Unfortunately you are correct- many authoring studios don't use dithering at all have no clue what to do with it
Been in few big places and it was very disappointing.
Hope you're spreading the word where you can...
Originally Posted by markanini View Post
Bug report: Once the interlaced flag is activated midstream MadVR sees it as interlaced for the remainder of the duration even if the stream switches back to reporting progressive.
Does EVR behave differently? Switching DXVA deinterlacing on/off is a complicated thing in madVR. Doing it all the time when the video switches those flags on/off could introduce a small stutter every time that happens. So I'm not sure if that's a good idea. How often does your stream switch back and forth?
Originally Posted by mcn View Post
I'm attaching some screenshots regarding the "issue" with subtitles positioning.
The first screenshot is of the original video, 1916x1076, without black bars.
The other two screenshots are taken with the video shown in full screen at 1920x1200, where black bars are added.
Embedded subtitles are partially shown in the bottom black bar, while external ones aren't.
Both should be definitely rendered by XySubFilter since modifying the timing through its properties window affects both subs.
Hmmm... And both embedded and external ones are SRT? Can you maybe make a small sample of that video available to me, with the external subtitle file? (You can use PM for that.)
super-xbr has very big problems with ringing, you have to sacrifice a lot of sharpness to get to an acceptable ringing level if the source isn't optimal.
The last part is very important: "if the source isn't optimal". It's true that super-xbr "enhances" ringing artifacts that are already in the source, while NNEDI3 instead reduces them. That's one of the very nice things about NNEDI3. super-xbr should not introduce new ringing artifacts if the source is clean. But already existing ringing artifacts are enhanced the same way valid lines and details are enhanced. I'm not sure if it's fair to fault super-xbr for that.
Today many Blu-Rays are relatively clean with only low amount of ringing. I think for those super-xbr should work pretty well. If you are watching a lot of low quality content with strong ringing in it, then obviously NNEDI3 is the much better choice for that.
I've read madshi prefers super-xbr to Jinc. And past posts have found NNEDI3 and super-xbr are the best algorithms to use with SuperRes because they are sharper.
Yes, that's true. I still like super-xbr quite a lot, especially for its quality-to-performance ratio. But aufkrawall has a valid point saying that super-xbr might not work so well for sources that have a lot of hard coded ringing in them. Maybe that will change if at some point I manage to find a good source deringing algorithm. Don't have one at this point, though.
sharpness values over 75 can introduce a lot of artifacts.
I wouldn't say that. Using sharpness values over 75 should not introduce artifacts. But it might enhance already existing artifacts. Which is a quite important difference.
If every user had an NVidia Titan GPU then the default settings would be different to what they are now.
Agreed.
With this test image (which you found, IIRC), SuperRes does introduce a certain amount of aliasing:
http://madshi.net/SuperResTest.png
I've been using this test image to do some more SuperRes related tests. Here are my conclusions:
1) Linear light vs gamma light: If you downscale the image in LL, and then use SuperRes with GL, the lines get too thin. If you downscale the image in GL, and then use SuperRes with LL, the lines get too thick. The only way to reproduce the proper line thickness is to use either GL or LL for both downscaling and SuperRes. Which means that unfortunately I will probably not be able to remove the "linear light" SuperRes option, because the optimal value will not be the same for all sources.
2) Using linear light, different SuperRes sharpness values produce different artifacts. It seems that a sharpness value of 2 produces the least amount of artifacts.
3) A radius of 0.66 produces some aliasing. A radius of 1.00 means SuperRes adds no aliasing, but SuperRes also loses some of its effectiveness/sharpness. Values between 0.66 and 1.00 show some aliasing and some sharpness loss. I'm not sure which radius I should use. Maybe a compromise would be 0.80 or something like that?
Thanks! These results match my own tests I've done today (see above for a summary of my test results).
I'm wondering whether I should remove the SuperRes sharpness setting again and hard code it to 2, since it seems to be the one which produces the most faithful reconstruction of the "ground truth"?
Old 7th November 2015, 14:14   #34079  |  Link
Murmeltier
What are the advantages of "dithering in linear light"? Or more generally: What is linear light good for when it comes to dithering? What happens to the picture if I choose "don't dither in linear light" under "trade quality for performance"?
Murmeltier is offline   Reply With Quote
Old 7th November 2015, 14:22   #34080  |  Link
madshi
In "devices -> your display -> properties" set your display to 3bit. Then compare dithering with linear light on/off, and you will see the difference.
