Old 25th October 2010, 09:30   #5821  |  Link
Lyle_JP
Unreasonable User
Lyle_JP's Avatar
Originally Posted by zmaster View Post
swainjena,
See the documentation for AviSynth. Look for information about the function AssumeFPS()/ChangeFPS()/ConvertFPS().
Or he could just encode to raw and set framerate in the muxer.
Lyle_JP is offline   Reply With Quote
Old 25th October 2010, 18:40   #5822  |  Link
blah123
I've got interlaced AVC/h.264 in TS. What i should use instead of DGAVCIndex to demux this file? DAIndex crashes with this:
blah123 is offline   Reply With Quote
Old 25th October 2010, 18:50   #5823  |  Link
poisondeathray
^This was answered already 2 pages back. Use directshowsource or dss2 + recent ffdshow build + haali media splitter ,or dgnvtools (not free, needs nvidia card)
Old 25th October 2010, 21:30   #5824  |  Link
blah123
Ok, but how I should do it? Which app?
I use TsMuxer, but when i remove interlace and convert files after muxing video with audio, the capture in file has a weird freeze of few frames and gives not synchronized audio and video. But whilst watching only video, it's good.
Old 25th October 2010, 21:42   #5825  |  Link
gorca
Possibly someone can help me out because am running out of ideas.
Last stable MeGUI (or older/experimental it doesn't matter), last x264 (or few versions older), last Haali, encoding from .m2ts to .mkv and this is what I get: http://img87.imageshack.us/img87/9789/bscap0000tt.jpg Every single time. Different .m2ts files/sources. Always the same. Was fine before. I've compressed dozens of BD's with MeGUI and never had this issue. Tried clean reinstall MeGUI, video decoder, splitter, etc. It didn't change anything. Could this be caused by some x264 setting? I always use the same, more or less, regular settings. Nothing too experimental. I don't know what could be causing these artifacts. Can't compress anything with MeGUI anymore.
gorca is offline   Reply With Quote
Old 25th October 2010, 21:52   #5826  |  Link
poisondeathray
You can use notepad, avsp, or megui
Just edit the script, it's not that difficult:
Directshowsource("video.m2ts")
or
DSS2("video.m2ts")
Old 25th October 2010, 21:55   #5827  |  Link
poisondeathray
what source filter?
post your script , settings
what playback software? what decoder?
are artifacts visible in preview before you encode?
Old 25th October 2010, 21:59   #5828  |  Link
gorca
As I said, Haali source (last 2 versions), different decoders (including different versions of ffdshow libav or WMV 9), no playback prbolem (only get this when encoding). Script: the usual. Nothing special about it. No MeGUI preview oartifacts.
Here are the x264 settings (although I tried some other settings also):
cabac=1 / ref=6 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=9 / psy=0 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=0 / threads=2 / sliced_threads=0 / nr=0 / decimate=0 / interlaced=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=2pass / mbtree=1 / bitrate=9500 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
P.S. I just encoded with x264_dp_ Unrestricted (DXVA) profile (didn't touch a thing, MeGUI 3.5.0., 1649 x264) and encoding is OK. This is obviously caused by some x264 setting. The problem is that I always use the same settings and if this is the encoder/settings problem it feels like something is broken.
Old 26th October 2010, 01:21   #5829  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
your player/decoder may be outdated and doesnt support certain x264 encoding features.
however, megui 0.3.5.0 is the latest stable version but not the most up to date.
since we're in the process of releasing a new stable version i suggest you to get the development version since it's pretty stable (probably more the the stable version you're using) and more up to date (tools included).
also update your player, ffdshow AND haali media splitter.
Old 26th October 2010, 11:32   #5830  |  Link
blah123
or
DSS2("video.m2ts")
But I use it in this way! And it isn't working!
Old 26th October 2010, 15:00   #5831  |  Link
poisondeathray
what's not working ? what's the error message when you preview .avs?
do you have haali media splitter, ffdshow installed ?
on win7 you need win7dsfiltertweaker as well
Old 26th October 2010, 20:16   #5832  |  Link
blah123
MeGUI 0.3.5.23, ffdshow, haali installed.
Ok, I try way of @poisondeathray again, but with other diffrent options.
Old 27th October 2010, 01:28   #5833  |  Link
gorca
Sharktooth, I've clean reinstalled everything (using only the latest meGUI, ffdshow, Haali, etc.) and it didn't change anything. However, I eventually resolved it. It seems that there was something specific with Back to the future (parts I, II, III) BluRay remuxes that I've used as sources. With these sources some x264 settings were not compatible so I got artifacts every time I changed Trellis 1 to 2, for instance. As soon as I used video-only source wrapped in .mkv that has been passed-through eac3to first, encoding artifacts were gone. Can't explain it but happy the issue was only connected to these 3 movies.
Thanks for helping out.
Old 27th October 2010, 05:30   #5834  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
glad you found a way to fix it.
Old 27th October 2010, 08:01   #5835  |  Link
LigH
LigH's Avatar
@ blah123:
Also there is FFmpegSource2, which is as independent from the whole DirectShow system and as free of charge as DGAVCDec, supports PAFF as well as MBAFF interlacing, and should be more frame-accurate than DGAVCDec with a replaced libavcodec decoder library (which was the reason why that one got abandoned).
The problem is not the demultiplexing, it is the decoding: There are different types (PAFF / MBAFF), and the old libavcodec decoder library used in DGAVCDec only supported MBAFF, but was the last frame-accurate version. DGDecNV uses Nvidia's PureVideo hardware decoder instead, DGAVCDecDI uses DiAVC.
New German Gleitz board
Old 27th October 2010, 18:14   #5836  |  Link
blah123
Ok, thx for support, TsMuxer handles with AVC.
But now I have a problem with audio. Is unsynchronised... I don't know, which delay I should set. tsMuxeR gives "-471", but there is still a little difference between audio and video after muxing...
Old 30th October 2010, 22:44   #5837  |  Link
GRKNGLR
Will a FLAC encoder and BassAudio be added to MeGUI in the future?
GRKNGLR is offline   Reply With Quote
Old 31st October 2010, 15:04   #5838  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
Maybe FLAC. BassAudio is not needed.
Old 31st October 2010, 19:39   #5839  |  Link
tebasuna51
tebasuna51's Avatar
Maybe only for AAC audio.
DirectShow don't work properly:
[Error] Log
-[Information] Versions
--[Information] MeGUI Version : 0.3.5.22
--[Information] OS : Windows XP Professional x86 SP3 (5.1.196608.2600)
--[Information] Latest .Net Framework installed : unknown
--[Information] Avisynth Version : 2.5.8.5
-[Error] Log for job10 (audio, 6p321.m4a -> 6p321.ac3)
--[Information] [31/10/2010 19:14:32] Started handling job
--[Information] [31/10/2010 19:14:32] Preprocessing
--[Information] Avisynth script
---[NoImage] DirectShowSource("D:\Test\6p321.m4a")
---[NoImage] EnsureVBRMP3Sync()
---[NoImage] return last
--[Information] Commandline used: -readtoeof 1 -b 640 - "{0}"
--[Information] [31/10/2010 19:14:32] Encoding started
--[Information] [31/10/2010 19:14:32] Encode thread started
--[Information] [31/10/2010 19:14:32] Avisynth script environment opened
--[Information] [31/10/2010 19:14:35] Script loaded
--[Information] Output Decoder
---[Information] Channels: 8
---[Information] Bits per sample: 16
---[Information] Sample rate: 48000
--[Information] Commandline: D:\Programa\megui\tools\aften\aften.exe -readtoeof 1 -b 640 - "D:\Test\6p321.ac3"
--[Information] [31/10/2010 19:14:35] Encoder process started
--[Error] An error occurred
---[Error] Exception message: Ha terminado la canalización.
---[Error] Stacktrace
----[NoImage]    at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
----[NoImage]    at System.IO.FileStream.WriteCore(Byte[] buffer, Int32 offset, Int32 count)
----[NoImage]    at System.IO.FileStream.Write(Byte[] array, Int32 offset, Int32 count)
----[NoImage]    at MeGUI.AviSynthAudioEncoder.encode()
---[Error] Inner exception: null
--[Information] Output from encoder via stderr
---[NoImage] Aften: A/52 audio encoder
---[NoImage] Version SVN
---[NoImage] (c) 2006-2007 Justin Ruggles, Prakash Punnoor, et al.
---[NoImage] input format: Microsoft WAVE Signed 16-bit little-endian 48000 Hz multi-channel
---[NoImage] Unsupported # of channels passed to aften_wav_chmask_to_acmod
---[NoImage] mismatch in channels, acmod, and lfe params
--[Information] [31/10/2010 19:14:35] Job completed
My 6p321.m4a is a standard 5.1, not 8 channels.
Without problems using an avs:
BassAudioSource("D:\Test\6p321.m4a")
-[Information] Log for job11 (audio, 6p321_m4a.avs -> 6p321_m4a.ac3)
--[Information] [31/10/2010 19:30:29] Started handling job
--[Information] [31/10/2010 19:30:29] Preprocessing
---[NoImage] Import("D:\Test\6p321_m4a.avs")
--[Information] [31/10/2010 19:30:29] Encoding started
--[Information] [31/10/2010 19:30:29] Encode thread started
--[Information] [31/10/2010 19:30:29] Avisynth script environment opened
--[Information] [31/10/2010 19:30:33] Script loaded
---[Information] Channels: 6
---[Information] Bits per sample: 32
--[Information] Commandline: D:\Programa\megui\tools\aften\aften.exe -readtoeof 1 -b 640 - "D:\Test\6p321_m4a.ac3"
--[Information] [31/10/2010 19:30:33] Encoder process started
---[NoImage] input format: Microsoft WAVE Floating-point 32-bit little-endian 48000 Hz 5.1-channel
---[NoImage] output format: 48000 Hz 3/2 + LFE
---[NoImage] SIMD usage: MMX SSE SSE2 SSE3
---[NoImage] Threads: 2
---[NoImage] progress: 100% | q: 534.5 | bw: 58.0 | bitrate: 640.0 kbps
--[Information] [31/10/2010 19:30:35] Postprocessing
---[Information] Deleting intermediate files
--[Information] [31/10/2010 19:30:35] Job completed
Old 31st October 2010, 21:49   #5840  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
ffaudiosource ?
megui
