8th September 2015, 21:13 | #32801 | Link |
So I guess for others to reproduce it they might need a AMD card, LAV with DXVA2 and madVR at the same time? No wonder then this issue was not reported. By the way, LAV is awesome, its so good to just have one software instead of some huge codec pack while keeping everything fast, great job on all of that!
8th September 2015, 21:18 | #32802 | Link | |
i get the same and it is not recommended to use superes more than 1 time. http://abload.de/img/testisthardrgszc.png |
8th September 2015, 21:37 | #32803 | Link |
Lost In The Web
@madshi
in the rar, my settings.bin & the file 638*480 used for the test http://dl.free.fr/getfile.pl?file=/7THddRTo
Windows 11 11th Gen Intel(R) Core(TM) i5-11400F Nvidia Geoforce RTX 3050 MPCHC - madVR - Lav Filters - XySubFilter |
8th September 2015, 22:11 | #32804 | Link | |
In the past, the player was dealing with all those issues. (In fact, in response to a request I made months ago, someone replied that "the player should be taking care of that") What I am missing is what madVR is now doing (when the new feature(s) are used). It is changing the frame size prior to doing up/down-scaling ? (Perhaps 6233638 knows what I am asking?)
s/w: Vista Home Basic 32bit (no Aero), MPC-HC, EVR Custom Presenter, CoreAVC Pro, ffdshow, SPDIFer h/w: Antec 2480 case, Gigabyte GA-MA69GM-S2H, 4200+, 2.5gb+512mb, ATI x1250 IGP, MS MCE remote |
8th September 2015, 22:34 | #32805 | Link |
if the frame size is 1280x960 (4/3) with a 16/9 picture with hard coded black bars it is changing the picture size to 1280x720.
depending on other settings other things will happen now with that picture. is there someone else who can't change the anamorphic lens stretch factor ? |
8th September 2015, 23:23 | #32807 | Link | |
So if I have a madVR profile that says "IF 960 THEN..." will it do the action? Or will it now only satisfy "IF 720 THEN... " Also, what is "screen masking" ?
8th September 2015, 23:28 | #32808 | Link | |
Anyway, I can no longer reproduce the issue, so it might have been a driver bug, because I've updated them since the problem. Last edited by ajp_anton; 8th September 2015 at 23:30. |
8th September 2015, 23:52 | #32809 | Link | ||
i guess it still take the source size for a simple reason there is no way the algo knows if the whole file is a 4/3 file with 16/9 content. Quote:
9th September 2015, 00:15 | #32810 | Link | |
Windows 10 // i7-8700k + GTX 1080 SLI // MPC-BE x64 + LAV + XySubFilter |
9th September 2015, 03:18 | #32811 | Link | |
Thought I'd mention it in case anyone else has the same problem. |
9th September 2015, 03:30 | #32812 | Link |
Many many thanks madshi, 0.89.2 now works with JRiver MC 20 and keep working with MPC-HC. The only thing I did notice is that subtitle positioning is wrong with some movies in JRiver when you choose No Changes in proportion settings, when you change to Expand it is fixed. Another thing i noticed is that with 0.89.2 NNEDI performance has decreased considerably. I was using NNEDI 64 without problems and now i can barely keep up with NNEDI 32.
PD: After more testing JRiver does keeps crashing with some movies. Bug report link: http://www.megafileupload.com/duS0/bugreport.txt Thanks in advance. I really appreciate your hard work. |
9th September 2015, 05:49 | #32813 | Link | |
Thanks madshi! |
9th September 2015, 08:13 | #32815 | Link | ||||||||||
It's only for front projection. I'll remove these settings for all display types but front projection in a future version. Quote:
3 taps is the only option now, that's why the taps option field is greyed out. I've removed 4 taps and 8 taps because they didn't bring any noticeable quality improvement. |
9th September 2015, 11:27 | #32816 | Link |
Latest madVR 0.89.2 has an issue with PotPlayer.
Play a file and turn into maximized size, the image will zoom much bigger than normal. http://i1.tietuku.com/2e6e6bab0be6fb69.png The normal should be: http://i1.tietuku.com/44f1b8a37618c6fb.png ps: no this issue with 0.89.1 and older versions |
9th September 2015, 11:46 | #32817 | Link | |
9th September 2015, 11:48 | #32818 | Link |
Did a settings reset (or sth. else I didn't notice...) and this issue is solved, thanks. Yes, it wasn't centred vertically, being fully at the top with all video still visible (on screen).
Win 10 Pro x64 |
