22nd June 2008, 09:19 | #3801 | Link | |
Swallowed in the Sea
22nd June 2008, 09:24 | #3802 | Link |
In StaxRip I demux all, there was only one request in 7 years to give control over this but it don't fit into StaxRip's philosophy (do what's practical automatically). It's however possible to read the language in the IFO file (assuming it was ripped without stream processing (normal case)) using MediaInfo, StaxRip does this to rename the audio files with a much better name:
VTS_01_1 01 en-English 3_2ch 384Kbps DELAY -192ms.ac3 VTS_01_1 02 de-German 3_2ch 384Kbps DELAY -192ms.ac3 VTS_01_1 03 hu-Hungarian 3_2ch 384Kbps DELAY -192ms.ac3 VTS_01_1 04 en-English Director's comments 2_0ch 192Kbps DELAY -128ms.ac3
22nd June 2008, 13:26 | #3803 | Link |
phjbdpcrjlj2sb3h
Would you guys like me to setup a Trac install or something for the MeGUI project? Personally, I am not a fan of the sourceforge tools at all, and prefer most alternatives to them. If you'd like something like Trac or Bugzilla setup, please just ask.
22nd June 2008, 17:30 | #3804 | Link | |
Aminei
The latest stable version seems to having issues with .NET.... |
22nd June 2008, 17:46 | #3805 | Link | |
Like so: F:\Program Files\Microsoft.NET\SDK\v2.0 64bit\Bin\corflags.exe /32BIT+ megui.exe This will change the clr header for the exe. |
22nd June 2008, 21:45 | #3807 | Link | |
Aminei
23rd June 2008, 00:45 | #3811 | Link | |
Stax's renaming trick seems quite useful. |
23rd June 2008, 01:03 | #3812 | Link |
Is there anyway to disable/enable cleanup on autoencode and one step encodiing? I sometimes have audio problems on captured HDTV, local stations screw up the audio and it would be easier if I had the raw video available to mux with when I get the audio straightened out?
23rd June 2008, 01:40 | #3814 | Link | |
23rd June 2008, 04:38 | #3816 | Link | |
phjbdpcrjlj2sb3h
Basically, I'm happy to setup any sort of infrastructure you guys would like for managing MeGUI, just let me know what you'd like (or if you want me to shortlist alternatives. |
23rd June 2008, 06:44 | #3817 | Link | |
Either we delete this feature, or we keep it and we try to make something useable with it. All I can say depends mainly on *when* and *what* we want to have in the 0.3.xxx stable version. All in all, I'm interested to release it as soon as possible. |
23rd June 2008, 06:46 | #3818 | Link | |
23rd June 2008, 07:44 | #3819 | Link |
phjbdpcrjlj2sb3h
It includes a wiki for documentation. Either that can be the frontpage, or a static HTML frontpage can be put in front of the whole Trac install. The latter seems to be a common way of dealing with this question.
23rd June 2008, 14:48 | #3820 | Link |
Mr. Sandman
stable
0.2.6.1049 - (berrinam) Added locking around getJobToProcess() to eliminate race condition on job starting (should fix #1932378: Two workers started working on same job) - (berrinam) MediaInfo should now properly detect .m4v files. (Fixes adaptive muxing for .m4v files) - (berrinam) Removed MP4 output from xvid_encraw, since it was never actually supported. - (berrinam) Fixed #1870331 (User specified sizes in bitrate calcs not remembered) dev Code:
0.3.0.1010 (includes the fixes and additions up to ver. 0.2.6.1049) - (berrinam) Better rationalisation of ARs in AVS window. Patch by i_a Dev version installer: http://www.webalice.it/f.corriga/meg...0_3_0_1010.exe
MPEG-4 ASP Custom Matrices: EQM V1(old), EQM AutoGK Sharpmatrix (aka EQM V2), EQM V3HR (updated 01/10/2004), EQM V3LR, EQM V3ULR (updated 04/02/2005), EQM V3UHR (updated 17/12/2004) and EQM V3EHR (updated 05/10/2004) Info about my ASP matrices. MPEG-4 AVC Custom Matrices: EQM AVC-HR Info about my AVC matrices My x264 builds. Mooo!!! Last edited by Sharktooth; 25th June 2008 at 14:58. |
development, megui, not a help thread |
