26th June 2008, 20:55 | #1821 | Link |
Hello,
I've got an problem with ripbot 1.10.1. When i convert with ripbot, the 2nd pass crashed. Windows Give me an error about the x264.exe file! I try to convert an blu-ray ripped in hard drive. I have already done with an old version of ripbot but now i have redoes because i want "Noise Movie Reduction". Here the repport of windows! Code:
Signature du problème Nom d’événement du problème*: APPCRASH Nom de l’application: x264.exe Version de l’application: 0.0.0.0 Horodatage de l'application: 48595796 Nom du module par défaut: ntdll.dll Version du module par défaut: 6.0.6001.18000 Horodateur du module par défaut: 4791a7a6 Code de l’exception: 80000003 Décalage de l’exception: 00047dfe Version du système: 6.0.6001.2.1.0.256.1 Identificateur de paramètres régionaux: 3084 Information supplémentaire n°*1: 47c1 Information supplémentaire n°*2: 675dce85330a461ae35e2f162cfc7bbd Information supplémentaire n°*3: 99cb Information supplémentaire n°*4: 5059fae0c3ca8ba98a7fc46c3cf909fb Informations complémentaires sur le problème ID du récipient*: 818511630
PC; 7.5 on 7.9 (Windows Experience Rating) on the lower rating. |
26th June 2008, 21:04 | #1822 | Link | ||
26th June 2008, 22:47 | #1823 | Link | |
Can you guys somehow make a toggle feature for subtitles? So we can turn on/off subtitles. Thanks |
27th June 2008, 00:27 | #1826 | Link | |
Ram is 2X Kingston DDR2 800MHZ 4GB With version 1.9.10: i have sucessfully with ripbot convert Across The Universe in blu-ray with noise reduction ON.
PC; 7.5 on 7.9 (Windows Experience Rating) on the lower rating. Last edited by 8ternity; 27th June 2008 at 00:30. |
27th June 2008, 00:45 | #1827 | Link |
Try with x264 r880 as well
27th June 2008, 02:03 | #1829 | Link | |
How come v1.9.10 is working??????? I didn't change anything related to iPOD. Unless stupid iTunes does not like mp4 with chapters.
27th June 2008, 02:44 | #1831 | Link |
http://www.videohelp.com/tools/RipBo...ons=1#download
I'm actually using 1.9.9, with the newer versions, I get script errors. Last edited by wakebrder; 27th June 2008 at 02:47. |
27th June 2008, 06:34 | #1832 | Link |
Anyone Tried ripboting Wak Hard Bluray Theatrical version? I have tried 3 different versions of ripbot - 1.9.4 - 1.9.6 and 1.10.1. All produce a movie gradually going out of sync. The movie has true sound and on the disc and is split into 40 .m2ts parts. The remuxed parts into one play perfectly insync on my HDD using Nero 8- but all ripbotted versions start off ok but are about 1 sec out by the end of the movie. I have run the joined .m2ts file though Convertx to make an ordinary dvd and this is insync ok. Any suggestions before I abort. Thx for any help.
27th June 2008, 09:05 | #1833 | Link |
@8ternity
The files are on my Drive with anydvd and tsmuxergui! 1 Movie 1 Sound! Same error ! I try to shrink Starship Troopers (Bluray) from my drive ! codec is VC1 When i Start the latest Ripbot following Error comes! video=DirectShowSource("C:\Temp\RipBot264temp\job1\Blu-Ray.mkv",audio=false).ConvertToYV12() LoadPlugin("C:\Programme\bluray\ripbot\tools\AviSynth plugins\NicAudio\NicAudio.dll") audio=NicAC3Source("C:\Temp\RipBot264temp\job1\audio.1.ac3") AudioDub(video,audio) WriteFile("C:\Temp\RipBot264temp\job1\info.txt","Framecount") WriteFile("C:\Temp\RipBot264temp\job1\info.txt","Framerate") WriteFile("C:\Temp\RipBot264temp\job1\info.txt","AudioRate") WriteFile("C:\Temp\RipBot264temp\job1\info.txt","AudioChannels") WriteFile("C:\Temp\RipBot264temp\job1\info.txt","AudioLength") WriteFile("C:\Temp\RipBot264temp\job1\info.txt","Width") WriteFile("C:\Temp\RipBot264temp\job1\info.txt","Height ") Trim(0,-1) Whats wrong? |
27th June 2008, 14:35 | #1834 | Link |
@Audiv8: Could you give wich version of ffsdshow are installed for admin help you with your case? Wich revision? Try uninstall ffdshow, download new version http://sourceforge.net/project/showf...roup_id=173941 >> Version SVN builds by clsid and reboot your computer. Re-try after that. Don't download the XXL version. If any trouble aftet that post your trouble that un admin can help you. Good luck.
PC; 7.5 on 7.9 (Windows Experience Rating) on the lower rating. Last edited by 8ternity; 27th June 2008 at 14:42. |
27th June 2008, 15:27 | #1836 | Link |
Remove chapter.txt from Job1 folder
27th June 2008, 19:34 | #1837 | Link |
Hi Atak,
have a problem. M2TS, 1 video track, 3 audio tracks, 1:52:54 1: Chapters, 16 chapters 2: VC-1, 1080p24 / 1001 (16:9) 3: DTS Master Audio, German, 5.1 channels, 16 bits, 48khz 4: Hi-Res DTS, English, 5.1 channels, 16 bits, 2082kbit / s, 48khz 5: DTS, English, 2.0 channels, 16 bits, 256kbit / s, 48khz [v02] Extracting video track number 2 .. [v02] Muxing video to Matroska ... Added value to MKV fps header. Video track 2 contains 162413 frames. eac3to processing took 20 minutes, 53 seconds. Done. It is only the first 3 Gemuxt soundtrack, how can I edit that I track for selection. |
27th June 2008, 21:06 | #1838 | Link |
Question: I have an MKV HD file, was 1280x544, ratio 2.35:1, want to keep the 2.35:1 ratio without cropping/zooming to set in 1280x720 without loosing/stretching the image with ripbot264. Can someone know how i can do that?
27th June 2008, 21:09 | #1839 | Link |
28th June 2008, 03:00 | #1840 | Link |
I dont care so should you
Installer updated its in my signature....
My Installer's || |
