6th March 2003, 18:32 | #41 | Link |
To 2cool or anyone,
Yes, I have tried this method of 2cool on this one cartoon episode dvd 9. But I cant get the ifos to work properly. okay, here is what i am doing. After getting the vobs to be compressed by dvd2one 1.02 there are several ifo and bu files and video_ts. Anyway, according to 2cools instructions, I start up ifoupdate and update the ifo according to its original and its author ifos. But after pressing correct sector, it pops up an error saying video_ts doesnt work and have to be aborted. Is it suppose to do this? Well, in 2cools instructions, it says that we can delete the ifos both in the dvd2one and episode folder. Does this mean that we do not have any ifos that we just created but just the original ones?? Or are we suppose to bring in these updated ifos and replace the old ones? Thirdly, after doing everything to the vobs, do we bring these new vobs and replace them in the original folder? And which video_ts file are we suppose to open up in ifoedit? Thank you. Please help me out. I really appreciate it. |
6th March 2003, 20:56 | #42 | Link |
Say your vob are 02_VTS set.
You created the new set with ifo. Rename the set to 01_VTS since IFOedit only creates 01_VTS ifo. Run DVD2one against it. Rename new DVD2one vobs back to 02_VTS. Run Ifoupdate, original would be 02_VTS.ifo file inside the original rip directory. Author would be the 01_VTS.ifo file. Ensure mode is Adjust Cell. Now update. Copy/Move 02_VTS vobs onto original rip directory. Done.
To Hell and Back |
6th March 2003, 21:03 | #43 | Link | |||||
PGC Navigator in Training
The next steps after DVD2One has compressed your episode VOBs is to rename and drag them into your Original folder. You must drag your original VOBs, if present, of the episode you're working on to another folder or delete them. IFOupdate and preview. If no problems then you can delete you IFOs in your "Episode" folder and "DVD2One". Remember in step 5, you "copied" over your IFO. Since your episode you worked on tested good then we don't need to work on it no more so you can delete as it is just a copy. As for your DVD2One files, it's going to be over written anyways when you repeat the procedures for the next episode title. Quote:
2COOL |
14th May 2003, 06:50 | #45 | Link | |
2COOL |
