Old 19th February 2003, 08:30   #21  |  Link
HeeD
I did a backup of LEXX Season 2 Vol. 1. using both InstantCopy trial and DVD2One v1.0.1 It has four episodes plus a couple other videos (making of LEXX, short about divine shadow and Interview with Michael McManus.
I used 2COOL's method and wound up with what was essentially a full backup of the DVD with menus and extras etc. It took me over hour and a half of messing around because I was not sure what I was doing. After doing it once now, I probably could do all the encoding, renaming and IFOUpdate stuff in an hour with DVD2One. The first part before doing any encoding at all was figuring out how much to reduce each VOB by. I figured in my case that a multiplier of .55 worked. Following is how I determined this:
I took total DVD size 7.64GB and subtracted from it the total of VOBs that I planned on transcoding with DVD2One, which was 7.58GB. This leaves me with a result of 0.06GB of extras that I leave as static. To derive the multiplication factor which will be used to reduce VOBs to fit on a DVDR - it is simple formula of: (DVDR_dest_size - static)/(DVD_orig_size - static), in this case (4.3 - 0.06)/(7.64 - 0.06) = 0.559. A simple verification shows that 7.58*0.559 +.06 = just under 4.3GB. I decide to reduce the factor to 0.55 for some headroom. eg. one of the VOBs was 1.70GB, therefore 1.70GB x 0.55 = 0.935GB, or 957.5 MB (0.935x1024). I round down so I entered 957MB in DVD2One for that particular VOB. As you are doing each VOB check how many MB it actually results in - it may be a meg or two larger so reduce the next VOB target size a little bit to compensate. I ended up with entire dir as 4.26GB after I was done.
InstantCopy was much easier - just let it do its work for a few hours.
Which one produced better results?
InstantCopy did! The DVD2One version had way too much artifacting. Even though the InstantCopy version also had lots of artifacting, it was different and not as irritating to watch. InstantCopy did not require any prep work, calculating VOB sizes or interacting with it in any way during its process. With DVD2One I had to do lots of calculating and basically be there with it renaming VOBs and transcoding.
Both programs show promise and I look forward to the retail version of InstantCopy that I ordered and also when DVD2One can backup an entire DVD automatically. I think they should work on an option to make the quality better first though - even if it takes longer to transcode.
HeeD is offline   Reply With Quote
Old 19th February 2003, 16:51   #22  |  Link
rishardc
Originally posted by 2COOL
rishardc,
I went over your guide more than once. Now correct me if I'm wrong but your method is combining all your episode VOBs and numbering them orderly as one titleset. You then create new IFOs and you got one big movie ONLY with all the episodes playing back to back. No menu keeping or extras.
In my way, I use DVD2one to transcode all 5 of my episodes SEPARATELY so that I can put them back in their original spot with IFOupdate fixing the original IFOs chapters points. This way, I get to keep EVERYTHING! Just like the original DVD.
Just got back from work. A little tired but still hangin'.
It keeps the original chapter points and it does play them back to back, but it looses the menu's and such.
rishardc is offline   Reply With Quote
Old 20th February 2003, 10:13   #23  |  Link
atreides93
I wrote an excel spreadsheet which should make it real easy to calculate the sizes.
anyone want it???
atreides93 is offline   Reply With Quote
Old 20th February 2003, 17:14   #24  |  Link
tyee
Yes atreides93 please post the spreadsheet
tyee
tyee is offline   Reply With Quote
Old 20th February 2003, 19:03   #25  |  Link
atreides93
here it is!
Old 20th February 2003, 22:47   #26  |  Link
repdetect2
Spreadsheet and Single Strand
Hey, can you repost it? I didn't come through.
Also, any ideas on the single strand with DVD2one?
repdetect2 is offline   Reply With Quote
Old 20th February 2003, 23:44   #27  |  Link
atreides93
2cool did some nice mods/improvements to the spreadsheet making it look nice.
i'm not sure how to upload files on here.
i attached it but it didn't show up
I think i figured it out. someone has to approve it. i'll ask the mod for this forum.
Old 20th February 2003, 23:56   #28  |  Link
2COOL
PGC Navigator in Training
2COOL's Avatar
Did you know that all this time, there's this poor guy waiting for months for a moderator in DVD burning forum to approve his file in his post? He's probably still there lost in the archives.
atreides93, I didn't know if you preferred a green or red theme on your spreadsheet. Decided to go for green as it's easier on the eyes.
2COOL
Old 21st February 2003, 00:42   #29  |  Link
repdetect2
Spreadsheet
Could you mail me the spreadsheet at repdetect2@hotmail.com?
Old 21st February 2003, 20:23   #30  |  Link
HeeD
2COOL, nice work!
Can you verify what mode should be used IFOUpdate?
Someone in a similar discussion said it should be "Adjusted Cell Mode". The default for it is "Standard".
Old 21st February 2003, 22:07   #31  |  Link
2COOL
2COOL's Avatar
Originally posted by HeeD
2COOL, nice work!
To tell you the truth, I assumed it was set for Cell Mode but after I already burnt the DVD, I saw it set at Standard. I don't recall ever encountering a non strand DVD with multi-PGCs.
2COOL
Old 22nd February 2003, 02:16   #32  |  Link
mrbass
FYI ..this is really minor...I use openoffice 1.0.2. The first calc works fine but the modified one just shows up blank. Just thought I'd save others the trouble of finding that out for themselves.
mrbass is offline   Reply With Quote
Old 22nd February 2003, 04:41   #33  |  Link
2COOL
2COOL's Avatar
The modified one was done and saved in Excel XP so earlier versions of Excel can't play it. Sorry, I wasn't thinking about it at the time. Will work on saving it in a more compatible excel format and posting it again. I also mentioned this in my guide.
2COOL
Old 22nd February 2003, 04:48   #34  |  Link
2COOL
2COOL's Avatar
Here's the updated resize calculator save in Excel 97 to 2002 format. There was one field that was corrected of not containing a formula. If you don't see it, a moderator in this forum needs to approve of it before uploading.
2COOL
Old 22nd February 2003, 05:58   #35  |  Link
vljenewein
vljenewein's Avatar
Don't see it..
vern at jenefarm@direcway.com
Thanks!
Vernon Jenewein
ICQ : 3826345 Eastern Time Zone
"Old age and treachery will overcome youth and skill"
vljenewein is offline   Reply With Quote
Old 22nd February 2003, 21:35   #36  |  Link
2COOL
2COOL's Avatar
Excel resize calculator has been corrected and also saved as a 97-2002 file for compability with older Excel versions. Download link in my guide on first page has been updated.
2COOL
Old 22nd February 2003, 22:37   #37  |  Link
vljenewein
vljenewein's Avatar
Thanks Max!
You're true blue.. and cool.. delivering a tool.
Many thanks, from an ol' fool.
I like how you did the set up. You really do need commending on taking the time to do this up and then to post it for anyone!
again...THANKS!
Vern
Vernon Jenewein
Old 22nd February 2003, 22:49   #38  |  Link
2COOL
2COOL's Avatar
Thanks but most of the credit goes to atreides93. I would've made my own but he beat me to the punch.
2COOL
Old 26th February 2003, 00:33   #39  |  Link
cmc
2COOL,
I believe you mentioned you were running win98se under the FAT32. Is this the same proc. to do a DVD-9 if not can you point me in the right direction?
Thanks,
P3, win98se, 512ram,ext 60 HD (maxtor), ext.Sony 500ul.
cmc is offline   Reply With Quote
Old 26th February 2003, 00:39   #40  |  Link
2COOL
2COOL's Avatar
Originally posted by cmc
2COOL,
Thanks,
cmc,
Just recently, I have upgraded to WinXP with SP1. It was about time I did a full format of my harddrive and install everything back from scratch to clean out any bad glitches or deinstallation residue. I really should be doing this annually.
But the answer to your first question, is yes. There's nothing in my guide that calls for you to have files over 4GB. And your second question, you are facing the right direction.
2COOL
[IMG] code is Off
