Old 19th September 2017, 13:04   #2721  |  Link
Artofeel
Artofeel's Avatar
AVFS is not working since pfmap-185 version
just closes right after start mounting (VapourSynth-R39-test4 \ VapourSynth-R38)
pfmap-184 is last working
I'm only one who used that feature?..
Artofeel is offline   Reply With Quote
Old 19th September 2017, 13:08   #2722  |  Link
Myrsloik
Professional Code Monkey
Myrsloik's Avatar
I'll give it a try then. Note that you don't even need it since a branded pismo library is also included in the installer.
Myrsloik is offline   Reply With Quote
Old 19th September 2017, 15:08   #2723  |  Link
Artofeel
Artofeel's Avatar
yeah, but I use pismo
like store thousands of images in one .pfo file
so I need new version of it due to some bugfixes
Old 24th September 2017, 02:18   #2724  |  Link
lansing
I'm trying to load a virtualdub filter through the avs loader, and I'm getting the error "Plugin C:/Program Files (x86)/VapourSynth/core64/plugins/AvsCompat.dll tried to register 'NeatVideo' more than once".
core.avs.LoadPlugin(r"VDubFilter.dll")
core.avs.LoadVirtualdubPlugin(r'NeatVideo.vdf', 'NeatVideo', 1)
clip = core.avs.NeatVideo(clip, ProfilePath, PresetPath, '1', '1', '1', '0')
Old 24th September 2017, 08:32   #2725  |  Link
Myrsloik
Myrsloik's Avatar
Where can I find both of these dlls and their source code?
I suspect that it's registering several different overloads of the same function which isn't supported (and so unusual nobody really encountered it before).
Old 24th September 2017, 13:23   #2726  |  Link
lansing
The vdubfilter.dll came with the avs+ update zip,
https://github.com/pinterf/AviSynthPlus/releases
The virtualdub version of the neatvideo dll can be download from its demo version
https://www.neatvideo.com/download
Old 24th September 2017, 20:13   #2727  |  Link
Myrsloik
Myrsloik's Avatar
Should be fixed in the next version. Note that the different overloads of the NeatVideo function will be distinct ones since VS doesn't do overloads at all. So the different versions will be called NeatVideo, NeatVideo_2, NeatVideo_3 and so on. Now to look into a few more bugs before I release the next test version.
Old 24th September 2017, 20:30   #2728  |  Link
lansing
I'll report this issue to the neatvideo forum to see if it's a bug or not
Old 24th September 2017, 20:33   #2729  |  Link
Myrsloik
Myrsloik's Avatar
It's not a bug.
Old 24th September 2017, 20:39   #2730  |  Link
lansing
It's not a bug.
Okay.
Old 26th September 2017, 21:12   #2731  |  Link
Myrsloik
Myrsloik's Avatar
Reproduced. I've contacted Joe Lowe about it so it should be fixed soon...
Old 26th September 2017, 21:23   #2732  |  Link
Myrsloik
Myrsloik's Avatar
R39-RC1
Start testing!
r39:
updated to zimg v2.6
added offline documentation to the installer
renamed the croprel function to crop, croprel will still be kept as an alias for for compatibility with existing scripts
fixed missing max value clamping for 9-15 bit input with convolution
optimized prewitt and sobel
removed the min and max arguments from sobel and prewitt because they interact very oddly with float formats
avisynth compatibility can now handle functions with multiple overloads
added float support to boxblur
removed subtext file size limit
fixed missing fps correction in avisource that would produce an error with some files
switched to nasm as the assembler
visual studio runtime detection is improved in the installer, it should no longer attempt re-installs when a newer version is present
minor optimization in vspipe, you can now output blankclip into the void much faster
memory will now be 64 byte aligned on systems with avx512 support
added swapn and dupn operators to expr
reverted the argument handling in levels, arguments no longer take a 3 plane list due it making no sense when combined with the planes argument
optimized levels, the integer version is now implemented with a lut and the floating point version is faster when gamma=1.0
improved get_outputs() in python (stuxcrystal)
format objects can now be cast to int which will return the format id (stuxcrystal)
added method to make it easier to query formats from python (stuxcrystal)
made it possible to install the python part as a module (stuxcrystal)
Old 26th September 2017, 23:18   #2733  |  Link
lansing
Ran into another problem with the avs' virtualdub plugin loader that it doesn't takes in named arguments, while vapoursynth asks for named arguments.
Also got the error "VirtualdubFilterProxy: only RGB32 supported for VirtualDub filters" and there's no conversion to RGB32 in vs. And when I set "format=vs.RGB" then editor would crash.
clip = core.resize.Bicubic(clip, format=vs.RGB)
clip.set_output()
Old 26th September 2017, 23:19   #2734  |  Link
Myrsloik
Myrsloik's Avatar
clip.set_output()
You can use unnamed arguments so I don't see the problem. The format you want is COMPATBGR32
Old 26th September 2017, 23:41   #2735  |  Link
lansing
I got the error "NeatVideo: Too many unnamed arguments specified". I'm using an older version of NeatVideo(3.5) which should be taking in 7 arguments including "clip".
clip = core.resize.Bicubic(clip, matrix_in_s="709", format=vs.COMPATBGR32)
Old 26th September 2017, 23:44   #2736  |  Link
Myrsloik
Myrsloik's Avatar
It's got multiple overloads like I mentioned. Try the NeatVideo_N() functions. List all the functions and signatures to see which version takes 7 arguments.
Old 27th September 2017, 00:09   #2737  |  Link
lansing
Okay I got the filter to work with NeatVideo_2(). And when I intentionally left out two, it gives me an error "NeatVideo_2: argument s6 is required", it doesn't tell me how many arguments I'm missing.
And there's a lot of warning about frame N not prefetched in the editor's log:
"Avisynth Compat: requested frame 47 not prefetched, using slow method"
Old 27th September 2017, 00:12   #2738  |  Link
Myrsloik
Myrsloik's Avatar
That's normal since it doesn't know about these filters. At least it works. Two layers of compatibility wrappers will always be quirky...
Old 27th September 2017, 02:59   #2739  |  Link
lansing
um, after more testing, looks like the filter stop having effect after around 6 random seeks in the preview or a few seconds of playback.
Old 27th September 2017, 22:58   #2740  |  Link
Myrsloik
Myrsloik's Avatar
What's profilepath and presetpath? How do I make myself a working script with this so I can try it?
speed, vaporware, vapoursynth
