14th October 2018, 19:50 | #181 | Link |
Software Developer
opus v1.3-rc2+2
opus-tools v0.2+2 | libopusenc v0.2.1 | libopusfile v0.11+4 opus-tools.2018-10-14.zip (mirror) (Includes a custom patch to show progress in 'opusdec' tool!)
18th October 2018, 22:55 | #182 | Link |
Opus 1.3 final is out now, please update title.
Changes since 1.2.x include: Improvements to the VAD and speech/music classification using an RNN Support for ambisonics coding using channel mapping families 2 and 3 Improvements to stereo speech coding at low bitrate Using wideband encoding down to 9 kb/s Making it possible to use SILK down to bitrates around 5 kb/s Minor quality improvement on tones Enabling the spec fixes in RFC 8251 by default Security/hardening improvements Notable bug fixes include: Fixes to the CELT PLC Bandwidth detection fixes Last edited by hajj_3; 20th October 2018 at 14:02. |
23rd October 2018, 08:42 | #184 | Link | |
Is it possible to control the built-in resampler? OPUS v1.3-beta1 encoder > opus-tools 0.1.10-2-gcc5a249-dirty OPUS v1.3-final encoder > opus-tools 0.2-3-gf5f571b Test sample > OPUS 1.3-final vs 1.3-beta1 Last edited by Gravitator; 23rd October 2018 at 08:47. |
24th October 2018, 21:23 | #185 | Link |
Software Developer
opus v1.3
opus-tools v0.2+3 | libopusenc v0.2.1 | libopusfile v0.11+4 2018-10-24.zip (mirror) (Includes a custom patch to show progress in 'opusdec' tool!)
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 24th October 2018 at 21:26. |
24th October 2018, 23:09 | #186 | Link | |
So there may still be something to do to improve the situation, but to be honest I'm not actually sure what would be the correct behaviour for 8-bit input. |
13th April 2019, 14:01 | #187 | Link |
Opus v1.3.1 is out:
libopus 1.3.1 Apr 12, 2019 This Opus 1.3.1 minor release fixes an issue with the analysis on files with digital silence (all zeros), especially on x87 builds (mostly affects 32-bit builds). It also includes two new features: A new OPUS_GET_IN_DTX query to know if the encoder is in DTX mode (last frame was either a comfort noise frame or not encoded at all) A new (and still experimental) CMake-based build system that is eventually meant to replace the VS2015 build system (the autotools one will stay). |
21st April 2019, 16:10 | #188 | Link |
Software Developer
opus v1.3.1+1
libopusenc v0.2.1+2 | libopusfile v0.11+5 | opus-tools v0.2+3 opus-tools.2019-04-21.zip (mirror) (Includes a custom patch to show progress in 'opusdec' tool!)
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 21st April 2019 at 16:13. |
6th November 2019, 12:55 | #189 | Link | |||
I will be grateful for the explanation how to correctly convert 5.1 or 7.1 to opus?
For example i have 7.1 flac file. I tried to convert through foobar2000 and ffmpeg, and i get Channel layout : L in both cases. What i'm doing wrong? My bat file Quote:
6th November 2019, 12:58 | #190 | Link | |
________________________ Sent from my phone using Tapatalk |
6th November 2019, 13:45 | #191 | Link |
I cut it by mkvtoolnix, but when i extract *.flac, for some reason it has the duration of the whole movie. But it doesn't matter, you can still reproduce it
https://drive.google.com/open?id=1Ys...3VCGOTLGz0TaEu I can upload source, but it 2.4Gb. Last edited by redbtn; 6th November 2019 at 14:04. |
6th November 2019, 14:48 | #192 | Link |
I was able to convert all channels
General Duration : 58 s 801 ms Overall bit rate : 146 kb/s Writing application : opusenc from opus-tools 0.2-3-gf5f571b ENCODER_OPTIONS : --bitrate 128 --vbr --comp 10 Channel(s)_Original : 8 channels Channel layout : L R C LFE Lb Rb Ls Rs ChannelLayout_Original : FL Sampling rate : 48.0 kHz Detected bit depth : 24 bits Compression mode : Lossy Writing library : libopus 1.3, libopusenc 0.2.1 Probably Opus requires at least 16kbit per channel while defaulting to VBR@96k leaves only 12k for each channel, hence downmixing comes into effect. What are your encoder settings? Try to increase overall bitrate to 128k or more. |
6th November 2019, 14:56 | #193 | Link | |
ffmpeg.exe -i input.flac -c:a libopus -vbr on -b:a 512k -ac 8 -y -hide_banner output.opus So, 512kb should be enough. Can you share your script? |
6th November 2019, 16:38 | #195 | Link | |
First I downloaded from the official website, now I use LoRd_Mulder's build. Last edited by redbtn; 6th November 2019 at 16:44. |
6th November 2019, 21:01 | #197 | Link | |
The issue at hand is that opusenc seems to always write the WAVEFORMATEXTENSIBLE_CHANNEL_MASK= value to the file's metadata, whereas FFmpeg only does it if the channel layout does not match the default (apparently; that's what some of the kinda-related issues on FFmpeg's trac go with). The Opus file sourced from sample.flac after encoding by opusenc has a value of WAVEFORMATEXTENSIBLE_CHANNEL_MASK=0X63F. If you demux the metadata from the FFmpeg-encoded opus file, paste that value into the metadata, then take the FFmpeg-encoded file and adjusted metadata file and remux them together with FFmpeg, mediainfo will 'see' the channel layout in the new file. Code:
ffmpeg -i sample.flac -acodec libopus -vbr on -ab 512k ffmpeg.opus Then check ffmpeg.opus in opusinfo and using ffmpeg -i to show that both of them still see the file as having all its channels. Play it back in mpv to verify whether the layout is correct despite mediainfo not reporting it. Code:
ffmpeg -i ffmpeg.opus -f ffmetadata metadata.txt Code:
ffmpeg -i ffmpeg.opus -i metadata.txt -map_metadata 1 -c copy ffmpeg-new.opus Now, if you do this and then the channel layout when being played back is wrong, then there's a bug that needs to be traced. Last edited by qyot27; 6th November 2019 at 21:05. |
7th November 2019, 12:18 | #198 | Link | ||
And I have another question. If I convert the same file multiple times, I get files with identical size but different MD5. I thought maybe only metadata changes, and looked on files into hex editor. They are different. Opus makes different decisions every time and encodes differently? (for example x265 or flac gives identical files) PS: I found another weird thing, if I convert to flac via ffmpeg (instead of eac3to), and then convert to opus via opus-tools, the same thing happens (mediainfo shows only L channel) I checked in hex editor and flac file produced by ffmpeg also doesn't have WAVEFORMATEXTENSIBLE_CHANNEL_MASK=0X63F The same situation with Quote:
8th November 2019, 00:15 | #199 | Link |
foobar2000 is probably not giving the FLAC file directly to opusenc, but decoding it to PCM and either piping it into opusenc or using a temp Wave file.
This really does sound like something that needs to be reported to MediaInfo, though. I don't know anything about libopus' determinism (or lack thereof) with its output from the same file. |
8th November 2019, 00:48 | #200 | Link | |
It doesn't matter, I found that mkvtoolnix erases metadata from opus file. When I mux it into MKV, mediainfo shows "Channel L". And if I demux opus from MKV, files are not the same. It doesn't have Channel layout and information about encoder (and maybe something else). I tried to compare them into hex editor, but files are much different. I don't have enough knowledge in this area, and I don't know is it impact to playback or not. But I definitely don't like that I can't mux file into MKV and then demux and get the same file as it was. It seems to me that I have to choose another encoder for converting my files (Unless someone can clarify this situation) Anyway, thank you qyot27 for help. Last edited by redbtn; 8th November 2019 at 00:54. |
