27th July 2022, 18:21 | #23 | Link |
SuperVirus
FWIW, and again:
from the #usercomments section for MKVtoolnix @ Videohelp dot com: Code:
If you have the following 69.0.007 versions bearing the below SHA-1, they will work with Windows 7/8 and respective server version: B5D5E22968F947558BFB100EF06D37A1FB3BC7C4 mkvtoolnix-32-bit-69.0.0-revision-007-ga64005aa6-setup.exe 5F8BB12A7C9FA214E4B63BCFC4EF020E27186A4F mkvtoolnix-32-bit-69.0.0-revision-007-ga64005aa6.7z 254911C993E8685AE514A8B7FD789C200EA6E3C4 mkvtoolnix-64-bit-69.0.0-revision-007-ga64005aa6-setup.exe 86B4EEDFA42A60D74FECBE76FA55BF44A53D400A mkvtoolnix-64-bit-69.0.0-revision-007-ga64005aa6.7z Code:
There might be one more option. There seems to be modified QT6 version for Win7 here: https://forum.qt.io/topic/133002/qt-creator-6-0-1-and-qt-6-2-2-running-on-windows-7 I've been already able to run another QT6 based software using that (Calibre 6.1 - https://calibre-ebook.com/download). There you need to use as well VxKex to run it - https://github.com/vxiiduu/VxKex But MKVToolnix seems to have QT embedded in main exe, so it is not possible just easily replace those binary files like for Calibre. |
29th July 2022, 19:13 | #25 | Link | |
SuperVirus
1) revert the change which made the CLI-executables depend on Qt (I.O.W., make them use the file magic.mgc again) + 2) replace the Qt-based GUI with one written in Java, or in a dot-net language, or in C++. Last edited by filler56789; 29th July 2022 at 19:16. Reason: clarity |
30th July 2022, 05:13 | #26 | Link |
SuperVirus
OOOPS, now finally there exists a non-official build of MKVtoolnix for Windows 7 and 8.1
https://forum.videohelp.com/threads/...st#post2663774 |
31st July 2022, 11:04 | #27 | Link |
According this thread, the minimal requirement build for mkvtoolnix is QT 5.9.0, so, for now, you "just" have to build mkvtoolnix with this QT version, no need for tweaked QT version, just normal 5.9.0.
I, out of curiosity take a look of how to build mkvtoolnix... argh... it seems even more painfull than building x264... Edit Maybe finaly it's not so painfull, but still failling building...
My github. Last edited by jpsdr; 31st July 2022 at 12:16. |
31st July 2022, 14:42 | #28 | Link | |
SuperVirus
Principally because of the bloated Qt slowware. When I managed to compile tsMuxeR, it was easy to get rid of the GUI part, which is the one that requires Qt. But MKVtoolnix is much more complex than tsMuxeR :–/ |
31st July 2022, 16:26 | #29 | Link |
Now there is a 32-bit version which works nicely under Win7 . Have a look here:
https://forum.videohelp.com/threads/...st#post2663838 Cheers manolito |
31st July 2022, 19:59 | #30 | Link |
Senior Member
If we could fork MKVToolNix to GitHub and then create an Actions script to automatically compile it.
I found this about Qt5: Code:
https://github.com/marketplace/actions/install-qt Future updates could be cherry picked to commit. Most non-gui commits would not break Win7 support. |
5th August 2022, 09:14 | #31 | Link |
Building MKVToolnix with QT5 under Linux
While the minimum requirement described in the MKVToolnix home page stays QT 5.9.0, it will probably be able to build a Windows 7 version. For now, i've not been able to build under Windows with MSYS2, the mxe package may just not be compatible with... But one thing is sure: You can't build from a 32 bits Windows with a 32 bits version of MSYS2. I'll describe what i've done, so some the paramaters/values i've used are specific to my configuration, adapt if you change things. I've created an MKVToolnix directory in my $HOME directory. Then, clone GIT the followings: Code:
git clone https://gitlab.com/mbunkus/mxe $HOME/MKVToolnix/mxe git clone https://gitlab.com/mbunkus/mkvtoolnix.git $HOME/MKVToolnix/mkvtoolnix Change eventualy the ARCHITECTURE if you want to build for 32 or 64 bits. For my setup, i've changed: Code:
INSTALL_DIR=${INSTALL_DIR:-$HOME/MKVToolnix/mxe} Code:
MKVTOOLNIX_DEPENDENCIES+=qt6 qt6-qtmultimedia Code:
MKVTOOLNIX_DEPENDENCIES+=qt5 qtmultimedia I was under Ubuntu 20.04, i'll now switch to install instructions specific to it. I had to install the following: Code:
apt-get install \ autoconf \ automake \ autopoint \ bash \ bison \ bzip2 \ flex \ g++ \ g++-multilib \ gettext \ git \ gperf \ intltool \ libc6-dev-i386 \ libgdk-pixbuf2.0-dev \ libltdl-dev \ libssl-dev \ libtool-bin \ libxml-parser-perl \ lzip \ make \ openssl \ p7zip-full \ patch \ perl \ python3 \ python3-mako \ ruby \ sed \ unzip \ wget \ xz-utils I may have installed too much things, so, the following is my guess of what may just be necessary: Code:
apt-get install python-is-python3 libogg-dev libvorbis-dev docbook-xsl xsltproc Code:
apt-get install vorbis-tools qt5-default build-essential qtcreator Now, from within the mkvtoolnix directory, run the script: Code:
./packaging/windows/setup_cross_compilation_env.sh Now... If everything went fine, it will say it and display a message with also 3 commands to execute, with rake at the last. Copy/paste (and so execute) the 3 commands in your console. The last, rake, will build mkvtoolnix. You have to search within the src directory (and sub-directories) to find all the .exe. I've been able to build a 32 bits version of 69.0.0.39, tested Ok (at leat the GUI starts) on a Windows 7 x86. Edit If you want to build both 32 bits and 64 bits versions, once a build is finished, you have to run "rake clean", and after changing ARCHITECTURE in setup_cross_compilation_env.sh, re-run it, don't add the PATH (it's allready done if you're still in the same console), just "hash -r" and "rake". And then, after, you have to strip the files. Edit 2 Collect them together in a location for stripping them all at once. 32-bit executables require the 32-bit strip.exe, 64-bit executables require the 64-bit strip.exe. 32-bit build: Code: Code:
{mxe}/usr/bin/i686-w64-mingw32.static-strip *.exe Code: Code:
{mxe}/usr/bin/x86_64-w64-mingw32.static-strip *.exe
My github. Last edited by jpsdr; 10th August 2022 at 08:52. |
5th August 2022, 13:23 | #32 | Link |
Build under Windows with MSYS2 is not looking good...
After solving some issues, i've been able to begin the toolchain build, but after a very long time (at least 1h if not 2h), it failed with: Code:
configure: error: Oops, mp_limb_t doesn't seem to work
My github. |
5th August 2022, 13:44 | #33 | Link |
SuperVirus
I have not read everything yet, BUT maybe there exists a workaround :–/
............. The configure step fails with "error: Oops, mp_limb_t doesn't seem to work" apparently because it calls configure using an absolute path, not relative. |
6th August 2022, 08:15 | #35 | Link |
Anyway, i have 69.0.0.39 Windows 7 working (at least, GUI start, didn't test further yet) version build under Linux, but i don't know where to put it. Any suggestion ? Create a Github ?
My github. |
7th August 2022, 10:39 | #39 | Link | |
I'll think later eventualy for at least a github.
My github. |
mkvtoolnix, windows 7 |
