Old 15th March 2018, 20:47   #1  |  Link
hubblec4
Matroska find' ich toll
DGIndexNV.dgi HEVC
Hello
I would like to support the DGIndexNV.dgi HEVC but this tool tells me my graphic card is not supported.
Could anybody share with me such a sample file please?
Best regards
hubble
hubblec4 is offline   Reply With Quote
Old 15th March 2018, 20:53   #2  |  Link
videoh
Useful n00b
Just out of curiosity, how will you use the DGI files?
Small file with one GOP:
DGHEVCIndexFileNV18 DGIndexNV 2053.0.0.132 X64
D:\Don\Programming\C++\DGDecNV\DGIndexNV\x64\Release\
H:\Streams\HEVC\8 Bit\MKV\HEVC2.mkv 831868
DEVICE 0
DECODE_MODES 0,0,0,0,0
STREAM 2 0
CLIP 0 0 0 8
RANGE 0 0 18446744073709551615 0
DEMUX
DEPTH 8
0:IDR 0 2 0
1:TRAIL 0 1
2:TRAIL 0 2
3:TRAIL 0 3
4:TRAIL 1 4
5:TRAIL 0 5
6:TRAIL 0 6
7:TRAIL 0 7
8:TRAIL 1 8
9:TRAIL 0 9
10:TRAIL 0 10
11:TRAIL 0 11
12:TRAIL 1 12
13:TRAIL 0 13
14:TRAIL 0 14
15:TRAIL 0 15
16:TRAIL 1 16
17:TRAIL 0 17
18:TRAIL 0 18
19:TRAIL 0 19
20:TRAIL 1 20
21:TRAIL 0 21
22:TRAIL 0 22
23:TRAIL 0 23
24:TRAIL 1 24
25:TRAIL 0 25
26:TRAIL 0 26
27:TRAIL 0 27
28:TRAIL 1 28
29:TRAIL 0 29
30:TRAIL 0 30
31:TRAIL 0 31
32:TRAIL 1 32
33:TRAIL 0 33
34:TRAIL 0 34
35:TRAIL 0 35
36:TRAIL 1 36
37:TRAIL 0 37
38:TRAIL 0 38
39:TRAIL 0 39
40:TRAIL 1 40
41:TRAIL 0 41
42:TRAIL 0 42
43:TRAIL 0 43
44:TRAIL 1 44
45:TRAIL 0 45
46:TRAIL 0 46
47:TRAIL 0 47
48:TRAIL 1 48
49:TRAIL 1 49
SIZ 1920 x 1088
FPS 50 / 1
CODED 50
ORDER 0
MAGA (Make Avisynth Great Again)
Old 15th March 2018, 23:33   #3  |  Link
hubblec4
Hi videoh
I never heard about DGIndexIM and I'm also not an expert but I use DGIndexNV in my chapterEditor for cutting to get keyframe timestamps.
(Also all .dgi files can be processed to chapters expect the HEVC format).
This sample here is to short but thanks. I will send you a PM.
Old 16th March 2018, 01:53   #4  |  Link
videoh
Useful n00b
Sorry, forgot that DGDecIM doesn't support HEVC. I sent you the user manual with the description of the HEVC dgi file format. Let me know if I can help in any other way.
Old 16th March 2018, 13:42   #5  |  Link
hubblec4
Thanks for your email and the sample.
I bought me DGIndexNV so I have this user manual with the description of HEVC format.
Maybe I need some info about the HEVC format stored in the .dgi file.
Has HEVC also "I" and "IDR" frames like AVC?
Old 16th March 2018, 18:13   #6  |  Link
videoh
Useful n00b
IDRs, CRAs, and BLAs are the keyframes for HEVC. Refer to the specification for details.
Old 16th March 2018, 21:45   #7  |  Link
hubblec4
Yes ok, but AVC has also "I" and "IDR" frames which are keyframes but only "IDR" is a "full" keyframe and only there can MKVToolNix cut the video correctly.
I think HEVC-IDR is the same like AVC-IDR. Are CRA and BLA also "full" keyframes or the same like AVC-I frames?
Old 16th March 2018, 22:09   #8  |  Link
nevcairiel
IDR, CRA and BLA are all "IRAP" frames, ie. "Intra Random Access Pictures", which means you can start decoding from there. The differences lie in their usage - a CRA frame could be followed by inter pictures in coding order with reference frames not available to the decoder, and must therefor be discarded (TFD frames, Tagged for Discard), which is not allowed for IDR. BLA are quite similar to CRA, except they convey a special meaning that the bitstream may have been stitched at that point.
