Old 1st May 2003, 23:30   #1  |  Link
rududu author
Nicolas
Rududu codec : new test version
Hello all !
I just released a new version of Rududu, so I'm very interrested to know what you think about it, what should be improved, what is good ...
for the english speaking people, the page is :
http://www.ifrance.com/rududu/codec3en.htm
pour les francophones :
http://www.ifrance.com/rududu/codec3.htm
thank you for your answers
Nicolas
rududu author is offline   Reply With Quote
Old 2nd May 2003, 00:08   #2  |  Link
Sirber
retired developer
Sirber's Avatar
Allo Nicolas.
Pense-tu offrir les sources aussi?
Hi Nicolas.
Do you think you'll release the sources?
Detritus Software
Sirber is offline   Reply With Quote
Old 2nd May 2003, 14:04   #3  |  Link
gino25
great!!!!!!!!!!!!
gino25 is offline   Reply With Quote
Old 2nd May 2003, 14:40   #4  |  Link
rududu author
Nicolas
Originally posted by Sirber
Allo Nicolas.
Hi Nicolas.
Ce n'est pas exclu, mais pas pour le moment. Peut-être lorsque j'aurais trouvé un boulot.
It's possible, but not now. Maybe when I'll found a job.
Old 2nd May 2003, 17:32   #5  |  Link
gino25
What are settings for a high quality encoding?
I tried some settings but video has not much details
Old 2nd May 2003, 18:20   #6  |  Link
rududu author
Nicolas
Well ...
good question :-)
The min quality was 32, but I limited it to 64 because of some (stupid ?) reasons. So you can't for the moment. And if you try to set the dead zone ratio below 256-ThresRatio you will see a beautifull bug. So I have to correct all this.
Sorry :-)
I have too much tested with the settings for a "middle" video quality...
Nicolas
Old 3rd May 2003, 00:48   #7  |  Link
Koepi
Koepi's Avatar
This sounds definatly interesting. Can you please give some more information like
- is the codec meant for archive or capturing purpose? (i.e., which datarate does it perform at "best")
- how fast is it? (i.e., does it do 720x576 in 20x realtime or is it more like 5fps)
... and so on.
If we test it, we need to know the "design goal" to give a proper feedback.
Thanks for your nice work, keep it up!
Best regards
Koepi
Koepi is offline   Reply With Quote
Old 3rd May 2003, 01:13   #8  |  Link
Sirber
retired developer
Sirber's Avatar
I'd like to know if it's I frames only in wavelet or if there is P frames too...
Detritus Software
Old 3rd May 2003, 09:01   #9  |  Link
rududu author
Nicolas
All the frames are compressed with wavelet. it's the antonini 9/7 transform, used in the JPEG2000 standard.
Old 3rd May 2003, 14:42   #10  |  Link
gino25
I have tried a lot of settings. But in all videos there is low details. (quality was at max)
Ruududu version2 have more details.
Why? Help
Old 3rd May 2003, 14:49   #11  |  Link
Sirber
retired developer
Sirber's Avatar
Won't we have greater quality by using p-frames?
Detritus Software
Old 3rd May 2003, 15:14   #12  |  Link
rududu author
Nicolas
There are P frames, I'm just saying that I frames and P frames are compressed using wavelet (even the motion vector field will be compressed using a simple wavelet)
Old 3rd May 2003, 15:22   #13  |  Link
Sirber
retired developer
Sirber's Avatar
That's great! I taught it was only I frames... sorry
Detritus Software
Old 3rd May 2003, 15:29   #14  |  Link
Koepi
Koepi's Avatar
So i still have to assume things and don't get any real insights? :P
Let me summarize:
rududu codec is
- an (integer?) wavelet (antonini 9/7 transform) codec
- using I- and Pframes
- using wavelets for compressing motion vectors (wtf? wavelets and motion vectors don't mix, sounds like a block based attempt again)
- optimized for medium quality at unknown speed and for unknown purpose (archive quality / temporary capturing space+speed)
- had better quality in the last beta version
- written by Nicolas from france
That's all we have about that codec for now. Or did I miss anything?
Old 3rd May 2003, 16:01   #15  |  Link
Sirber
retired developer
Sirber's Avatar
This seems correct with the infos we have now. Maybe Nicolas didn't understand your question...
From Koepi (Translated by Me):
Ça a l'air vraiment intéressant. Pourais-tu svp nous donner des informations de plus comme
- Est-ce que le codec a été conçu pour archiver ou pour capturer (c-a-d a quel kbps il donne la meilleure qualité)
- Quel est sa vitesse? (c-a-d, est-ce qu'il fais du 720x576 a 20x la vitesse du temps réel (mouhahaha) ou c'est plus du 5 fps)
... et on continu!
Si on doit le tester, on doit savoir le "but" pour pouvoir te donner des commentaires pertinents.
Merci pour ton bon travail, lâche pas!
Meilleurs veux
Koepi
Detritus Software
Old 3rd May 2003, 18:03   #16  |  Link
Koepi
Koepi's Avatar
Thanks for translating that Sirber, my french is _really_ rotten ( I can't even "decompress" most of your french abbreviations ) and additionally, our main language here is english so that everyone has the chance to understand things.
Merci beaucoup pour tous (even that looks wrong to me - I need a refresh-your-french-class it seems),
Koepi
Old 3rd May 2003, 18:34   #17  |  Link
Sirber
retired developer
Sirber's Avatar
Merci beaucoup pour tout
no "s"
It means "Thanks a lot for all"
Detritus Software
Old 3rd May 2003, 18:46   #18  |  Link
Koepi
Koepi's Avatar
I know what I _want_ to write
I only missed the tout<->tous difference. So after all it's (EDIT: = my french) not way worse as it was after school
EDIT2: after reading this in english I think in german we're way shorter, here we just say "Danke für alles" - 3 words vs. 4 in french and 5 in english
Regards
Koepi
Old 3rd May 2003, 23:43   #19  |  Link
Sirber
retired developer
Sirber's Avatar
lol
I was just teasing
Detritus Software
Old 4th May 2003, 01:10   #20  |  Link
spyder
Matroska Developer
spyder's Avatar
"Thanks for everything" <-- 3 words in English
spyder is offline   Reply With Quote
