Old 8th October 2017, 22:29   #46341  |  Link
ABDO
madshi you are wonderful, great work, mucht thanks
ABDO is offline   Reply With Quote
Old 8th October 2017, 22:39   #46342  |  Link
mzso
I don't even know what the bug is all about. I don't have the resources to go to other forums to look for bugs. If the ProgDVB developer thinks there's a bug in madVR then he'll welcome to contact me about it. He did contact me about the deinterlacing bug, and it's fixed now.
That would require him to acknowledge it as a bug, which so far I couldn't get him to do. (The deinterlacing issue took a year...)
I got nowhere with that. Keeps pointing me towards madVR.
But basically the bug is that I get this:
(madvr)
Instead of this:
(EVR)
(Even though I have HD skin enabled.)
Old 8th October 2017, 22:41   #46343  |  Link
bitterman
The decoder queue goes empty in the moment when this happens. Which means that the decoder is not sending madVR any frames in this situation. I'm not sure why, but it doesn't seem like it's likely to be madVR's fault. Have you tried another video renderer like VMR9 or EVR? If the problem also occurs with them, then that would prove that it's not madVR's fault.
It wasn't a fun thing to do, but I've watched the movie with both EVR (custom presenter) and VMR9 (renderless) for approximately 30 minutes straight. Nothing happened.
The moment I changed back to MadVR. The freeze image issue was there again.
The problem only goes away when I untick HEVC in LAV video configuration. Then the playback is smooth and nothing happens.
It's safe to say that the problem is causing because of my not HEVC compatible video card, the GTX 650 Ti.
I have no idea why with EVR and VMR9 the freeze image issue didn't occurred.
Because while I was testing I did had the HEVC box ticked in LAV video and the current active decoder was my gpu instead of avcodec.
Originally Posted by sneaker_ger View Post
No, R7 doesn't support HEVC at all. Then LAV simply falls back to software decoding. Good software decoding is often better than "bad" (no ASIC) hardware decoding.
If you open LAV Video settings during playback it will tell you which decoder is currently active. ("avcodec" = (ffmpeg) software decoder)
Yes, you were right. On my dad's computer the active decoder was "avcodec".
Even though HEVC was still ticked in his LAV video configuration it did automatically went for avcodec instead of using his gpu.
bitterman is offline   Reply With Quote
Old 8th October 2017, 22:46   #46344  |  Link
Ver Greeneyes
4) Currently chroma noise/artifact reduction is very slow because I'm doing it in luma resolution. In a future version I'll do it on the original chroma data instead which should reduce the chroma processing hit to a quarter of the current cost for 4:2:0 content.
Sounds good. The (old Youtube) videos I'm testing this on right now need a huge amount of deblocking in the chroma channels, but luma only needs some minor adjustments. Would it be possible to have a separate strength setting for the chroma channel processing? On these videos I need a strength setting of 9 or 10 to fix the chroma, but that obviously does far too much damage to the complete image.
Old 8th October 2017, 22:53   #46345  |  Link
Anime Viewer
Troubleshooter
Anime Viewer's Avatar
madVR v0.92.5 released
http://madshi.net/madVR.zip
1) Please test the new algorithms and let me know what you think!
Getting a failed error message (repeatedly) trying to download v0.92.5. Anyone else experiencing this problem?
System specs: Sager NP9150 SE with i7-3630QM 2.40GHz, 16 GB RAM, 64-bit Windows 10 Pro, NVidia GTX 680M/Intel 4000 HD optimus dual GPU system. Video viewed on LG notebook screen and LG 3D passive TV.
Anime Viewer is offline   Reply With Quote
Old 8th October 2017, 22:56   #46346  |  Link
dvd1
bilinear: https://abload.de/img/billineare3pa6.png
ngu sharp: https://abload.de/img/ngusharpe1rem.png
i don't even know where to start it is anywhere.
if you can't see the major difference I suggest in a not offensive way to meet a optician to fix the problem.
the difference is really really big al over the image except the sky.
how do you change stairs on an image. ping
thank you
dvd1 is offline   Reply With Quote
Old 8th October 2017, 22:56   #46347  |  Link
juanchu
MPC-BE (1.5.1 (build 2755) beta) crashes with madVR turned on. If I try to change file after playing it or if I try to close player, then crashes. With previous version, this didn't happen.
However, there is no problem with MPC-HC (1.7.13).
juanchu is offline   Reply With Quote
Old 8th October 2017, 22:58   #46348  |  Link
ABDO
no,every thing is normal here
Old 8th October 2017, 22:58   #46349  |  Link
mzso
* fixed: ProgDVB: DXVA deinterlacing didn't activate after channel switch
* fixed: potential freeze when freeing madVR instance
* fixed: playback trouble after switching video files (introduced in v0.92)
[/code]
I think something may have gotten awry. Now I get a crash every time I change-channel/try-to-change-renderer/unload-tuner with ProgDVB and every time I stop-playback/open-a-new-file-during-playback with potplayer. So it seems like when madVR is unloaded.
I couldn't test for the previous deinterlacing or hanging issues because of this.
(all I did was overwrite the files in the madVR folder and ran instal.bat)
Old 8th October 2017, 23:01   #46350  |  Link
madshi
(madvr)
Instead of this:
(EVR)
Is there an easy way for me to reproduce this without requiring any actual DVB hardware?
Does madVR show "(DXVA11)" at the end of the 4th line in the Ctrl+J OSD when these freezes occur?
Can you make a sample available, or 2 or 3 which show this problem? Would be interesting to look at them. But yes, different strengths for luma and chroma are possible, if really needed.
Seems to work fine for me.
Just noticed a crash problem in v0.92.5, which happens when switching from one video file to another, or sometimes even just closing a video file. Already found the cause of the problem, stupid bug. Sorry, my bad, will fix that tomorrow in v0.92.6.
Old 8th October 2017, 23:03   #46351  |  Link
madshi
Here's a quick fix for the crash problem:
http://madshi.net/madVR925b.zip
New official v0.92.6 with this fix (and maybe some more changes) will come tomorrow.
Old 8th October 2017, 23:09   #46352  |  Link
ryrynz
ryrynz's Avatar
Who's going to be the first madman to remove random noise and then add grain?
Old 8th October 2017, 23:12   #46353  |  Link
madshi
It's actually not as mad as it might seem because:
1) encoded grain is often quite artifacty.
2) upscaled grain looks bad.
3) added grain after upscaling has no artifacts and looks high-res.
However, removing grain may also remove details. So it's probably still not a good idea overall.
Old 8th October 2017, 23:22   #46354  |  Link
Ver Greeneyes
Sure, here's a 30 second clip from the start of an old Let's Play: https://mega.nz/#!SBlwlZ5K!msF_yjXZZ...EN_iAvkBN7KBCU (pretty much just the menu screen, here's the full playlist)
In general I've noticed that the chroma channel for Youtube videos tends to be pretty horrendous (including for higher resolution videos), I don't know if that's just the bitrate or if Youtube's re-encoding makes it worse.
Old 8th October 2017, 23:26   #46355  |  Link
thank you
sorry i can't really follow you. if you are talking about aliasing billinear adds a lot of aliasing.
@deblocking
my first issue with the deblocking is that it very fast changes images parts that are not blocky anymore and makes them very unsharp but on other images parts the blocking is still there.
i used a very blocky video file from on old computer game using SMK2 as a codec.
here an image: https://abload.de/img/winordert5uc3.png
and i wonder if debanding is run before or after deblocking.
Old 8th October 2017, 23:43   #46356  |  Link
mzso
I don't know. I don't think progDVB loads anything if you don't have tuner running, with a channel tuned. (And so far I haven't heard of a dummy tuner.)
Trying with the hotfix I could still get Potplayer hanged video open spamming.
But I noticed that the madVR OSD is still updating. Does that mean anything? (I didn't think to have OSD open before, so I didn't know how it was.)
Link: https://drive.google.com/open?id=0By...Gx6d0ZfU3E1Mnc
I also noticed that madVR shows DXVA, even though I disabled HW accelerated decoding in LAV. Is that normal because of deinterlacing?
Old 9th October 2017, 00:05   #46357  |  Link
dvd1
excuse me, how did you change BILINEAR to NGU on a single image. png?
Old 9th October 2017, 00:05   #46358  |  Link
madVR is by default using DXVA chroma scaling when DXVA deinterlancing is used you can control this under trade quality for performance.
Old 9th October 2017, 00:06   #46359  |  Link
i pause the video and change the scaling algorithm.
Old 9th October 2017, 00:26   #46360  |  Link
dvd1
[QUOTE=huhn;1821256]i pause the video and change the scaling algorithm.[/QUOTE
]then if I pause is changing the scaler already changes or should I start the video again?
thank you so much
