21st February 2011, 06:55 | #6021 | Link |
So my best start would be MeGUI. Are there any extra command lines i have to put when encoding video games, I don't care how big it will be. I'm actually looking about 100mb per minute.
Perfection is achieved, not when there is nothing more to add, but when there is nothing left to take away. |
21st February 2011, 09:30 | #6022 | Link |
AiDz0r: Neither your user title nor your signature render correctly for me with any browser I have installed. But they stretch your posts and make the page scroll horizontally.
21st February 2011, 14:08 | #6023 | Link |
Mr. Sandman
AiDz0r, as per forum rules there is no best. MeGUI as well as other GUIs are a matter of personal taste. Use what you like more. However, MeGUI supports almost all x264 commandline options, so no need to specify extra commandline options. I'd start playing with presets and tunings.
21st February 2011, 18:10 | #6024 | Link |
Problem with MEGUI not updating
Hi All
Has any one having the problem with MEGUI (32) not updating? My copy has not updated for several weeks. Is there a fix for this problem I have. Many Thanks Whimick |
21st February 2011, 20:22 | #6025 | Link |
go to settings an change the update server from the drop list...
_
if you ask a question and somebody give you the correct answer don't forget to leave a "thank you" note... Visit The Land Of Dracula (Romania - EU)! |
28th February 2011, 14:49 | #6027 | Link | |
what's this for?
Windows 7 / SP1 MeGUI 1981 preprocessing took about 25 min before audio encoding started. only tested with AAC encoding (Winamp & Nero) still a known issue?
latest mix sets: http://soundcloud.com/sill |
28th February 2011, 16:01 | #6028 | Link | |
1st pass (preprocessing) to know the max volume value. 2nd pass (encode) to encode the audio with the max volume allowed.
1st March 2011, 08:28 | #6032 | Link |
I don't mind functional and simple UIs (there is software where you miss the features over all the UI effects) ... but the squeezed edit lines and buttons are funny. Do they have too many resizer anchors?
1st March 2011, 15:10 | #6033 | Link |
partially-informed layman
If I'm running MeGUI 1911 (32-bit) under 64-bit Windows, will MeGUI automatically use the 64-bit version of x264 that I see it has downloaded to C:\Program Files\MeGUI\tools\x264\x264_64.exe or do I need to somehow tell it specifically to use that rather than the 32-bit version. If so, how would I do that? thanks
1st March 2011, 15:58 | #6034 | Link | |
The Black Reaper
1st March 2011, 16:15 | #6035 | Link | |
1st March 2011, 16:51 | #6036 | Link |
@ Lighto & Tuik - Thanks very much. I missed that because it's greyed out here in 32-bit XP. I'm writing a tutorial and want to mention 64-bit mode. By the way, is there any official, current 64-bit version of MeGUI?
1st March 2011, 18:03 | #6037 | Link | |
The Black Reaper
Not very sure of the details. AFAIK, one is required to use all 64bit filters in their work flow when using the 64bit version of MeGUI. |
4th March 2011, 20:38 | #6038 | Link |
This YouTube video was rendered with x264 in MeGUI following this tutorial precisely. Does anyone have any idea why the levels in the first couple of seconds are wrong? Are there any x264 or MeGUI settings that affect that? No problem with offline playback of the file in VLC.
4th March 2011, 20:49 | #6040 | Link |
The first three seconds of an x.264 MP4 created with MeGUI 1911 and uploaded today to YouTube has its levels completely screwed up:
Nutcracker Highlights It will only take about five seconds of your time to see the problem. You will note that the levels return to normal at exactly the first scene transition which makes me think something is wrong in the way the initial GOP is formed. However, the MP4 plays perfectly on my computer using the VLC media player. Here are the video settings used: Code:
program --profile main --level 3.1 --crf 19.2 --deblock -2:-1 --keyint 300 --min-keyint 29 --bframes 2 --b-pyramid none --no-weightb --ref 2 --weightp 0 --qpmin 3 --subme 6 --trellis 0 --no-mixed-refs --output "output" "input" I got these video settings from an excellent MeGUI tutorial, but am wondering if any of the changes from default could be causing the problem. I think the following is an accurate summary of the changes from the x.264 scratchpad defaults: GOP size increased from 250 to 300 Min GOP size increased from 25 to 29 Weighted prediction for B-frame unchecked Number of B-frames decreased from 3 to 2 B-Pyramid changed from Normal to Disabled Number of Reference Frames changed from 3 to 2 P-frame Weighted Prediction changed from Smart to Disabled Min in Quantizers changed from 0 to 3 Any help would be appreciated. Thanks! [edit] I just noted that while I was posting, Nick (who wrote the tutorial) posted about the same subject: http://forum.doom9.org/showthread.ph...75#post1482275 This isn't exactly a double or cross-post, since we are two different people, and since I am providing a lot more detail, I'll keep my post. I just wanted everyone to make the connection between the two posts.[end edit] Last edited by johnmeyer; 4th March 2011 at 20:55. Reason: added the word "first"; provided link to associated post |
megui |
