19th December 2011, 22:43 | #11565 | Link |
Well Version 0.78 worked for me out of the box on my HD 3400, Version 0.79 didn't. Version 0.80 Worked after 4 hours of continuous tinkering (I even activated settings usually not activated to get smooth playback like overshoot max latency). It works now with all my 720p video only in full screen exclusive mode. Windowed is borked dropped frames, glitches all 9 yards.
Anyone know how I can save the madVR settings? export its registry file? EDIT Recanted. Drops frames as well! EDIT2 I reset settings and deactivated decoding and Use separate device for presentation, lowered GPU queue to 6 and that seems to fixed it. Scaling is set at Bicubic 60 for all. So it seems Auto settings are fracked. EDIT 3 HOLY! the quality is AWESOME with anime Thanks alot Madshi!
Motherboard: GIGABYTE GA-990FXA-D3 Processor: AMD FX 8150 Black Edition 8-core @3.6 Ghz. RAM: G-Skill Ares 16GB dual channel DDR3. GPU: 2X Crossfire AMD RADEON HD 6850. OS: Windows 7 Utlimate x64. Last edited by Paladin77; 19th December 2011 at 23:36. |
19th December 2011, 23:41 | #11566 | Link | |
to 0-2 after a minute or so after starting playback (550 Ti running 7 x64.) I've got it disabled now (It did help with glitches earlier) It's not the only thing causing that, not setting appropriate flush settings after presentation does it too. Setting up FSE optimally can be rather time consuming huh? It seems like I either have to choose between keeping the present and render queues high and not dropping frames but getting the odd presentation error or having the queues drop right down but having zero presentation errors. Finding the sweet spot isn't easy, overshooting the max frame latency does wonders for removing the glitches, if only it didn't drop the present and render queues so much.. Last edited by ryrynz; 20th December 2011 at 05:19. |
20th December 2011, 03:37 | #11567 | Link |
Thanks looking forward to it.
0.80 fixed the black screen/freezes with auto queue with an X2300M. The high priority build worked fine with X2300M and 9500GT in fact it worked a little better then 0.79 with the former gpu, it played 480p with fewer frame drops. |
20th December 2011, 11:46 | #11568 | Link | |
we all know xbmc is the one and only media center to have out there p.s: tiben is working his ass off on this literally so be greatful to his and madshis epic work i know you are as we all are , keep it up madshi and tiben wooot!!! xD |
20th December 2011, 13:34 | #11569 | Link |
XBMC+LAV(Splitter/Video/Audio)+madVR would be so awesome. No longer would I need to invoke an external player. The ultimate Christmas gift!
Just so I am clear, we are not talking the old DSPlayer, we are talking an Eden version right? |
20th December 2011, 13:56 | #11570 | Link | |
20th December 2011, 14:41 | #11571 | Link |
Hi guys,
i was asking for advice about gpu for madvr few days ago. I chose two cards: ATI HD6770 or HD6870 I definitely need one of these, cause sapphire make these models with FLEX support, so no need for expensive active displayport adapter. So the question is, is it worth the plus money to get the 6870? The difference between them here is ~100$ (~30-40%), so pretty big. Will i see any problems (regarding madvr) with the 6770 that i wont with the 6870? Thanks! Last edited by tauka; 20th December 2011 at 14:53. |
20th December 2011, 16:50 | #11572 | Link | |
1. What type of Content do you have? 2. What is your setup like? 3. Did you compare the 2 cards in AMD website? http://www.amd.com/us/products/deskt...verview.aspx#2 vs http://www.amd.com/us/products/deskt...verview.aspx#2 (click on specifications). 4. As far as madVR is concerned: Minimal required specs as mentioned by madshi: - graphics card with full D3D9 / PS3.0 hardware support - at least 128MB of dedicated graphics card memory - Windows XP or newer Finally IMO MadVR should work fine with 6770 (dude I have it working on an HD3430 lol) and if that is ONLY what you will use it for i.e madVR IMHO it really isn't worth the shelling out an extra 100$ if you're on a tight budget UNLESS there is a feature in 6870 (like dual HD bitstreaming) you absolutely must have or it pretains to your setup. I stand corrected if anyone would like to add or amend what I said.
Motherboard: GIGABYTE GA-990FXA-D3 Processor: AMD FX 8150 Black Edition 8-core @3.6 Ghz. RAM: G-Skill Ares 16GB dual channel DDR3. GPU: 2X Crossfire AMD RADEON HD 6850. OS: Windows 7 Utlimate x64. |
20th December 2011, 16:52 | #11573 | Link | |
Buying a 6xxx now, is virtually buying an end-of-market product. |
20th December 2011, 17:02 | #11574 | Link | |
In my opinion 6770 is strong enough. I have HD5750 which is weaker and I manage to run MADVR with Lav Codec + Raw ffdshow with frame doubling script in avisynth and I watch 1080p/Bluray movies on my 42inch full HD TV .I play movies in 1080p24 resolution And never had any dropped frames even with Lancroz 8 scalling which should be the heaviest resizer. Oh and I also use YCMS . So if you don't play very heavy games even 6770 is enough. Maybe it worth for you to wait a little for the HD 7000 series or Geforce 600 Series. My system is: Quadcore q6600 (weakest quadcore cpu) 6GB ram that runs on 667 Mhz (not much) ATI HD 5750 |
20th December 2011, 17:46 | #11575 | Link |
I have tested also setup with HD6570, i5 SandyBridge and it works fine also with Lanzcos scalers, CPU utilisation was 20percent, GPU load 35percent.
Giving out that HTPC as a gift under the christmas tree. Tuned XBMC with MPC-HC, LAVfilters and MadVR. Remote included. And lot of work from our programming guys included as well..Thanks!
__________________ System: Intel Core i5-6500, 16GB RAM, GTX1060, 75" Sony ZD9, Focal speakers, OS Win10 Pro, Playback: madvr/JRiver |
20th December 2011, 19:10 | #11576 | Link |
Yeah, i definitely need a gpu for all kind of material (full blurays, and 720@60 materials), so thats the reasoning behind a strong gpu. my hd3850 cant handle these now. (with core2duo e6750)
yeah, but next gen will be pricy at first, and i need a card now, not at the end of Q1 of '12 thanks for te info. spared money can go to a hdmi switcher |
20th December 2011, 19:59 | #11577 | Link |
If you're not an insane gamer (I hope you didn't get an arrow to the knee as well). Get the 6 series for your content. Otherwise if games are part of the equation. wait for the next gen or get the high end hd 6990
20th December 2011, 20:10 | #11578 | Link |
Actually, I used to be an insane gamer. But then I took an arrow to the knee.
SETUP: Win 10/MPC-HC/LAV/MadVR HARDWARE: Fractal Design Node 804 | Xeon E3-1260L v5 | Supermicro X11SSZ-TLN4F | Samsung 2x8GB DDR4 ECC | Samsung 850 EVO 1TB | MSI GTX 1650 Super | EVGA G2 750 |
20th December 2011, 20:11 | #11579 | Link |
I think there should be a configuration utility included with madVR to tweak all the settings GPU related. Honestly I'm fed up wit tweaking madVR so it won't drop frames. I set it to auto and it sets the GPU queue to 4, sometimes 5, sometimes 12 and then it works fine for an hour and after that it says the memory is 100MB over how much the card has. Then it brings it down to 4 and it starts dropping frames every 5 seconds. On top of that the refresh rate frame drop/repeat calculation is never steady and goes from seconds to minutes to hours and back to seconds. This is on two different computers with two completely different configurations in terms of CPU, RAM, GPU, and GPU RAM.
