26th November 2008, 15:55 | #4941 | Link | |||
While the above answer was dated since September... Quote:
26th November 2008, 18:01 | #4942 | Link |
Hi people!
I have a problem with DXVA. Link: http://www.sendspace.com/file/gfihhl Watch original_sample.avi first, then stutter_sample.avi (this is what I see). As I see it, x264 doesn't do well with the avi container in dxva (mode or whatever it's called). I know that you shouldn't use avi for x264. Even if I extract the raws and put it in mkv it doesn't help. And if you look at sample_filters.png you can see that I use EVR Custom, and that is when the stuttering appears. If I use system default the problem goes away (dxva isn't in use). The sample is from [Nya] Osen Ep. 6 (1280x720) (it's a japanese tv-series). Sorry about the ranting but I hope someone can give me an answer to why this is happening maybe and/or a solution It's greatly appreciated! Last edited by Moodilic; 26th November 2008 at 18:34. |
26th November 2008, 23:26 | #4946 | Link |
MPC-BE DEV
Media Player Classic HomeCinema (x86), svn 906
Media Player Classic HomeCinema (x64), svn 906 Supported languages: CN, CZ, DE, ES, FR, HU, IT, KR, PL, RU, SK, TR, UA Changes log Updated FFmpeg; Update Traditional Chinese translation.
Win11 x64, i7 8700K 5Ghz, ASUS MAXIMUS X HERO, G.Skill (2x8GB) Trident Z F4-3600C16D-16GTZ, RX 5700,TV Philips 43PUS6703/12, Zappiti 4K HDR Media Player Classic - BE x86/x64. Team of developers. |
27th November 2008, 01:17 | #4947 | Link |
Couple of small problems with an otherwise brilliant media player
(i) I have been unable to play any .flac files for a while with various svn of MPC-HC, I just get "cannot render the file". It is possible I changed a setting that has broken it but I don't know what so I'd appreciate a tip to fix this as it is just about the only filetype that doesn't work. also (ii) if I associate a filetype handled by haali splitter in MPC-HC options it seems to break haali thumbnail extraction for videos- is there a way to get round this- does MPC-HC have a thumbnail extraction ability or one in development? Last edited by jos99; 27th November 2008 at 01:20. |
27th November 2008, 03:26 | #4948 | Link | |
Chumbo |
27th November 2008, 06:11 | #4949 | Link |
About 50% of the time, whenever I drag/drop a .m2ts (1080p AVC) file into MPC-HC (x64 r906) while a file is playing, MPC-HC crashes with a C++ Runtime error.
Edit: Another bug. With DXVA enabled, one of my 1080p AVC .m2ts files is decoded incorrectly but ffdshow displays it just fine. (Hard to get a frame accurate comparison because MPC-HC is also blending a previous frame.) I can upload a sample if needed. Last edited by Snowknight26; 27th November 2008 at 06:30. |
27th November 2008, 06:55 | #4950 | Link | |
Solaris: burnt by the Sun
*longer than it takes me to shower and make coffee |
27th November 2008, 12:33 | #4955 | Link | ||
MPC-HC 2.1.7.2 |
27th November 2008, 17:16 | #4956 | Link | |
Otaku
Seems that haali uses the settings in reverse from EVR (that goes from "-0.60" to "-1.00", soft to sharp) Your statement was corret.
In the school, the three guys met. Their relation had been changed in the season, and turned into three love stories.
27th November 2008, 17:37 | #4957 | Link | |
thanks for your opinion and answering my question! Last edited by Steveo08; 27th November 2008 at 17:40. |
27th November 2008, 20:10 | #4958 | Link | ||
27th November 2008, 21:50 | #4960 | Link |
Any idea why the Standalone Filter fails rendering on NULL within timecodec ?
http://forum.doom9.org/showpost.php?...postcount=5312
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 |
