28th August 2010, 14:36 | #12281 | Link |
Hi albain.
There is crash in ff_samplerate.dll possibly related to revision 3501. See page 613, posts by me and 27049215: http://forum.doom9.org/showthread.ph...31#post1426231 |
29th August 2010, 05:26 | #12282 | Link |
Is it possible to add MPEG-4 ALS support in FFDShow? Since revision 20517 ffmpeg can decode it. There's also the issue of a splitter capable of demuxing and feeding the audio stream correctly, so actually adding support in FFDShow isn't enough I suppose but it would be nice to have ALS under directshow.
30th August 2010, 14:47 | #12283 | Link | |
Media Control author
Hi, I can't reproduce the problem. Do you have a sample file ? Which splitters are you using ? which player ? |
30th August 2010, 17:59 | #12285 | Link | |
Software Developer
Albain:
I've had it set to not show the tray icon at all and the option to show internal filter in the tray icon was not enabled. I tried enabling the tray icon and then when playing a media file, right clicking the tray icon threw this error: Quote:
I'm calling QueryInterface before the graph is running (filters are added to the graph and connected), does this make a difference? I'm on Windows 7 Pro 32bit and set the ffdshow tray icon to always show in the tray. Still using the same CLSID build. |
30th August 2010, 19:11 | #12286 | Link | |
I watch using Zoom Player, navigate file using mouse wheel. Audio is resampled from 44.1Khz to 48KHz using libsamplerate high. FLV splitter 1.3.2099 from MPC-HC project. |
31st August 2010, 08:40 | #12287 | Link |
Hi.
Since LAVF splitter introduced very good MOV splitting, all my *.MOV samples plays using FFDshow except one with "twos" audio inside. Sample is here. Here is what MediaInfo say: Code:
Audio ID : 2 Format : PCM Format settings, Endianness : Big Format settings, Sign : Signed Codec ID : twos Duration : 2s 0ms Bit rate mode : Constant Bit rate : 256 Kbps Channel(s) : 1 channel Sampling rate : 16.0 KHz Bit depth : 16 bits Stream size : 62.5 KiB (1%) Language : English Encoded date : UTC 2010-03-17 22:55:13 Tagged date : UTC 2010-03-17 22:55:13
Working machine: Win10x64 + Intel Skull Canyon My HTPC. How to start with Bitcoin |
31st August 2010, 09:18 | #12288 | Link |
hoborg's post reminds me on a similar issue we have discussed in the german doom9/Gleitz board: MOVs with "twos" audio don't play in MPC-HC. Because MediaInfo reports them as PCM, I wondered if it was possible to hex-patch the Codec ID to something more compatible, but I had no idea which alternative FourCCs for PCM audio might exist in QuickTime... "Simply" recognising it as compatible PCM format would of course be a more convenient solution.
31st August 2010, 12:12 | #12291 | Link |
Yes, MPC-HC will use Quicktime frameworks to play MOV file. Open it in Graphstudio and LAVF as splitter - FFDShow audio decoder refuse to connect.
31st August 2010, 13:14 | #12293 | Link | |
The problem is that MP4 splitter failed to split some MOV samples i have - there is no audio output PIN, but working fine with LAVF as splitter :/
31st August 2010, 13:35 | #12295 | Link | |
The fact that the graph is not running shouldn't have any effect |
31st August 2010, 17:04 | #12296 | Link | |
4:2:0 hater
1st September 2010, 00:04 | #12297 | Link | |
@albain it seem you missed my previous post.
1st September 2010, 12:49 | #12298 | Link |
The default matrices in mixer do not seem to be correct.
For example for 5.1 to 2.0 it uses 0.707 for both center and LFE. However, the LFE channel is supposed to be played 10dB louder than other channels. Is it a bug or does ffdshow compensate for this somewhere else? |
1st September 2010, 13:00 | #12299 | Link |
Software Developer
Small feature request:
Accept video decoder pin connections for the "{72707A61-0000-0010-8000-00AA00389B71}" sub-type exposed by the microsoft AVI splitter. You already support decoding this video format when the "QTRpza" sub-type is used for connection (exposed by 'haali media splitter' for the same file). Here are some sample files: http://samples.mplayerhq.hu/V-codecs/RPZA/ (i couldn't find a splitter for the MOV files, but the jumping.avi file can be used as a test case) Albain: Here's my entire process for getting the stream info: 1) I enum all the filters in the graph. 2) For each filter in the graph, I call: Code:
// dsStreamFilter is an IBaseFilter class If dsStreamFilter.QueryInterface(IID_IAMStreamSelect, dsStreamSelect) = S_OK then // dsStreamSelect is an IAMStreamSelect class Begin dsStreamFilter.GetClassID(dsFilterGUID); If (IsEqualGUID(dsFilterGUID,CLSID_FFDShow) = True) then Begin If dsStreamSelect.Count(StreamCount) = S_OK then // This call throws the StackOverflow exception, StreamCount is a DWord. Begin End; End; dsStreamSelect := nil; // removes the reference count and frees the object End; Am I doing something wrong? Last edited by Blight; 1st September 2010 at 13:03. |
1st September 2010, 14:07 | #12300 | Link | |
4:2:0 hater
