23rd June 2017, 18:03 | #2181 | Link |
It starts now always a new instance and every instance runs only one job and runs then a new instance in case there are more jobs, it was changed because if memory issues. You still can start multiple instances side by side of course.
23rd June 2017, 21:29 | #2183 | Link |
I see that as of 1.5.1.1 there is support to pre-render to a lossless AVI. I believe this is regarding the request to save the filter output as it is processed on first pass when doing a 2 pass encode or multi-pass encode. I don't see how to use the feature. And I did read the help files but didn't see it mentioned. Where are the controls for this located, or how do I activate it?
24th June 2017, 05:28 | #2184 | Link |
It's at: Options > Video > Pre-render...
24th June 2017, 17:03 | #2185 | Link |
NVEncC 3.13
- add deband filter (--vpp-deband) - fix --vpp-perf-monitor not working - fix crop issue when using cuvid decode --vpp-deband [<param1> = <value>] [, <param2> = <value>] [...] Parameters: Range = <int> (default = 15, 0 - 127) It is a blurring range. We take samples from neighboring pixels within this range and perform blur processing. Mode = <int> (default = 1, 0-2) Setting value: 0 Processing is performed while referring to one peripheral pixel and maintaining the original pixel value. Setting value: 1 Blur processing is performed by referring to two pixels in total, one pixel at the periphery and its point symmetric pixel. Setting value: 2 Blur processing is performed by referring to a total of 4 pixels including 2 peripheral pixels and their point symmetric pixels. Thre = <int> (collective setting) Thre_y = <int> (default = 15, 0 - 31) Thre_cb = <int> (default = 15, 0 - 31) Thre_cr = <int> (default = 15, 0 - 31) Y, cb, cr The threshold of each component. If this value is high, while reducing the gradation skipping, fine lines and others will collapse. Dither = <int> (collective setting) Dither_y = <int> (default = 15, 0 - 31) Dither_c = <int> (default = 15, 0 - 31) Y, cb & cr's dithering strength. Seed = <int> Change of random number seed (default = 1234) Blurfirst (default = off) By reducing the dither intensity by blur processing first, we will raise the effect with the material with many gradation skipping. Overall side effects become stronger and fine lines are more likely to collapse. Rand_each_frame (default = off) Change the seed value of each frame. Example: --vpp-deband range = 31, dither = 12, rand_each_frame |
24th June 2017, 18:11 | #2186 | Link |
@mcjordan
Good you posted this not an hour later. Requirements .NET 4.7 is required on systems prior Windows 10 Version 1703 (Creators Update) https://www.microsoft.com/en-us/down....aspx?id=55170 Download https://drive.google.com/open?id=0B-...ld4dzhuTC1WWWM https://onedrive.live.com/redir?resi...nt=folder%2c7z 1.5.1.3 unstable test build
24th June 2017, 18:57 | #2187 | Link |
The deband GUI was kind of half baked (built in 20 minutes) so I uploaded it again as 1.5.1.4.
25th June 2017, 10:21 | #2190 | Link |
It's created in the temp folder but copied to the target file folder before the temp folder gets deleted.
In the next build you can create a powershell script called JobEncoded.ps1 with following code: Code:
# active project $p = [ShortcutModule]::p $logFilePath = [System.IO.Path]::GetDirectoryName($p.TargetFile) + "\" + $p.Name + "_staxrip.log" if ([System.IO.File]::Exists($logFilePath)) { [Microsoft.VisualBasic.FileIO.FileSystem]::DeleteFile($logFilePath,'OnlyErrorDialogs','SendToRecycleBin') }
25th June 2017, 12:34 | #2192 | Link | |
Err......sounds a bit too complicated........ I prefer previous behavior where the log get automatically deleted together with Temp directory once transcoding is successful. |
25th June 2017, 12:43 | #2193 | Link |
@Taurus
It was a string processing miss probably introduced while increasing decimal digits. @JohnLai I can change it to be saved under Settings/Logs, there is a ticket about it: https://github.com/stax76/staxrip/issues/166
25th June 2017, 13:09 | #2194 | Link | |
Back in my younger day when I used Handbrake, my dad asked me why I transcoded several 18+ videos after he looked into handbrake logs directory. Didn't realize that damned handbrake store transcoding log at %appdata%. ~.~"" |
25th June 2017, 16:17 | #2196 | Link |
Feature request:
Possible to start 2 audio transcoding at once? I have few China dramas with multiple audios. Cantonese, dubbed English and Mandarin audios Currently, staxrip is transcoding audio one by one. Since audio transcoding kinda uses one CPU core and it takes quite a while by transcoding audio one by one....is it possible to start multiple audio transcoding simultaneously and after that, starts video transcoding? |
25th June 2017, 16:32 | #2197 | Link | ||
26th June 2017, 12:26 | #2198 | Link |
Noob
errors encoding using 2.4.87 https://pastebin.com/P2DXgjPg. everything is fine in 2.4.74.
i tested using http://www.mediafire.com/file/v7xdau...b8fa.GCC710.7z and http://msystem.waw.pl/x265/x265-2.4+...gcc71-SSE41.7z |
26th June 2017, 14:00 | #2200 | Link | |
