Old 13th February 2015, 19:51   #2421  |  Link
Selur
Selur's Avatar
Why would you want to lower it to zero? (fixed locally)
Old 13th February 2015, 21:36   #2422  |  Link
gambit19
i downloaded yesterday a couple of recent version of hybrid but i am not able to open it, it always gives me error about not being able to find QSVEnc but i can clearly see it in the hybrid folder, any ideias what this might be, I am running windows 8.1?
Any idea when you might incorporate the new hvec 1.5?
gambit19 is offline   Reply With Quote
Old 14th February 2015, 06:54   #2423  |  Link
Selur
Selur's Avatar
never heard of it until now, so without a link no clue what you are speaking of.
Or do you mean x265s latest release? (Hybrid should already support everything that is included in the 1.5 release)
a. What does the error message say. There shouldn't be an error message.
b. QSVEnc might require more up-to-date Intel drivers.
Cu Selur
Old 14th February 2015, 18:57   #2424  |  Link
legend
My source file is DTS 6CH....How Do I encode from DTS 6 Channel to 2 channel aac HE audio..
legend is offline   Reply With Quote
Old 14th February 2015, 20:29   #2425  |  Link
Selur
Selur's Avatar
  1. make sure you got a aac encoder which support AAC encoding (Hybrid supports Nero AAC, Qaac, FHG, FDK), see: *hidden* Hybrid options,...->Additional aac encoders
  2. enable Audio->Main->Reencode
  3. set "Audio->Main->Audio Encoding Options->Audio format" to 'aac'
  4. select the aac audio encoder you want "Audio->Main->Audio Encoding Options->Nero AAC/Qaac/FHG/FDK"
  5. select "Audio->Main->Audio Encoding Options->Audio format->aac" + 'high efficency"
  6. select "Audio->Main->Filtering"
  7. set "Audio->Main->Audio Filtering->Downmix" to one of the 'toStereo ...' modes
  8. add your audio stream to the audio queue
Old 15th February 2015, 05:46   #2426  |  Link
Gravitator
Still there 40,30,20,10
Will add support NVEnc - HEVC? > https://onedrive.live.com/?cid=6BDD4...5AC8933C6!2293
With this forum > http://x265.ru/f/viewtopic.php?f=2&t=7
Gravitator is offline   Reply With Quote
Old 15th February 2015, 12:53   #2427  |  Link
Selur
Selur's Avatar
ah, didn't know rigaya made a standalone binary.
Thanks for the info, will look into it.
will be included in the next public release
Old 15th February 2015, 13:16   #2428  |  Link
Selur
Selur's Avatar
@Music Fan:you PM storage is full -> the verison.txt and the dll belong to the avisynth extension so if you disabled the avisynth extension those two files are not needed.
@Gravitator: looked into NVEncC and support for it will have to wait a bit since I don't own a graphic card which supports H.265 encoding through it. It requires a Maxwell NVIDIA cards iirc. and since my current Geforce GTX 660ti is working fine and will probably be enough for me for the next few month I doubt that NVEncC H.265 support will come anytime soon.
(tried to test NVEnC on my 660 ti, but it caused my whole system to crash!)
Old 16th February 2015, 12:51   #2429  |  Link
legend
Using this software couple of days. It's really quite satisfactory. Still have some question.
1. If I give target file size But the output filesize did not get properly. for example If I input target size 700mb after encode output size I get 745 or 746Mb. So How Do I get actual output file size like 700MB or 800MB.
2. How do I create sample file from my encoding setting before full size encoding.
Old 16th February 2015, 18:21   #2430  |  Link
Selur
Selur's Avatar
regarding 1.: details -> no clue how to answer, only general tip: "use 2pass encoding" if the encoder supports it + don't use vp8 or vp9 if you want to hit a file size
regarding 2.: you can enable the cut support if you only want to encode a part of your source (Config->Internals->Cut Support))
Old 20th February 2015, 20:21   #2431  |  Link
HeadFi
HeadFi's Avatar
hi
Hi. I'm getting an error while trying to open hybrid saying :"Disabled avisynthsupport,since the version file is not present.You need to update the avisynthExtenions addOn"
Anyone knows what it might be?
HeadFi is offline   Reply With Quote
Old 21st February 2015, 09:01   #2432  |  Link
Selur
Selur's Avatar
That happens if the version file inside the avisynthPlugins folder isn't present.
Did you install Hybrid with the installer ?
Did you modify any options inside the installer ? (normally the defaults are the best)
Old 21st February 2015, 16:52   #2433  |  Link
Pat357
To use NVencc exe, you need to have the NVidia drivers 347.09 or later installed. It will hang with any older drivers.
Try to use "NVencc --help" and "NVencc --check-hw" and "NVEncC --check-features".
It will do only h264 encoding by ASIC on your Keppler, because your card doesn't have a hardware H265 encoder. The newer GM220 based cards can also do H265 encoding
Just fwiw, it works fine on my GTX 680 (347.25 drivers), which has the same hardware encoder as your 650ti : around 100fps (!) for 1080p encoding with only about 10% CPU load !
"NVencc --check-features" gives me :
Environment Info
OS : Windows 7 (x64)
CPU: Intel Core i7 970  @ 3.20GHz (6C/12T)
GPU: GeForce GTX 680 (8 EU) @ 1084 MHz (347.25)
RAM: Total 24567 MB / Used 7728 MB
: H.264/AVC
Max Bframes               4
RC Modes                  63
Field Encoding            1
MonoChrome                0
FMO                       0
Quater-Pel MV             1
B Direct Mode             1
CABAC                     1
Adaptive Transform        1
Max Temporal Layers       0
Hierarchial P Frames      0
Hierarchial B Frames      0
Max Level                 51
Min Level                 1
4:4:4                     0
Max Width                 4096
Max Height                4096
Dynamic Resolution Change 1
Dynamic Bitrate Change    1
Forced constant QP        0
Dynamic RC Mode Change    0
Subframe Readback         0
Constrained Encoding      0
Intra Refresh             1
Custom VBV Bufsize        1
Dynamic Slice Mode        1
Ref Pic Invalidiation     1
PreProcess                0
Async Encoding            1
Max MBs                   65536
MAX MB per sec            983040
Lossless                  0
Pat357 is offline   Reply With Quote
Old 23rd February 2015, 15:13   #2434  |  Link
Ajvar
Just a tiny bug report. My Desktop Folder location is changed by default but when I install Hybrid it creates a folder called Desktop in Profiles/My profile/ and creates a shortcut there.
Ajvar is offline   Reply With Quote
Old 23rd February 2015, 15:17   #2435  |  Link
Selur
Selur's Avatar
Seems to be a problem with NSIS (Nullsoft Scriptable Install System) so the best way to avoid the problem is to not tell the installer to create a shortcut.
Old 24th February 2015, 02:04   #2436  |  Link
Ajvar
OK, I won't. Just Hybrid is the only one which does this (I recall one or 2 programs which did same in the past) and wanted to notify. For me it is not a big problem.
Old 24th February 2015, 07:17   #2437  |  Link
Selur
Selur's Avatar
Problem is I'm no NSIS-Master and I have no clue why it does this,... (script looks fine: http://pastebin.com/7UxbcRMx)
Only way to fix this atm. seems to be to not create a shortcut.
Old 28th February 2015, 06:20   #2438  |  Link
kide13
Hello, sorry for my bad english.
Thanks you Selur ! the dream come true ! all the stuff i needed
I don't want to offend you but to be honest, it's probably the worst design i ever seen
For better readability i suggest to use some human standards (size, color, font type, icons, align), at least you tried with some icons but they are so ugly :/ i like only the Paypal button
Readability and Ergonomics are scientific disciplines, it's not easy and require a lot of time. So i can't blame you.
But nevermind, Hybrid is the tools paradise !
Now i'll easily convert all my tv shows and movies to x265 60fps !
kide13 is offline   Reply With Quote
Old 28th February 2015, 11:32   #2439  |  Link
Selur
Selur's Avatar
Read this, especially the styling part of 'Command Line Interface (CLI)' and 'misc.ini options' around font size.
-> You can adjust a lot through styling&co, but personally I like the way it is and so I won't change it.
+ When I look at latest Mac OS X, Windows 8 and Linux Unity I'm really no friend of what nowadays is considered a 'good' design.
Old 28th February 2015, 19:08   #2440  |  Link
kide13
ok cool, but i think i can't reorganize categories ?
example, imagine this is tabs:
Set - Jobs - Log - Config
└ File - Video - Audio - Subtitle - Chapter
░░░░░░░░░└Codec - Picture - Filtering
Blue group is how a nfo is organised. I think it's more user friendly.
it's just an example but i would reorganise a lot of elements in Hybrid if it is possible. I can use any programming languages if needed.
Selur
