Old 23rd May 2003, 21:42   #81  |  Link
trbarry
trbarry's Avatar
Yes - BSR is VectorPath, and executes in at least 10 cycles. Furthermore the code isn't pairable at all, leaving 2 of the three pipes unused.
Sh0dan -
I don't know what VectorPath is, but I assume it's costly from the rest of it.
What do you think of requiring SSE instead of SSEMMX for those 2 functions of mine that need bsr? That should eliminate the Athlon's but accept P3 & P4. And it's a one line change.
- Tom
trbarry is offline   Reply With Quote
Old 23rd May 2003, 21:59   #82  |  Link
sh0dan
Retired AviSynth Dev ;)
sh0dan's Avatar
VectorPath is AMD's word for complex "emulated" instructions, that usually requires several cycles to decode and execute.
Nic's Athlon XP has SSE, so it will be used there.
It is however impressive that the "if" code can execute faster than the assembler.
Regards, sh0dan // VoxPod
sh0dan is offline   Reply With Quote
Old 24th May 2003, 05:21   #83  |  Link
trbarry
trbarry's Avatar
It's more than impressive. It's totally frelling mind boggling. But it is true that the if/else logic usually falls out after the first 1 or 2 tests on normal data, so it's nowhere near as bad as it looks.
- Tom
Old 24th May 2003, 11:27   #84  |  Link
Nic
Ok, I released 1.06 for now. (releasing it as 1.05 might have caused confusion)
@Tom: Has your block decoding optimisations for sse2 only for now, hope thats ok.
All seem good to you?
-Nic
Nic is offline   Reply With Quote
Old 24th May 2003, 13:29   #85  |  Link
DDogg
Retired, but still around
DDogg's Avatar
mpeg2source("D:\mymovie.D2V",idct=6) returns:
MPEG2Source:IDCT invalid(1:mmx,2:SSEMMX,3:FPU,4:REF;5:SSE2)
DDogg is offline   Reply With Quote
Old 24th May 2003, 13:46   #86  |  Link
AmiRage
Same here for idct=7 also.
AmiRage is offline   Reply With Quote
Old 24th May 2003, 14:29   #87  |  Link
cult
cult's Avatar
where is it?I cant see any attachment
cult is offline   Reply With Quote
Old 24th May 2003, 14:32   #88  |  Link
ARDA
First post of this thread
Arda
ARDA is offline   Reply With Quote
Old 24th May 2003, 14:33   #89  |  Link
Nic
Sorry didn't check marcfd's override param, I always change it in the d2v...ill go ammend that now..
-Nic
edit:
Ok, that bugs fixed, please re-download:
(updated links always at start of thread)
http://nic.dnsalias.com/MPEG2Dec3v106.zip
SourceCode:
http://nic.dnsalias.com/MPEG2Dec3v106_src.zip
pps
BTW: Skal's iDCT is faster, but only slightly, you may not notice a difference, but its the fastest iDCT ive ever seen, so its included for completeness
Old 24th May 2003, 15:32   #90  |  Link
HarryM
Originally posted by Nic
pps
BTW: Skal's iDCT is faster, but only slightly, you may not notice a difference, but its the fastest iDCT ive ever seen, so its included for completeness [/B]
@Nic: Can you add Skal's code into your MpegDecoder?
HarryM is offline   Reply With Quote
Old 24th May 2003, 17:41   #91  |  Link
lighty
AFAIK- he already did include it as he said in the previous post.
lighty is offline   Reply With Quote
Old 24th May 2003, 19:33   #92  |  Link
Ctrl-Alt-Suppr
Are you sure ?
DVD zone2 : BLADE ( 3 min ) ~ Asus P4G8x ~ P4 2.532.89 ~ 512mo
AviSynth 2.51 RC4 ~ Xvid's Koepi 14/05/2003 ~ VDubMOD 1.4.13 v2 (for debug .log)
MPEG2Source("D:\...\.d2v",idct=X ).Crop(4,72,-8,-76).Trim(99500,104000)
BicubicResize(608,256,0,0.5)
idct=1 ___ 83 sec ___ 54.22 fps ___ 34.9 mo
idct=2 ___ 82 sec ___ 54.88 fps ___ 34.9 mo
idct=3 ___ 89 sec ___ 50.56 fps ___ 34.9 mo
idct=4 ___ 133 sec ___ 33.83 fps ____ 35 mo
idct=5 ___ 80 sec ___ 56.25 fps ___ 34.9 mo
idct=6 ___ 82 sec ___ 54.88 fps ___ 34.9 mo
idct=7 ___ 86 sec ___ 52.33 fps ___ 34.9 mo
~~~~~~ AviSynth's Guide : ~~~~~~
http://avisynth.unite-video.com/
~~~~~~ French Forum : ~~~~~~
http://unite-video.com/phpbb/portal.php
Ctrl-Alt-Suppr is offline   Reply With Quote
Old 24th May 2003, 19:41   #93  |  Link
HarryM
Are you sure ?
You have SSE2.
I have AthlonXP and idct=6 (Skal's SSEMMX) is about +2% really faster than idct=2 (SSEMMX) for me.
Of course - without Crop, Trim, etc. and with 'null - test speed' in xvid.
Old 24th May 2003, 19:43   #94  |  Link
HarryM
@Nic:
Skal's SSEMMX idct is more accurate than FPU 64bit idct?
Old 24th May 2003, 22:17   #95  |  Link
Sigmatador
Posts: n/a
we need someone with a 64bits processor
Old 24th May 2003, 22:24   #96  |  Link
JohnMK
Is there a way to force an idct by placement of some kind of overriding text file with your preferred idct in the same dir as mpeg2dec3? I don't like the idea of tinkering with my .d2v, I'd rather have an automated solution for the future. The older versions used to have this feature . . . .
JohnMK is offline   Reply With Quote
Old 25th May 2003, 07:30   #97  |  Link
HarryM
Mpeg2Source("...", idct=6)
Old 25th May 2003, 09:12   #98  |  Link
Nic
@ctrl-alt-supr: "Are you sure?"
I did write for a reason:
"Skal's iDCT is faster, but only slightly, you may not notice a difference, but its the fastest iDCT ive ever seen, so its included for completenes."
And yes I am sure.
-Nic
Old 25th May 2003, 12:10   #99  |  Link
killingspree
Newbie Forum Mod
killingspree's Avatar
wow... you got me confused now (:
what's supposed to be faster on a PIV now? idct=5 or 6?
regards
steVe
Search the forum, read the forum rules once more and use the search function on doom9.org before posting!
oh btw my amazon.de wishlist
killingspree is offline   Reply With Quote
Old 25th May 2003, 12:34   #100  |  Link
Nic
@killingspree: Hmmm, 5 (SSE2) probably will be, for now I wouldn't start using 6. The speed difference is small and I havent tested it fully yet.
(when I tested it, I just left it doing random iDCTs and comparing it to other iDCTs, and it is faster, but it seems in MPEG-2 Decoding it doesnt make any real difference, still its there for completeness, ill test its accuracy properly soon)
-Nic
ps
Im almost tempted to use 7 (simpleidct) myself...even though tests have shown that iDCT accuracy doesn't seem to make any real kind of a difference to the eye when mpeg-2 decoding, maybe it will make a difference to the encoder (even if very very tiny)...Hmmm, I may have to check.
