Old 4th July 2016, 23:26   #38481  |  Link
nevcairiel
Originally Posted by Xello View Post
Yes I thought that was odd when i looked at the spec sheet, as this is a gsync monitor so it supports all refresh rates from 1 to max (165 in this monitor's case).
Actually G-SYNCs minimum refresh is 30Hz, if your FPS drops below that it internally switches to something similar to ordinary VSYNC.
Most screens even have a higher minimum refresh above that due to panel requirements, typically in the 40Hz range somewhere.
Old 4th July 2016, 23:37   #38482  |  Link
Xello
Gotcha, MadVR is reporting correctly though right?
https://dl.dropboxusercontent.com/u/...4/asus24hz.png
Xello is offline   Reply With Quote
Old 4th July 2016, 23:43   #38483  |  Link
Asmodian
Actually that isn't how it works. The module in the monitor starts duplicating frames internally in a predictive manner, so it starts duplicating when the frame rate drops below something a bit above 30 so it almost never has to use the V-sync like mode, unless the frame rate fluctuates in a way it wasn't expecting. All G-sync displays I have seen have a min refresh rate of 30Hz but the Freesync displays often use something higher (35-47).
The G-sync refresh rates have nothing to do with what modes the monitor will accept however, that is still up to the EDID info like always.
My XB270HU has a 24Hz mode over displayport, so madVR will happily switch to 2560x1440p23, but it has the same min G-sync rate of 30Hz.
Personally I suggest setting your monitor to 165Hz and using smooth motion, no messing with things and having the monitor changing modes, the blended frames will not be onscreen long.
Odd, my list of refresh rates looks similar to yours (only missing the 165Hz option) but madVR will happily switch to 2560x1440p23. I am running Win10 pro x64.
madVR is reporting correctly, I assume the monitor is duplicating the frames internally.
madVR options explained
Old 4th July 2016, 23:46   #38484  |  Link
Xello
Sigh..................
I was setting the display modes....................
Of my old display...................................
Just..............
Working fine now.
BTW that smooth motion suggestion made me vomit :P But I see your logic so might as well see what it looks like.
edit: doesn't look bad actually, I thought it was gonna cause the soap opera effect
Old 5th July 2016, 01:23   #38485  |  Link
Asmodian
Just..............
Working fine now.
MadVR's smooth motion is not frame interpolation, it works very well on high refresh rate displays without changing the frame rate of the source. It is nothing like all the new motion interpolation modes on TVs or SVP, etc.
Old 5th July 2016, 01:50   #38486  |  Link
Magik Mark
Why is it madvr reports my display refresh rates as 23.970 and my source filter (LAV) reports it as 23.976? Is there a way to correct this?
Aora Master - Intel i9 - RTX 2060 - DDR4 24GB Predator - LG OLED C9 - Yamaha A3030 - Windows 10 x64 - Kodi with DSplayer - Lav - MadVR
Magik Mark is offline   Reply With Quote
Old 5th July 2016, 02:29   #38487  |  Link
a custom resolution can change that. but if you are aiming at 23.976 than you are just wasting your time.
Old 5th July 2016, 07:07   #38488  |  Link
Asmodian
I have never been able to tune an Nvidia GPU to exactly 23.97602, or even that close.. the steps when creating a custom resolution were about 0.004 Hz, if I remember correctly.
Old 5th July 2016, 12:18   #38489  |  Link
chros
chros's Avatar
Originally Posted by Sunset1982 View Post
I'll get my hands on a GTX 1070 and an AMD RX480 at the end of the week. I'll compare their madvr performance against each other an will post the results here.
Anyone got some wishes or suggestions you'd like me to test?
My priority will be upscaling 1080p to 4k...
Thanks for the offer!
1. It'd be nice to see the power consumption of these cards during playback. (You can get a cheap power consumption meter with LCD display (for about 10 euros) and plug it in its own socket and read/take a note the values during test.)
2. Regarding to the 1st point, it would be also nice that you can try out these kind of sources:
- 720p h.264
- 1080p h.264
- 1080p h.265
- 2060p h.264
- 2060p h.265
Thanks
Ryzen 5 2600,Asus Prime b450-Plus,16GB,MSI GTX 1060 Gaming X 6GB(v385.28),Win10 LTSB 1607,MPC-BEx64+LAV+MadVR,Yamaha RX-A870,LG OLED65B8(2160p@23/24/25/29/30/50/59/60Hz)
Old 5th July 2016, 12:19   #38490  |  Link
chros
chros's Avatar
Or if you can't use close enough value then use 24p instead of 23p with madVR. (That's what I'm doing.)
Old 5th July 2016, 15:30   #38491  |  Link
CarlosCaco
In your optimus system hdmi outputs by intel or nvidia?
Desktop, i5 2500, 8GB, N570 GTX TF III PE/OC
Asus X555LF, i7-5500U, 6GB Ram, Nvidia 930m/HD 5500
Windows 8.1 Pro x64
CarlosCaco is offline   Reply With Quote
Old 5th July 2016, 16:00   #38492  |  Link
Sunset1982
did some quick testing with my new amd rx480...
my first observations:
compared to my gtx970 I save about 3-6 ms through different tests with different settings.
rx480 gets a bit noisy when stressed with high settings
cant get 4K, HEVC, 10 Bit, HDR files running. Getting green screen. worked with gtx 970.
render ques are stable at 7-8/8 with copyback. Saw some quick jumps to 4-7/8 and back every 1-2 mins, but no dropped frames or glitches. Tested with crimson 6.2.2
Tomorrow I'll get my hands on a gtx1070. I will post the results of the complete test friday.
Intel i5 6600, 16 GB DDR4, AMD Vega RX56 8 GB, Windows 10 x64, Kodi DS Player 17.6, MadVR (x64), LAV Filters (x64), XySubfilter .746 (x64)
LG 4K OLED (65C8D), Denon X-4200 AVR, Dali Zensor 5.1 Set
Sunset1982 is offline   Reply With Quote
Old 5th July 2016, 17:12   #38493  |  Link
kanade
Hey madshi, I'm not able to send the crash report via error dialog to you as I keep getting this error message:
I also didn't get bug report text file after closing the error dialog.
kanade is offline   Reply With Quote
Old 5th July 2016, 19:39   #38494  |  Link
aufkrawall
Probably GCN's madVR performance is a bit higher than the average of most games (or you have to take very GCN friendly games for comparing)?
I'd say my R9 390 can also cope really well compared to my previous GTX 980 OC.
With DXVA2 (CB) or even with software decoding?
In both cases I'd say: outsh!
Polaris driver totally bugged?
Cool, thanks. I'm having those jumps very often with 1080p 60fps with Hawaii. Present queue with GTX 980 was totally stable (if driver didn't bug with clock adjustment for OpenCL...).
Really good that you are testing such stuff. Results for madVR are totally rare in the web.
Old 5th July 2016, 19:58   #38495  |  Link
Sunset1982
Originally Posted by aufkrawall View Post
With DXVA2 (CB) or even with software decoding?(
Edit: hevc file is working with software decoding, but not working with dxva2 cb. If I choose software decoding I can play HEVC files. But HEVC with 4k and hdr info is too much for my cpu. Can't get it running without stuttering like hell. amds hevc decoder seems to be buggy. don't know if it is a softwarebug in crimson drivers or a hardware bug.
Old 6th July 2016, 00:25   #38496  |  Link
Sunset1982
amd rx480 vs good old 970 gtx
finished my comparison between the gtx970 and amd's rx480. tomorrow i will complete the comparison with the gtx 1070. For those who are interested in AMD's RX480, there you are...
MadVRComparison.xlsx
with the rx480 you get a performance gain of 9-57 % compared to the good old gtx 970. Power consumption is a up and down. In some scenarios the rx 480 needs more power, sometimes less.
Old 6th July 2016, 01:06   #38497  |  Link
ispano
Thx for the comparison. My RX480 arrives today and am especially happy with the fact it can do modest 4k upscaling with NNEDI3. Running an HTPC build off a GTX 285 at the moment .
ispano is offline   Reply With Quote
Old 6th July 2016, 08:47   #38498  |  Link
Sunset1982
It seems to be a good card for madvr. Especially for that price. But I would wait for a custom design, because of the fan, which is a bit noisy under heavy load.
I'm excited about the gtx1070. Will see how it performs today and if it worth the money in terms of madvr performance. Would be nice to have a bit of performance reserve for future madvr features and upscaling refinements, which (except for superres) I didn't use in my tests...
Old 6th July 2016, 12:22   #38499  |  Link
chros
chros's Avatar
Intel (that's my "problem" )
Thanks, but can you publish this/next one in an online form, e.g. on google docs? (It will be reserved for a long time, and I can't open it with Excel 2003 )
Old 6th July 2016, 12:43   #38500  |  Link
try openoffice.
and what is this rubbish? not possible, no HDMI 2.0
of cause the 970 has HDMI 2.0...
