13th November 2014, 04:59 | #1081 | Link | |
13th November 2014, 21:50 | #1083 | Link |
@forclip:
No SSE2 indeed Therefor only bassAudio_SSE.dll works on my WinXP pc. The two (SSE2) bassAudio.dll work perfectly on the Win7 laptop. Thanks a lot!
My hobby website |
13th November 2014, 22:22 | #1084 | Link | ||
forclip, I have 2 feature requests, if I may:
My hobby website |
13th November 2014, 23:36 | #1085 | Link | ||
Theoretically there can be other dlls, AviSynth plugins (if someone decided to put everything in one place), runtimes. It seems quite reasonable to not try to load them all. I'm glad that it now works for you too ----- At your own risk: http://ge.tt/5qvijT42/v/0 Firstly it tries BASS_StreamCreateFile, if it fails - BASS_MusicLoad with BASS_MUSIC_SINCINTER and BASS_MUSIC_RAMP (and BASS_STREAM_PRESCAN | BASS_STREAM_DECODE | BASS_MUSIC_POSRESETEX, required for bassAudio). Works for me, but I have only one such file, so "untested". Last edited by forclip; 14th November 2014 at 02:55. |
14th November 2014, 21:42 | #1086 | Link | ||
I do however have some samples that have several "chapters", like Twilight.umx for instance. Foobar2000 (with foo_dumb) shows me the file consists of 4 segments: segment 1 (2:18), segment 2 (3:49), segment 3 (0:50) and segment 4 (4:15) (11:12 in total). BassAudio (and DC-BSM btw) only load segment 1 and I don't know if BASS is capable of loading all segments. I've uploaded Twilight.mka (Twilight.umx encoded to a 48Kbps Opus stream and muxed to Matroska with chapters), in case you don't have foobar2000, so you can listen to all segments.
My hobby website |
15th November 2014, 03:48 | #1087 | Link |
Well, bassAudio.dll, bass.dll . Anyway, I like how it currently is, I don't think it is so hard to rename those plugins after downloading. How often it is required? Surely not every day.
Twilight.umx - can be played in a very tricky way. Here is a short explanation. But knowing starting positions "in orders" doesn't make a lot of sense, it's only part of the problem. So I would say that bassAudio will stay limited in playing such files.. |
15th November 2014, 10:09 | #1088 | Link | |
I was thinking about this problem and I don't found a easy solution.
15th November 2014, 19:24 | #1089 | Link |
Understood. Thanks for you effort, forclip.
My hobby website |
13th December 2014, 10:02 | #1091 | Link |
Thanx tebasuna51
13th December 2014, 12:32 | #1093 | Link | |
random user
Some days ago I made a mini svn commit but I though it was not worth to pack a new release. If someone will try I have just uploaded a built (.exe only) to mediafire. EDIT: removed invalid link Anyway I have a few ideas to further improve the usability but this will not happen this year. I hope I have more free time next year to work on this app.
BeHappy Audio Transcoder > <Doom9 forum> <Gleitz forum> <GitHub> MP4.tool GUI for MP4Box & L-SMASH muxer > https://www.mediafire.com/folder/3i6y6cbkyhblm/MP4.tool Last edited by jones1913; 31st May 2015 at 10:49. |
14th December 2014, 08:48 | #1094 | Link |
Thanks to jones1913 and forclip, I only join your jobs.
And thanks to siella, and Tom Keller, for the extensions pack, I don't include the pack (only I correct a bug in previous FraunhoferMp3) in the release because I don't have time to check all new encoders, and each user is free to add the needed ones. Also to CoRoNe for force us to improve the app.
BeHappy, AviSynth audio transcoder. Last edited by tebasuna51; 14th December 2014 at 09:11. |
18th December 2014, 10:58 | #1095 | Link |
Thanks to jones1913 and tebasuna51 for keeping alive behappy project. I found bug but i am not sure so i ll test again and i ll report in here. Problem is behappy doesnt decode bit of ac3 audio file correctly. I looked ac3 file with mediainfo and it gave 16 bit but when i try to decode with bassadio, ffaudio or nicac3 behappy show 32 bit float.
Behappy BePack.v3.3BeHappy,BeSweet,BeLight,BeSplit,BeSliced,BdAC) with last plugin, encoder and extensions. Avisynth Movie Screenshot, thumbnails creator Last edited by siella; 18th December 2014 at 11:03. |
18th December 2014, 11:14 | #1096 | Link |
Again this confusing topic...
Most lossy audio compression technologies with psycho-acoustic spectrum masking (like MP2, MP3, AC3, AAC...) work in a floating-point mode, they will transform the samples into audio spectrums of brief blocks and store parameters of a Fourier transformation. Decoding them back into samples again will return floating point samples at first. They may be converted to integer samples later, or not, depending on the decoder. I don't know which resolution of 16 bit MediaInfo reports. That may be the resolution of the input samples which the encoder used. But that doesn't matter. As soon as there is an AC3 bitstream, there are no more 16 bit integer samples. Only a sequence of encoded frequency spectrums in AC3 blocks. |
18th December 2014, 18:39 | #1097 | Link |
LigH
BeHappy preserve the output of the decoders (32 bits float, max precission in AviSynth) and only downsample when the next encoder don't support this precission. Or when you, manually, add a Convert Sample To ... function.
27th December 2014, 14:21 | #1098 | Link |
random user
Maybe declaring this as stable was a bit too optimistic.
I found an error in jobs start logic, but it was actually only noticeable when using DSP scripts with initialization delay (eg. normalize filter) or source plugins which are delayed while creating an index (LWLibavAudioSource). In this case jobs can simply crash or can finish with "done" status but with broken audio output file (with size of only a few kB). I have just commited a fix. Now a job is only started if the previous job has properly initialized and reached at least a progress of 1%. This can lead to a more delayed start of each job now (depending on source/dsp filters and filesize). But of course correct audio output is much more important than speed. SVN-builds can be found in my mediafire folder. (Link also in my signature)
BeHappy Audio Transcoder > <Doom9 forum> <Gleitz forum> <GitHub> MP4.tool GUI for MP4Box & L-SMASH muxer > https://www.mediafire.com/folder/3i6y6cbkyhblm/MP4.tool |
2nd January 2015, 13:01 | #1099 | Link |
random user
Happy new year to all!
The last days I had some time and so I have worked through the code to see if Im able to extend the extension system, for more functional and visually rich extension plugins (good advertising slogan he?). Until now I was not very familiar with the xml-deserialization technique used by BeHappy, but it was actually quite simple to understand. What I have done so far is: - added some more elements to multi-option class so we can add a trackbar, comboboxes and checkboxes additional to the existing radiobuttons - renamed some things (all plugins must be recreated anyway) - make the current plugin configuration saveable in behappy save state file (as before) old: new: Of course all extensions needs to be recreated once this is finished , but I hope that someone can help me then (TomK.? siella?) More infos soon..
behappy |
