Old 16th November 2011, 00:41   #10901  |  Link
psymed
Does 0.79 lessen cpu usage by any chance?
psymed is offline   Reply With Quote
Old 16th November 2011, 00:43   #10902  |  Link
Thunderbolt8
Originally Posted by Gser View Post
A clip of the material would help. Deinterlacing methods have not changed in many years. I'm using amd 5870. Basically the renderer only commands the GPU to deinterlace the material, the problem being before that MadVR did not for some reason understand bobbing hence only showed duplicates.
I tried to make a clip, but that problem was gone then in that clip. but it still exists within the original video.
it looks like the camera or the whole picture becomes very shaky and flickering.
edit: that problem seems to be related to directvobsub. it didnt appear in the sample, because I didnt mux subs in it this time. when deactivating directvobsub, the shaking is gone.
would be nice if this interaction could be improved.
Laptop Lenovo Legion 5 17IMH05: i5-10300H, 16 GB Ram, NVIDIA GTX 1650 Ti (+ Intel UHD 630), Windows 10 x64, madVR (x64), MPC-HC (x64), LAV Filter (x64), XySubfilter (x64) (K-lite codec pack)
Old 16th November 2011, 00:51   #10903  |  Link
pankov
Originally Posted by TheShadowRunner View Post
Hi madshi, sadly this bug is back with 0.79 final.
madshi,
I confirm this again
Z370M Pro4 | i3-8100 | 16GB RAM | 256GB SSD + 40TB NAS
NVIDIA GTX 1060 6GB (385.28) | LG OLED65B7V
Win 10 64bit 1803 + Zoom Player v14
pankov is offline   Reply With Quote
Old 16th November 2011, 00:52   #10904  |  Link
sToN3d
That's a known problem for some users. Unfortunately it doesn't occur on my PC, so I don't know right now what to do about it. I've implemented a little change in v0.79, though, which *may* help (but I rather doubt it). So you can retest this with v0.79.
Your change did indeed help a little. My CPU load is almost back to normal. It was ~6-7% before and now I'm at ~2.5-3.5%.
sToN3d is offline   Reply With Quote
Old 16th November 2011, 01:04   #10905  |  Link
Thunderbolt8
heres a sample http://www.mediafire.com/?jypobakil48bhnd
could you please check if you can see traces of interlaced leftovers as well in there?
Old 16th November 2011, 01:04   #10906  |  Link
Gser
I am curious as to how MadVR commands the use of DXVA deinterlacing. What mode does it choose, seeing as different GPU's need different flags.
Gser is offline   Reply With Quote
Old 16th November 2011, 01:12   #10907  |  Link
Gser
Why exactly are you trying to deinterlace film material? : D Just use tfm. I got similar weaving artifacts with different software deinterlacers as well.
Old 16th November 2011, 01:17   #10908  |  Link
Thunderbolt8
dunno what kind of material that is. I just want it to look normal during playback (without reencoding the movie) -.-
how can I use tfm during playback?
Old 16th November 2011, 01:18   #10909  |  Link
Gaius
I get no video picture when using LAV video, audio and splitters when using my MadVR settings or when restoring the default settings.
Also, clicking "Ok" on the MadVR properties window doesn't close the window and you have to close the entire player to get rid of the MadVR properties window.
This is on 32 bit Windows 7 with MPC-HC 1.5.3.3816 and latest stable Nvidia drivers.
Gaius is offline   Reply With Quote
Old 16th November 2011, 01:32   #10910  |  Link
Gser
Well if you want proper IVTC use ffdshow with avisynth plugin. Or if you don't mind the extra frames just turn off deinterlacing.
I have a rather interesting problem with Dscaler IVTC mod. For some reason it reports to madvr that the fps is film speed and deinterlacing is turned off. I don't know if the problem is with Dscaler or MadVR, perhaps i will try the non ivtc mod version since its ivtc function never worked for me anyways.
Old 16th November 2011, 01:37   #10911  |  Link
Anima123
Madshi, could you please add a force deinterlace option with the Ctrl+Alt+Shift D shortcut in case the source doesn't report the interlace status correctly?
Anima123 is offline   Reply With Quote
Old 16th November 2011, 01:41   #10912  |  Link
Thunderbolt8
ignoring it looks horrible, really distracting when watching.
and my PC is too slow to do tcm() via avisynth on the fly during playback :S
Old 16th November 2011, 01:41   #10913  |  Link
Gser
Yes this would be handy. I have a source here that for some reason is reported as interlaced with 0.78 and not reported as interlaced with 0.79. Still trying to figure out the fps issue. If I put FFDShow inbetween DScaler and MadVR, it reports the correct fps but for some reason MadVR is forcing film speed.
Old 16th November 2011, 01:43   #10914  |  Link
Gser
http://forum.doom9.org/showthread.php?t=141441
Try using Phase filter with FFDShow, its what i generally use.
Old 16th November 2011, 02:08   #10915  |  Link
Thunderbolt8
is it possible that it doesnt work so well when when I also use sharpening with ffdshow?
is it generally possible to fix an order in which all ffdshow filters can be used? in that case, I could try to run sharpening after applying phase.
Old 16th November 2011, 02:17   #10916  |  Link
Andy o
Thanks madshi, deinterlacing is now working at 50p for my material instead of at 25p.
The other thing I reported where 29i material with a "24p" tag in the file name would switch to 50p or 60p has also been fixed, but then deinterlacing gets turned off. The way I used to do it with CUVID was the decoder outputting 30p and then decimating with ffdshow processor/avisynth. I suppose it's not possible to decimate like this with madVR's deinterlacing, right?
MSI MAG X570 TOMAHAWK WIFI, Ryzen 5900x, RTX 3070, Win 10-64.
Pioneer VSX-LX503, LG OLED65C9
Andy o is offline   Reply With Quote
Old 16th November 2011, 02:24   #10917  |  Link
Gser
Just drag the sharpening filter after the dscaler filter.
Old 16th November 2011, 02:55   #10918  |  Link
dansrfe
Originally Posted by pankov View Post
madshi,
Confirmed again as well.
Also deinterlacing gives rise to noticeable jerkiness and aliasing.
Here's the log: http://www.mediafire.com/?t7jzm59ln9wa6dp
Old 16th November 2011, 03:08   #10919  |  Link
Andy o
madshi, one other thing, would it be possible to add the option to force 29i/30i whenever I add a "29i" or "30i" to the file name, even when there's a "1080p60" in madVR options? Right now I have both 1080i29 and 1080p59, and it always switches to the latter. The reason is that the only way IVTC is working fully for me is if I let madVR IVTC to 60p and then convert that to a 30i output so my display's IVTC processor can detect proper cadence and apply IVTC again to 72 Hz. A bit convoluted, but works. I was using this method when I was using EVR.
Old 16th November 2011, 03:19   #10920  |  Link
dansrfe
I have a question:
How does madVR deal with the refresh rate reported by the source filter or splitter and ffdshow's video decoder and then if deinterlacing is activated within ffdshow?
For example:
I play a VOB file hard-telecined/3:2 pulldown at 29.970 reported by the source filter (navigator) and ffdshow, but then I enable deinterlacing within ffdshow. Now pure deinterlacement would keep the same fps of 29.970 and I realize that but what happens if I use AviSynth internally within ffdshow and inverse telecine it using tfm().tdecimate()? How does madVR deal with that? Does ffdshow report 23.976 as the new fps? Does madVR still use the rate reported by the source filter?
I feel like the problem gets more complicated with the introduction of user-added refresh rates...but I like it nevertheless.
