24th May 2008, 05:03 | #2202 | Link | |
24th May 2008, 05:27 | #2203 | Link | |||
Also any answer to these questions/suggestions?
24th May 2008, 05:33 | #2204 | Link | |
24th May 2008, 06:16 | #2206 | Link | |||
Swallowed in the Sea
dunno... |
24th May 2008, 17:10 | #2207 | Link | |
26th May 2008, 01:02 | #2210 | Link |
General ID : 0 Complete name : G:\Temp\BDROM\BDMV\STREAM\00000.m2ts Format : BDAV Format/Info : BluRay Video File size : 17.0 GiB Duration : 1h 55mn Overal bit rate : 21.1 Mbps Video ID : 4113 (0x1011) Menu ID : 1 (0x1) Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.1 Format settings, CABAC : Yes Format settings, ReFrames : 4 Duration : 1h 55mn Bit rate : 20.0 Mbps Width : 1920 pixels Height : 1080 pixels Display aspect ratio : 16/9 Frame rate : 29.970 fps Standard : NTSC Colorimetry : 4:2:0 Audio ID : 4352 (0x1100) Menu ID : 1 (0x1) Format : AC-3 Format/Info : Audio Coding 3 Duration : 1h 55mn Bit rate mode : CBR Bit rate : 224 Kbps Channel(s) : 2 channels Channel positions : L R Sampling rate : 48.0 KHz |
26th May 2008, 02:53 | #2211 | Link | |
27th May 2008, 17:05 | #2212 | Link | |
Molu |
27th May 2008, 21:28 | #2213 | Link |
Sorry if already reported, I am in a little hurry...
Bug in MeGUI 0.3.0.1004: If you select the video encoding mode "Const. Quantizer", on a german Windows XP (using the comma as LOCALE dependent decimal separator) you get the x264 command line option "--qp ##,0", where the ",0" may be a fractional part, although a quantizer would usually be integer. And the spin control contains only an integer. This command line option confuses x264: "invalid argument: qp = ##,0" In "Const. Quality" mode instead, the spin control shows a fractional number and spins in tenths, displaying a comma as (LOCALE dependent) decimal separator in the spin edit and the command line option "--crf ##.#" with decimal dot (the usual english number notation, as expected) - so this mode works well. |
29th May 2008, 17:38 | #2214 | Link |
Quality Freak
A few small questions.
1. Is MeGUI compatible with Avisynth 2.5.8 RC1? 2. In the audio encoding options in MeGUI, I use Nero Digital AAC. SO, I use one of the NDAAC profiles. In the config of any of those profiles, there's 3 options to upmix 2 channel to 5.1 using various methods. None of them work for me. I queue it, start it, and then it immediately stops and says "error". In the log, it doesn't tell me what the error is. So I suppose my question is, why doesn't the 2 channel to 5.1 options work? Last edited by Nightshiver; 29th May 2008 at 17:41. |
30th May 2008, 04:23 | #2215 | Link | |
too much lurking
30th May 2008, 06:52 | #2218 | Link | |
about your problem : try to rename it (00000.m2ts to my_file.m2ts) and load it once again. |
30th May 2008, 06:59 | #2219 | Link | |
I can't remove this warning because it's also used for the other encoders (xvid, snow...). |
30th May 2008, 08:01 | #2220 | Link | |
I renamed the file to myfile.m2ts and I get the same error when I try to open it in the script creator. Also, I forgot to mention, two Haali Media Splitter icons pop up in the system tray. |
megui |
