Old 13th February 2010, 06:23   #121  |  Link
Emp3r0r
Emp3r0r's Avatar
I put the source on google code. Due to a lack of time, I've not been able to resolve the chapter lookup feature. I would love to see this fixed and added to megui.
http://jvance.com/pages/ChapterGrabber.xhtml
http://code.google.com/p/chaptergrabber/
edit: I found the time, latest version works with tagchimp and the new chapterdb.org
ChapterGrabber - add names to your chapters | AtomSite - open source AtomPub server
Emp3r0r is offline   Reply With Quote
Old 14th April 2010, 10:08   #122  |  Link
doc_dvxm
HD Encod3r
Originally Posted by LeXXuz View Post
Hi Emp3r0r,
I cannot get any chapter information from tagchimp with ChapterGrabber. Using the same keywords directly on the website gives me dozens of results with movies/chapter information. No matter what I do, ChapterGrabber always claims that it has found 0 results. Any ideas?
Hii there... Me too... I am trying to search, but there is no info founded in tagchimp and metaservices..
I tried with 3.6 and 3.7 version... I am on 32 Bit Platform Win 7 Ultimate OS ...
What do you prefer ??
Thanx in advance...
Best Regards,
doc
doc_dvxm is offline   Reply With Quote
Old 13th May 2010, 17:02   #123  |  Link
Anacletus
Anacletus's Avatar
Version 3.8 online --> http://jvance.com/pages/ChapterGrabber.xhtml
Anacletus is offline   Reply With Quote
Old 13th May 2010, 19:50   #124  |  Link
Emp3r0r
Emp3r0r's Avatar
4.0 is now online as well with built-in update checking.
The tagchimp search results are improved and I hope to add a new chapter database in a near future.
Old 15th May 2010, 01:41   #125  |  Link
sialivi
Emp3r0r,
I'm just trying out version 4.1 and no matter what movie I try all the chapters have the timestamp 00:00:00.000
sialivi is offline   Reply With Quote
Old 16th May 2010, 03:56   #126  |  Link
Emp3r0r
Emp3r0r's Avatar
I just tested it on a bluray and it worked fine? What type of disc? DVD?
Old 17th May 2010, 00:53   #127  |  Link
hubblec4
Matroska find' ich toll
thanks a lot for the update.
hubblec4 is offline   Reply With Quote
Old 6th June 2010, 06:05   #128  |  Link
Emp3r0r
Emp3r0r's Avatar
I've created an online database to store chapter names and updated ChapterGrabber to read and store names in the database. It also helps you find an appropriate title for the movie so we can find the chapters easier.
If the database already has the chapter names, when you load the disc in ChapterGrabber, the chapter names (and movie title) will automatically load.
Please help build the database. I'm hoping to have the data collected in chapterdb.org added to themoviedb.org.
Thanks
Old 7th June 2010, 10:16   #129  |  Link
doc_dvxm
HD Encod3r
The Latest version (4.1) has been tested on various BluRay Disc's. It work fine. Thanx for your great job
Old 24th July 2010, 19:51   #130  |  Link
LeXXuz
21 years and counting...
LeXXuz's Avatar
DAMN! Seen this way too late.
Thought this nice little tool was dead. Very good to see you're back working on it.
LeXXuz is offline   Reply With Quote
Old 16th November 2010, 15:02   #131  |  Link
LeXXuz
LeXXuz's Avatar
An option to shift chapter times would be great.
Old 16th November 2010, 17:40   #132  |  Link
Usedocne
lurkster
^2nded.
Usedocne is offline   Reply With Quote
Old 25th January 2011, 19:45   #133  |  Link
Couch Potato
Couch Potato's Avatar
A teeny addon for Chapter Grabber...
Hi Guys,
First post so please be gentle with me...
I love this prog to bits but I find it a pain transfering the found stuff into Handbrake or MKV Merge GUI, so I wrote a little awk script that reads a saved XML Chapters file and creates two new files from it, a CSV for Handbrake and an XML for MKV Merge, it runs under Linux or Windows (using gawk from Cygwin).
I'm currently using it from a shortcut from my Windows 7 destop, and it saves me no-end of cutting/pasting/typing.
Anyone interested?
Couch Potato
Couch Potato is offline   Reply With Quote
Old 3rd July 2011, 22:25   #134  |  Link
hubblec4
thanks for the update to V. 5.0.0.0
is there a changelog available?
Old 3rd July 2011, 22:30   #135  |  Link
LeMoi
LeMoi is offline   Reply With Quote
Old 3rd November 2011, 18:16   #136  |  Link
Frogger13
Just another User
No update since a long time... Is this great project dead?!
Frogger13 is offline   Reply With Quote
Old 20th November 2011, 13:32   #137  |  Link
LeXXuz
LeXXuz's Avatar
It seems I can't use this tool without an Internet connection. I never noticed this before, but this week I had some problems with my ISP and no connection to the Internet for a couple of days.
I was unable to use Chapter Grabber. It ALWAYS crashed a couple of seconds after start. I verified this later by dis-/connecting my system manually. Anybody to confirm this?
Old 25th December 2011, 06:29   #138  |  Link
Emp3r0r
Emp3r0r's Avatar
It should work without a connection, will look into it
Old 4th January 2012, 02:47   #139  |  Link
Mole
Mole's Avatar
Excellent program!
But it would be nice if you could add option for adding delay in the times.
For example, delay of 5.250 ms or -5.250 ms if you want to delete 5.250 seconds from all the chapters.
Thanks for the good work so far though!
Mole is offline   Reply With Quote
Old 4th January 2012, 07:57   #140  |  Link
LeXXuz
LeXXuz's Avatar
I second that. Shifting the chapter times would be great!
