10th September 2004, 17:06 | #2761 | Link | |
I'm afraid we've to stop
Gordian Knot Family: Gordian Knot: website, download Auto Gordian Knot: Website and download, tutorial, FAQ |
10th September 2004, 18:48 | #2762 | Link |
well... in fact i need to make from this DTS - mp3 and mux it with avi
DTS is playing fine, almost, with ac3 filter... i have sound first 30 mins and than - silence edited azidts -core -input 1.dts -output 1.wav
P4 2.8C@3.58, Epox EP-4PDA2+, 2x512 DDR533@510 Geil (2.5-4-4-8), Sparkle FX5900XT (480/730), HDD's 440gb TT SkyStar-1 (Rev. 1.5, Drv. 2.17g), TS SkyStar-2 (Rev. 2.6C, Drv. 4.3.0) Last edited by QNX; 10th September 2004 at 20:00. |
11th September 2004, 06:05 | #2764 | Link | |
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: stable version is coming
I don't beleive that the ! in the path could be causing the problem because I have successfully encoded an mpg file in the same directory as the ts file. I upgraded to AGK1.56 and tested on the ts file with the same result. I download the versions of VDubMod and replaced the folder in the AGK folder. Testing the TS file again with the new versions resulted in the same problem: VirtualDub Error Avisynth read error: Avisynth: caught an access violation at 0x01373919, attempting to read from 0f2cdc900 ... [11/09/2004 2:49:16 PM] OS: WinXP (5.1.2600).2 [11/09/2004 2:49:16 PM] Job started. [11/09/2004 2:49:16 PM] Input file: JAG (2004-09-07 12-00 SCT Digital).ts [11/09/2004 2:49:16 PM] Output file: U:\!TVEdits\compression tests\JAG (2004-09-07 12-00 SCT Digital).avi [11/09/2004 2:49:16 PM] Audio: MPEG1 Audio on PID 0xc0 [11/09/2004 2:49:16 PM] Subtitles: none [11/09/2004 2:49:16 PM] Codec: XviD [11/09/2004 2:49:16 PM] Target quality: 50% [11/09/2004 2:49:16 PM] Started encoding. [11/09/2004 2:49:16 PM] Demuxing and indexing. [11/09/2004 2:53:21 PM] Processing file: U:\!TVEdits\compression [11/09/2004 2:53:23 PM] Source aspect ratio: 16:9 [11/09/2004 2:53:23 PM] Source resolution: 704x576 [11/09/2004 2:53:23 PM] Found PAL source. [11/09/2004 2:53:24 PM] Analyzing source. I didn't mention before that if I click ok to the error then the encoding seems to continue. I have not previously let it complete, I will let this happen now and let you know the result if this would be helpfull. Paul |
11th September 2004, 06:22 | #2765 | Link | |
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: stable version is coming
[11/09/2004 2:49:16 PM] AutoGK 1.56b [11/09/2004 2:49:16 PM] OS: WinXP (5.1.2600).2 [11/09/2004 2:49:16 PM] Job started. [11/09/2004 2:49:16 PM] Input file: JAG (2004-09-07 12-00 SCT Digital).ts [11/09/2004 2:49:16 PM] Output file: U:\!TVEdits\compression tests\JAG (2004-09-07 12-00 SCT Digital).avi [11/09/2004 2:49:16 PM] Audio: MPEG1 Audio on PID 0xc0 [11/09/2004 2:49:16 PM] Subtitles: none [11/09/2004 2:49:16 PM] Codec: XviD [11/09/2004 2:49:16 PM] Target quality: 50% [11/09/2004 2:49:16 PM] Started encoding. [11/09/2004 2:49:16 PM] Demuxing and indexing. [11/09/2004 2:53:21 PM] Processing file: U:\!TVEdits\compression [11/09/2004 2:53:23 PM] Source aspect ratio: 16:9 [11/09/2004 2:53:23 PM] Source resolution: 704x576 [11/09/2004 2:53:23 PM] Found PAL source. [11/09/2004 2:53:24 PM] Analyzing source. [11/09/2004 3:02:36 PM] Source is considered to be interlaced. [11/09/2004 3:02:36 PM] Found 97122 frames [11/09/2004 3:02:36 PM] Encoding audio. [11/09/2004 3:19:18 PM] Running single pass encoding. I received another error: VirtualDub Error Avisynth open failure: Evaluate: Unrecognised exception! (U:\!TVEdits\compression tests\agk_tmp\JAG (2004-09-07 12-00 SCT Digital)_movie.avs, line 21) Clicking ok completed the job: [11/09/2004 2:49:16 PM] AutoGK 1.56b [11/09/2004 2:49:16 PM] OS: WinXP (5.1.2600).2 [11/09/2004 2:49:16 PM] Job started. [11/09/2004 2:49:16 PM] Input file: JAG (2004-09-07 12-00 SCT Digital).ts [11/09/2004 2:49:16 PM] Output file: U:\!TVEdits\compression tests\JAG (2004-09-07 12-00 SCT Digital).avi [11/09/2004 2:49:16 PM] Audio: MPEG1 Audio on PID 0xc0 [11/09/2004 2:49:16 PM] Subtitles: none [11/09/2004 2:49:16 PM] Codec: XviD [11/09/2004 2:49:16 PM] Target quality: 50% [11/09/2004 2:49:16 PM] Started encoding. [11/09/2004 2:49:16 PM] Demuxing and indexing. [11/09/2004 2:53:21 PM] Processing file: U:\!TVEdits\compression [11/09/2004 2:53:23 PM] Source aspect ratio: 16:9 [11/09/2004 2:53:23 PM] Source resolution: 704x576 [11/09/2004 2:53:23 PM] Found PAL source. [11/09/2004 2:53:24 PM] Analyzing source. [11/09/2004 3:02:36 PM] Source is considered to be interlaced. [11/09/2004 3:02:36 PM] Found 97122 frames [11/09/2004 3:02:36 PM] Encoding audio. [11/09/2004 3:19:18 PM] Running single pass encoding. [11/09/2004 3:22:38 PM] Duration was: 3 minutes 19 seconds [11/09/2004 3:22:38 PM] Speed was: 487.11 fps. [11/09/2004 3:22:38 PM] Job finished. No AVI was produced though. Paul |
11th September 2004, 06:39 | #2766 | Link |
problem with 720p transport streams
Hi, I am using AutoGK 1.56 beta to convert 1080i and 720p HDTV Transport Streams (.tp) to Xvid with AC3, with the width of the video resized to 720 pixels. The 1080i encodes are coming out very well with compressability in a normal range (40-50%) and with the desired file size of about 17 MB per minute, but the 720p encodes are looking very bad at similar file size with compressability half of 1080i! Then I noticed that the converted 1080i was playing at ~29.970 fps, while the 720p conversions were playing at ~59.940. Yes, I know that this is the native framerate of many 720p sources, but isn't it normal when encoding such sources to Xvid/Divx to decimate every other frame? I wonder if such a high framerate is the cause of the bad compressability. Thanks for any suggestions,
lazyn00b Last edited by lazyn00b; 11th September 2004 at 06:46. |
11th September 2004, 11:50 | #2769 | Link | |
11th September 2004, 11:53 | #2770 | Link | |
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: stable version is coming
11th September 2004, 11:54 | #2771 | Link | ||
Mad Scientist
Feedback, requests and opinions
Hello, all.
- MPEG2 Video files(*.vob,*.m2v,*.mpeg,*.mpg) - Transport Streams(*.ts,*.tp,*.trp,*.m2t) or if simply both types were merged under a "Supported input formats" type. Concerning .ts multifile inputs, I usually get a set of files like this one: Brubaker.ts Brubaker.ts.001 Brubaker.ts.002 Brubaker.ts.003 and I have to rename them for AutoGK like this: Brubaker_1.ts Brubaker_2.ts Brubaker_3.ts Brubaker_4.ts I don't know if that's a job for AutoGK or DGIndex, but it would save the additional renaming step if this other sequence naming pattern was recognized. And finally, about the recent request about the bitrate, I think it would mostly confuse the novice user AutoGK targets. And if you don't mind using an extra program, PVAStrumento tells you the bitrate of .vob, .mpg and .ts files. Regards, Last edited by ydobon; 11th September 2004 at 11:57. |
11th September 2004, 12:13 | #2772 | Link | |
Re: problem with 720p transport streams
P.S. There is a smart way to bring down fps for large number of cases via FDecimate(), so I'll do some tests and may be add this as a hidden option.
11th September 2004, 12:20 | #2773 | Link | ||
Re: Feedback, requests and opinions
11th September 2004, 13:23 | #2774 | Link |
first of all thanks for AutoGK, it gets better with every new release!
I've just encoded some animes and after that I played a little bit with the new GK. Would it be possible to add the avisynth dup plugin to the .avs script if there is a .cartoon file? I get's much better rips with this plungin in my scripts! Thanks |
11th September 2004, 14:43 | #2776 | Link | |
Mad Scientist
Re: Re: Feedback, requests and opinions
Hi, again.
ren *.ts.008 *_9.temp ren *.ts.007 *_8.temp ren *.ts.006 *_7.temp ren *.ts.005 *_6.temp ren *.ts.004 *_5.temp ren *.ts.003 *_4.temp ren *.ts.002 *_3.temp ren *.ts.001 *_2.temp ren *.ts *_1.temp ren *.temp *.ts I'm sure it must have some secondary effect I'm not aware of. But I use it in a directory containing only the files I want to rename and it works. Hope it helps someone |
11th September 2004, 15:58 | #2777 | Link | |
11th September 2004, 17:23 | #2778 | Link |
Dup Filter for Avisynth:
"This is intended for use in clips that have a significant number of duplicate content frames, but which differ due to noise. Typically anime has many such duplicates. By replacing noisy duplicates with exact duplicates, a bitrate reduction can be achieved." I've tried it and it worked fine. don't know if it is useful in general, but i think so. you could visit http://www.neuron2.net/dup/dupnew.html for more information! |
11th September 2004, 19:51 | #2779 | Link | |
Re: Re: Re: Feedback, requests and opinions
11th September 2004, 19:57 | #2780 | Link | |
