1st February 2009, 14:54 | #681 | Link | ||
Below is the first log file for a bilingual .mkv file Author message: [29/01/2009] build 279 (latest is: 279) - Option to convert TrueHD and DTS-MA/HRA to AC3 if in m2ts/ts/mpeg. [14:15:28] Your multiAVCHD.exe was just updated! [14:15:28] Author message: [29/01/2009] build 279 (latest is: 279) - Option to convert TrueHD and DTS-MA/HRA to AC3 if in m2ts/ts/mpeg. Error reading .ini file! Setting default options. [14:18:41] Log started for multiAVCHD v2.0 (build 279) [14:18:41] Processing 1 input files/folders . [14:18:41] Converting mkv file to AVCHD (H:\FILMS SEEDED\XXX.mkv). [14:18:41] Detected video: ID#1:V_MPEG4/ISO/AVC:1920x820 23.976fps (AR:2.34) [14:18:41] Video height not AVCHD compliant (480/576/720/1080)! Final output may be distorted. [14:18:41] Fixing clip and playlist info. [14:18:41] Detected audio: ID#2:A_DTS:audio (48000Hz/6ch) Language: rus [14:18:41] Detected audio: ID#3:A_DTS:audio (48000Hz/6ch) Language: fre [14:18:41] Detected subtitles: ID#4:S_TEXT/UTF8 Language: rus [14:18:41] Detected subtitles: ID#5:S_TEXT/UTF8 Language: eng [14:18:41] Generating meta file for tsMuxer... [14:18:41] M2TS stream split set at 15000MiB... [14:18:42] Searching for original chapters (mediainfo)... [14:18:42] None found. Inserting 5 min chapters... [14:18:42] Detected frame reference count: 4 (max:5). [14:18:42] Compliant with L4.1 for 1920x820p. [14:18:42] Creating BluRay folders (tsMuxer)... [14:33:59] Done! [14:33:59] Applying new vertical resolution ID to video (1080p). [14:33:59] CLPI transfer: H:\_TEMP\20090129-141842-253\BDMV\CLIPINF\00001.clpi -> H:\AVCHD\BDMV\CLIPINF\00000.clpi [14:33:59] M2TS transfer: H:\_TEMP\20090129-141842-253\BDMV\STREAM\00001.m2ts -> H:\AVCHD\BDMV\STREAM\00000.m2ts [14:33:59] MPLS transfer: H:\_TEMP\20090129-141842-253\BDMV\PLAYLIST\00000.mpls -> H:\AVCHD\BDMV\PLAYLIST\00000.mpls [14:33:59] Non-compliant AVCHD title. (1 of max 40 now!). [14:33:59] Old pointer to 00001.m2ts in 00000.mpls now set to -> 0 [14:33:59] Preparing authoring information... [14:33:59] Copying 1 sec blank video data. [14:33:59] Creating static/lite top PAL menu. [14:34:00] Setting menu for 1 titles... [14:34:00] New offset for m2ts#1 -> 0 [14:34:00] New offset for mpls#1 -> 00000 [14:34:00] Setting titles #2 to #40 to point at top menu. [14:34:00] Processing clip (CPI/CLPI) files... [14:34:00] Completed. [14:34:00] Adding one second black fill for Title#1 (PRID#42) [14:34:00] Done! [14:34:00] H:\AVCHD folder created! [14:34:00] Burn its CONTENTS to DVD-UDF 2.50... Only the first audio track was played - the second one has no sound. But with the build 303 (and 299) and the SAME file, I have every time "(RT) Invalid floating point operation - Line 23" "Access violation at address 00981F2C in module 'calclib.dll. Read of address 00000018 - Line 2043" And the program stops. Here is the mediaindo.txt: General Complete name : H:\FILMS SEEDED\XXX.mkv Format : Matroska File size : 9.02 GiB Duration : 1h 42mn Overall bit rate : 12.6 Mbps Encoded date : UTC 2008-12-12 12:27:01 Writing application : mkvmerge v2.4.0 ('Fumbling Towards Ecstasy') built on Oct 11 2008 20:13:15 Writing library : libebml v0.7.7 + libmatroska v0.8.1 Video Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.1 Format settings, CABAC : Yes Format settings, ReFrames : 4 frames Muxing mode : Container profile=Unknown@4.1 Codec ID : V_MPEG4/ISO/AVC Duration : 1h 42mn Bit rate : 9 034 Kbps Nominal bit rate : 9 596 Kbps Width : 1 920 pixels Height : 820 pixels Display aspect ratio : 2.35 Frame rate : 23.976 fps Resolution : 24 bits Colorimetry : 4:2:0 Scan type : Progressive Bits/(Pixel*Frame) : 0.239 Writing library : x264 core 65 r1047M f773bf0 Encoding settings : cabac=1 / ref=4 / deblock=1:-3:-3 / analyse=0x3:0x113 / me=umh / subme=9 / psy_rd=0.9:0.0 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=0 / 8x8dct=1 / cqm=0 / deadzone=17,9 / chroma_qp_offset=-2 / threads=6 / nr=0 / decimate=1 / mbaff=0 / bframes=3 / b_pyramid=0 / b_adapt=2 / b_bias=0 / direct=3 / wpredb=1 / keyint=250 / keyint_min=25 / scenecut=40(pre) / rc=2pass / bitrate=9596 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:0.60 Language : French Audio #1 Format : DTS Format/Info : Digital Theater Systems Codec ID : A_DTS Duration : 1h 42mn Bit rate mode : Constant Bit rate : 1 536 Kbps Channel(s) : 6 channels Channel positions : Front: L C R, Surround: L R, LFE Sampling rate : 48.0 KHz Resolution : 24 bits Title : DTS 5.1 1536 kbps Language : Russian Audio #2 Format : DTS Format/Info : Digital Theater Systems Codec ID : A_DTS Duration : 1h 42mn Bit rate mode : Constant Bit rate : 1 536 Kbps Channel(s) : 6 channels Channel positions : Front: L C R, Surround: L R, LFE Sampling rate : 48.0 KHz Resolution : 16 bits Title : DTS 5.1 1536 kbps Language : French Text #1 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Language : Russian Text #2 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Language : English Any ideas? Last edited by xeniste; 1st February 2009 at 15:26. |
1st February 2009, 16:23 | #684 | Link | |||
Right, only up to option 2 works. So I'm not the only one. Gemad could you specify your player? What I have not tried Dean is custom menu + 'full title count for page one'. Guess I'll get back to you on that. |
1st February 2009, 16:31 | #685 | Link |
Programmer (or just 教务长)
@xeniste: Try again now.
You get this error BEFORE loading your file, right? @Cerpintine: You can't have "custom menu" and "Full title count" both checked at the same time. Uncheck 'custom menu' and then check 'full..' |
1st February 2009, 19:58 | #690 | Link |
I tried to combine 2 BD-Rs - made with a Panasonic program to save my HD Camcorder recordings from a SD card - onto one single BD-R. Each of the 2 separate BD-Rs is playable, the combined version is not fully playable.
The AVCHD structure of the first BD-R (input disk 1) contains 9 titles, each title contains up to 42 chapters, with a total file count of 250. The AVCHD structure of the 2nd BD-R (input disk 2) contains 5 titles, each title contains up to 60 chapters, with a total file count of 214. The AVCHD structure of the resulting combined BD-R (w.o. top menu) contains 14 + 4 titles. All 464 files (250 + 214) are included in the 'STREAM'-folder. My SAP Samsung BD 1400 plays as new 1st title the old 1st title of the 1st input disk (with all chapters) followed as new 2nd title by the old 1st title of the 2nd input disk (with all chapters). Then it starts with the 1st title of the 1st BD-R again. A manual selection of new titles 3 to 14 via RC shows always the 1st title of the 1st BD-R again. Sumary: Combining two BD-Rs puts all necessary files into the new AVCHD structure but plays only the first title of each (input) BD-R. FSNAVI |
2nd February 2009, 11:49 | #694 | Link |
deank, now that you are really going forward with your app; You might be able to look at te (GPL'ed) source of tsRemuX. You might be able to use it to create you own muxer, and circomvent (small) bugs that occur in tsMuxeR. And the other advantage is that you are not tied to effords or energy spent by others or the updates of a programm, that like tsMuxeR doesnt seem to happen or where no communication seems possible.
The source is freely downloadable here: http://www.megaupload.com/?d=6G5LPRI4 (The first post of the txRemux tread). Last edited by G_M_C; 2nd February 2009 at 13:59. |
2nd February 2009, 18:15 | #696 | Link |
Another day... and a lot of tests.
Today I found that with the same multiAVCHD output * TMT * Nero Showtime * Playstation 3 (USB) * Playstation 3 (DVD5) -- all these behave DIFFERENTLY. I issued build 308. It should make TMT and NERO work fine with custom menu. Also PS3 plays custom menu - still no nav- arrows, but titles are selectable via Remote Control (or "triangle", NUMBER button or Jump to - title). Please if someone can test with their stand-alone-player. |
2nd February 2009, 18:46 | #698 | Link |
Did multiAVCHD update some menu files for PAL/NTSC?
And I'd rather have someone to test with Panasonic or Sony. They follow AVCHD standard and not Samsung. Last edited by deank; 2nd February 2009 at 18:50. |
2nd February 2009, 19:31 | #699 | Link |
So guys! Report from the build 308.
On a Sony BDP-S350 (SAP), it's like this (Custom menu checked): AVCHD screen > 1 second> Title menu screen >2-3 seconds > Arrow appears. Arrow movable and clickable! No problems, it works perfectly. With Corel Win DVD: Clickable menu without file names. First title starts playing immediately without menu. Titles selectable via Title menu of the player. All in all, that's what I've said: as many SAPs, as many problems. Same is right for software players. And Dean has absolutely right: the more we report different behavior or different SAP brands, the better he can solve various problems, isn't it? |
2nd February 2009, 19:35 | #700 | Link |
Thanks for the contribution with this information.
I'd like to ask all of you, who have something to report - post in this forum. |
