Old 15th June 2008, 22:40   #5121  |  Link
G_M_C
list of quotes
You' ve quoted my question about converting audio to 24 fps, but you might have forgotten the answer
G_M_C is offline   Reply With Quote
Old 15th June 2008, 22:47   #5122  |  Link
nautilus7
nautilus7's Avatar
All these days without madshi's posts here, i was waiting for his multi quote responses. It was almost certain that he would miss a few, but not this way.
Thanks for the update madshi. Looking forward for the new dts-hd master audio decoder. I want to make some 7.1 flacs.
nautilus7 is offline   Reply With Quote
Old 15th June 2008, 22:48   #5123  |  Link
madshi
Have edited that post.
Old 15th June 2008, 23:36   #5124  |  Link
G_M_C
Yes i'm shure that it really is 24.000
I've tried making a AVCHD with 23,976; Then the audio plays, but the video isnt displayed. Only on 24 fps it works (and on all other rates supported by the format, see here: http://www.avchd-info.org/format/index.html).
The current video i'm working with is 720p @ 23,976. The player i'm trying to get it to work on is the Panasonic DMP-BD30.
Old 16th June 2008, 00:26   #5125  |  Link
xkodi
@madshi
eac3to 2.47 bug report:
LPCM, 7.1ch, 24bit, 96kHz track is decoded by eac3to as WAV file that is reported by players as 48kHz, but looks like only the WAV header is wrong, because eac3to reports the parameters correctly:
2: RAW/PCM, Japanese, 7.1 channels, 24 bits, 96khz
xkodi is offline   Reply With Quote
Old 16th June 2008, 01:09   #5126  |  Link
nautilus7
nautilus7's Avatar
Originally Posted by xkodi View Post
@madshi
If you convert it to flac... Is it reported correctly then?
(if the wav header is written accidentally as 48 khz, wouldn't then the track played at half speed? )
Old 16th June 2008, 01:26   #5127  |  Link
Thunderbolt8
thanks for 2.47, as I said Ill report back in case I should encounter problems
Old 16th June 2008, 02:55   #5128  |  Link
DoomBot
eac3to v2.47 released
http://madshi.net/eac3to.zip
* sequence end codes are removed when demuxing video now, too
So this means we dont have to mux to mkv when doing a seamless branching movie correct? Then i can mux my demuxed video and audio with tsmuxer.
DoomBot is offline   Reply With Quote
Old 16th June 2008, 07:35   #5129  |  Link
madshi
Hmmmm... Could I have a small sample of the source file (m2ts or evo), please? 10MB should be plenty. Thanks!
Yes, that's exactly the purpose I implemented it for. However, depending on how tsmuxer behaves it might still be better (or worse) to choose MKV as an intermediate step instead of demuxing. My recommendation would be to test both solutions (1: eac3to -> MKV -> tsmuxer; 2: eac3to -> demux -> tsmuxer) and see which end result is better. I can't say which will be better. That depends on tsmuxer.
Old 16th June 2008, 10:00   #5130  |  Link
xkodi
http://rapidshare.de/files/39733929/...2496.m2ts.html
Old 16th June 2008, 19:31   #5131  |  Link
madshi
Thanks, will be fixed in next build.
Old 16th June 2008, 21:29   #5132  |  Link
rickardk
eac3to v2.47 crashed when trying to make a flac out of this one:
www.earselect.se/test.lpcm
eac3to v2.22 can handle it though
rickardk is offline   Reply With Quote
Old 16th June 2008, 21:43   #5133  |  Link
madshi
That's a crash in the MP2 audio parser when trying to find out whether the file is MP2 or not. v2.22 didn't support MP2 yet. That's why it worked with v2.22. The problem will be fixed in the next build.
Old 17th June 2008, 21:50   #5134  |  Link
Thunderbolt8
the ac3 commentary track from the patton blu-ray has a -9ms delay. but when demuxing that track eac3to writes the 'applying (e)ac3 delay...' message, which actually doesnt/shouldnt happen in that case. if a delay was applied then the sync would be worse than no change at all, because of the 32ms frame size. so is this message in this case basically only generic even though eac3to doesnt add a delay here, its printed out each time any delay is detected, indicating to the user that eac3to looks to solve this issue automatically, even when the solution is not adding a delay at all?
Old 17th June 2008, 22:07   #5135  |  Link
nautilus7
nautilus7's Avatar
Latest eac3to version crashes with title 1 (main movie) of National Treasure 2 Blu-ray. I think this is because of the PiP function (secondary video stream) of this disc. Previous version simple couldn't detect the dts track of the secondary video stream.
Bug report
Old 17th June 2008, 22:25   #5136  |  Link
BLKMGK
Bug report
Getting the same sort of error with Jumper How exactly did you create the bugreport file? Vista is offering to send it off someplace but umm yeah I dunno' know where If I view the bug report I see the access violation etc. but no way to copy that data out... DYING to see this movie lol
BLKMGK is offline   Reply With Quote
Old 17th June 2008, 22:58   #5137  |  Link
nautilus7
nautilus7's Avatar
Originally Posted by BLKMGK View Post
...but umm yeah I dunno' know where
That's why newer versions of eac3to copy the bug report to the folder that eac3to is located. Jumper has PiP as well.
Old 18th June 2008, 00:04   #5138  |  Link
BLKMGK
well in that case! http://pastebin.com/m257da4ce
Old 18th June 2008, 06:48   #5139  |  Link
boykster
I got the same crash/error on Jumper with 2.47 (with the newest AnyDvd update). I was able to successfully process it with 2.46 and so far (about 1 hour in to watching it) everything's looking good.
I processes NT2 with 2.46 also and had no problems other than that DTS error message. My output video/audio streams were just fine.
boykster is offline   Reply With Quote
Old 18th June 2008, 11:53   #5140  |  Link
nautilus7
nautilus7's Avatar
I noticed that Rambo (2008) blu-ray which uses PiP also doesn't crash with 2.47. Although the PiP audio track is AC3.
eac3to "F:\Rambo IV 2008 Blu-ray 1080p H.264 DTS-HD MA 7.1" 1)
M2TS, 2 video tracks, 3 audio tracks, 2:00:22
1: Chapters, 17 chapters
2: h264/AVC, 1080p24 /1.001 (16:9)
3: h264/AVC, 480p24 /1.001 (20:11)
4: DTS Master Audio, English, 5.1 channels, 24 bits, 48khz
5: AC3, French, 5.1 channels, 640kbit/s, 48khz, dialnorm: -27dB
6: AC3, English, 2.0 channels, 192kbit/s, 48khz, dialnorm: -27dB
eac3to "F:\Rambo IV 2008 Blu-ray 1080p H.264 DTS-HD MA 7.1" 3)
M2TS, 2 video tracks, 3 audio tracks, 1:31:31
eac3to
