Old 8th September 2005, 14:11   #1  |  Link
dimzon
BeHappy/MeGUI developer
dimzon's Avatar
FAAC encoding plugin for BeSweet
WARNING!
This thread is obsolete! Use this thread.
Get it here!
Installation:
1) Install dimzon's BSN Framework first
2) Place provided bsn_FAAC.dll into BeSweet directory
3) Place faac.exe (command-line aac-encoder) into BeSweet directory
(tested with FAAC 1.24.1 (May 17 2005) UNSTABLE, included into package)
Usage: -bsn( -dll bsn_FAAC.dll [options] )
You can use *.aac, *.mp4, *.m4a or *.m4b as file extension,
 and the file format will be set automatically to ADTS or MP4.
Quality-related options:
  -q <quality>	Set default variable bitrate (VBR) quantizer quality in percent.
		(default: 100, averages at approx. 120 kbps VBR for a normal
		stereo input file with 16 bit and 44.1 kHz sample rate; max.
		value 500, min. 10).
  -b <bitrate>	Set average bitrate (ABR) to approximately <bitrate> kbps.
		(max. value 152 kbps/stereo with a 16 kHz cutoff, can be raised
		with a higher -c setting).
  -c <freq>	Set the bandwidth in Hz (default: automatic, i.e. adapts
		maximum value to input sample rate).
Expert options, only for testing purposes:
  --tns  	Enable coding of TNS, temporal noise shaping.
  --no-midside	Don't use mid/side coding.
  --mpeg-vers X	Force AAC MPEG version, X can be 2 or 4
  --obj-type X	AAC object type. (LC (Low Complexity, default), Main or LTP
		(Long Term Prediction)
  --shortctl X	Enforce block type (0 = both (default); 1 = no short; 2 = no
		long).
Other options
  -exe <file> Set encoder executable name. Defaut is FAAC.EXE.
  			  You can specify another FAAC build if you wish :)
Please, post your feedback here!
Enjoy!
dimzon is offline   Reply With Quote
Old 8th September 2005, 14:34   #2  |  Link
dimzon
dimzon's Avatar
Just very minor bugfix
Old 8th September 2005, 15:15   #3  |  Link
Kurtnoise
Swallowed in the Sea
Kurtnoise's Avatar
Good... but approval needed...If you want you can send it to me the file (kurtnoise at free dot fr) and I'll take it in my webpage.
Are you succeed to create something with libfaac.dll ? Too much complicate ? do you have already checked winLAME sources ? There are some codes with libfaac. Hope this helps...
Old 8th September 2005, 15:50   #4  |  Link
dimzon
dimzon's Avatar
Here are latest bsn_FAAC and beta bsn_Speex
Seems like pipelining is much more easy and common way to integrate external encoders into BeSweet. I spent 2 hour creating bsn_FAAC (there are many Win32 API code for pipelining) and i spend only 20 minutes to create bsn_Speex (based on bsn_FAAC pipeline code)
Maybe it's time to integrate with ffmpeg command-line encoder?
Old 8th September 2005, 16:04   #5  |  Link
dimzon
dimzon's Avatar
Does anybody need OptimFROG or other losless support ?
Old 8th September 2005, 17:48   #6  |  Link
Kurtnoise
Kurtnoise's Avatar
Ok...here is the link : http://kurtnoise.free.fr/BeSweet_Plugins/
I know it's much more easy with command line. So, no problem for me concerning lossless. Yes, I want them...
May I suggest you something ? Try to send a MP to DSPGuru to show him this thread. I think that he could create an new command line function, especially for you (just like -bswaplug( ) or anything else because -bsn() switch is dedicated to besweet nero encoder. And it will be more clearly for everybody to avoid some confusions by creating a new switch.
Old 8th September 2005, 17:58   #7  |  Link
dimzon
dimzon's Avatar
Wich lossless encoder did You prefer? I looked for OptimFROG and FLAC, both of them can obtain RAW PCM data from stdin.
It's good idea.
Don't forget, BSN framework still backward-compatible (if you do not specify -dll parameter it will redirect all calls to natve bsn.dll renamed to bsn_NeroAAC.dll)
Old 8th September 2005, 18:02   #8  |  Link
Kurtnoise
Kurtnoise's Avatar
Monkeys Audio and Wavpack I would like but I dunno if we have raw pcm data from stdin.
Old 8th September 2005, 18:24   #9  |  Link
dimzon
dimzon's Avatar
I will try to make Wavpack encoder plugin during this week
Old 8th September 2005, 21:14   #10  |  Link
DSPguru
BeSweet Author
DSPguru's Avatar
Ok...here is the link : I think that he could create an new command line function, especially for you.
yes, that wasn't hard. luckily, i had the time to do it.
In v1.5b31 you now have a -dimzon( -dllname .... ) switch.
DSPguru is offline   Reply With Quote
Old 9th September 2005, 09:12   #11  |  Link
FredThompson
FredThompson's Avatar
FWIW, supposedly, Monkey's Audio adds some extra junk at the end of the files. It's also closed source, unlike FLAC.
Reclusive fart.
Collecting Military, Trains, Cooking, Woodworking, Fighting Illini, Auburn Tigers
FredThompson is offline   Reply With Quote
Old 9th September 2005, 10:21   #12  |  Link
Kurtnoise
Kurtnoise's Avatar
not true...there is a SDK and some extras infos in developpers MAC forums.
Old 9th September 2005, 10:56   #13  |  Link
dimzon
dimzon's Avatar
Great!
check Your PM
Old 9th September 2005, 19:33   #14  |  Link
Elias
Be Brave!
Elias's Avatar
Wow! This is so great! No more need of using the Nero dlls. One question though: which is better suited for quality AAC encoding? Nero or FAAC?
Elias is offline   Reply With Quote
Old 12th September 2005, 11:07   #15  |  Link
dimzon
dimzon's Avatar
Originally Posted by Elias
Nero or FAAC?
Nero now OWN FAAC code so Nero has better quality for AAC-LC than FAAC
Old 12th September 2005, 12:11   #16  |  Link
Elias
Be Brave!
Elias's Avatar
What!? When did this happen?!
Old 12th September 2005, 20:32   #17  |  Link
movax
Member
Nero buys up the devs, and puts them to work as paid slaves Similar to the tale of FAAC source to Nero, the PsyTel guys were assimilated by Nero too.
movax is offline   Reply With Quote
Old 12th September 2005, 21:00   #18  |  Link
Elias
Be Brave!
Elias's Avatar
Micro$oft-style?
