Old 1st May 2019, 22:14   #6801  |  Link
~ VEGETA ~
The cult of personality
~ VEGETA ~'s Avatar
Originally Posted by sneaker_ger View Post
I thought you wanted to use libx265 from within ffmpeg. Ignore my last post.
Use:
ffmpeg -i "INPUT" -f yuv4mpegpipe -strict -1 -
Then make sure the log says it's "yuv420p10le".
I see:
video: wrapped_avframe, yuv420p10le in cmd so I guess this is ok.
what about my other question about better way to encode next time?
~ VEGETA ~ is offline   Reply With Quote
Old 1st May 2019, 22:36   #6802  |  Link
sneaker_ger
Originally Posted by ~ VEGETA ~ View Post
I encoded .vpy file to lossless 10-bit H.264 since my device is slow with the filters I used
Plus, next time when I want to encode like this (lossless 10-bit H.264 then 10-bit HEVC), should I encode to .yuv/.h264 in x264 (--muxer yuv\raw)? So I can input it directly to x265 without piping??
I don't understand the need for a temporary file at all in this case. Usually this is to speed up encoding when we do slow filtering + multiple passes of video encoding and time of
filtering + 1st pass + filtering + 2nd pass + .. > filtering + encode to lossless + 1st pass from lossless + 2nd pass from lossless ..
But you are encoding CRF, e.g. now instead of filtering + x265 crf you do filtering + x264 lossless + x265 crf. That's slower?
Old 1st May 2019, 22:46   #6803  |  Link
~ VEGETA ~
~ VEGETA ~'s Avatar
I have very low fps doing my filters, so I put everything to lossless x264 --preset ultrafast... then I can encode directly using x264 with slow settings in both 1080p and 720p. While If I want to encode in 1080 and 720 from vpy in both times I guess it will be slower since now I've gotta encode the filtering twice.
while if I wanna encode 720p only (from horriblesubs tv shows), then yes I go vpy directly without lossless.
what do you do for encoding BDs to 1080 and 720?
Old 1st May 2019, 23:18   #6804  |  Link
sneaker_ger
So you encode to multiple resolutions? Ok, then it may make sense to create an intermediate to only do (slow) filtering once.
I think you may save a little bit of time/CPU by saving to uncompressed y4m/yuv instead of encoding x264 lossless as intermediate. But with slow filtering + slow x265 it will probably not make too much of a difference either way. And the size of the file increases so the wear on the HDD/SSD increases. P.S.: ffmpeg allows multiple outputs but I don't know how it affects speed and it may result in HDD fragmentation.
I don't.
Old 1st May 2019, 23:28   #6805  |  Link
~ VEGETA ~
~ VEGETA ~'s Avatar
save to uncompressed video?? like using virtualdub2 to do that? not bad but I never tried it. I just hope it won't be more size than lossless h.264, at least not too much. plus, it has to be 10-bit.
I encode on a dedicated server so no problem about HDD xD, or so I think.
Old 1st May 2019, 23:35   #6806  |  Link
sneaker_ger
You don't need VirtualDub. vspipe can create y4m files. But yes, unsurprisingly, uncompressed files are bigger than compressed ones...
But again: if you are doing slow filtering and slow x265 encoding the difference between uncompressed or lossless x264 --preset ultrafast intermediate is probably not worth worrying about. If you want to know exactly you have to benchmark it.
Old 1st May 2019, 23:41   #6807  |  Link
~ VEGETA ~
~ VEGETA ~'s Avatar
I thought of doing this:
ffmpeg -i inputfile.vpy -c:v rawvideo outputfile.yuv
so you suggested vspipe, so maybe this:
vspipe script.vpy output.raw
or add --y4m
I will try next time to see how much time will it take. Lossless x264 ultrafast 1080p is about 8 hours.
Old 3rd May 2019, 15:11   #6808  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
If you really need a lossless mezzanine that doesn't require much computational cost, I think you're better off with UTVideo.
Alternatively, you can use other lossless codecs like FFV1, HuffYUV or Lagarith, although my suggestion is UTVideo or FFV1.
Broadcast Encoder
Avisynth memes: 1 - 2 - 3
Videotek - Audacity XP
Old 3rd May 2019, 15:56   #6809  |  Link
~ VEGETA ~
~ VEGETA ~'s Avatar
I tried make it .yuv raw from virtualdub2 using ffv1 lossless, it took the same time as x264-10bit lossless if not a bit more.
Also, now x265 inputs it directly but it encodes it WAY much slower for IDK reason. Also file size is so freaking huge, maybe I did something bad despite using the exact same encoding commands:
x265_64bit_10bit.exe --preset slower --crf 17 --ref 6 --rd 6 --psy-rd 1 --ctu 32 --aq-strength 0.8 --output-depth 10 --input-res 1920x1080 --fps 24000/1001 --input "C:\videp.yuv" --output "C:\output.hevc"
pause
Old 4th May 2019, 08:12   #6810  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
That's not surprising, considering that lossless codecs have limited algorithms to use in order to achieve a compression; as to the uncompressed .yuv file, well, uncompressed is uncompressed.
Oh... I didn't expect that- Apparently x264 lossless is more optimized or perhaps it's because you used VirtualDub rather than ffmpeg to encode it.
I didn't expect that. Encoding an uncompressed yuv source shouldn't take more than encoding an uncompressed A/V stream like the one Avisynth pipes to x265 nor encoding a lossless x264 source.
I mean, x265 is still gonna use its internal decoder to take the source in input, right?
Encoding-wise, I wonder whether its own internal decoder is more optimized for taking one thing in input rather than the other, or perhaps is just the way things have been allocated... but that cannot be since each source is lossless and there are little differences on filesize to justify a big speed different, besides compressed lossless, although with less space, still have to be "decoded", while uncompressed lossless files are ready to go but way bigger, so perhaps the hard drive is not fast enough to justify an uncompressed source as it takes longer to buffer it than decoding a losslessly compressed one... I don't know.
Perhaps someone can enlighten me as well about this.
Broadcast Encoder
Old 4th May 2019, 08:27   #6811  |  Link
Wolfberry
Helenium(Easter)
Wolfberry's Avatar
x265-3.0_Au+24-4217e691387c-win64-multilib
x265 [info]: HEVC encoder version 3.0_Au+24-4217e691387c
x265 [info]: build info [Windows][GCC 9.1.1][64 bit] 8bit+10bit+12bit
x265 [info]: (libavcodec  58.52.101)
x265 [info]: (libavformat 58.27.103)
x265 [info]: (libavutil   56.26.101)
x265 [info]: (lsmash       2.16.1)
Monochrome Anomaly
Wolfberry is offline   Reply With Quote
Old 4th May 2019, 09:56   #6812  |  Link
Leeloo Minaļ
FFV1 offers one of the most efficient compression rate, size-wise, but it is also slow as hell.
And if it is slower than others lossless codecs in compression, it is also slower in decompression !
I am not surprised that x265 encoded slower too, you should try UTVideo instead.
Leeloo Minaļ is offline   Reply With Quote
Old 13th May 2019, 06:29   #6813  |  Link
stax76
stax76's Avatar
The help output has one dash too much I think:
---hrd-concat            Set HRD concatenation flag for the first keyframe in the buffering period SEI. Default disabled
Old 13th May 2019, 19:37   #6814  |  Link
MeteorRain
結城有紀
Did you say you make .yuv raw using ffv1 lossless? So would that be an AVI file instead?
MeteorRain is offline   Reply With Quote
Old 15th May 2019, 23:59   #6815  |  Link
iAvoe
I wish the next x265 update or build can get rid of piping files in. Something like a straight file input as x264 builds (I'm not sure why it's not working through so many years tho)
iAvoe is offline   Reply With Quote
Old 16th May 2019, 00:21   #6816  |  Link
benwaggoner
No one is making a build with ffmpeg integrated is why.
Ben Waggoner
My Compression Book
Old 16th May 2019, 01:34   #6817  |  Link
qyot27
qyot27's Avatar
*cough*. We're still on the same forum page.
LAVF input is only supported through patches. MCW more or less put the kibosh on the idea of it being in the upstream source a few years ago, IIRC. Something about not wanting to deal with the maintenance burden of input modules other than raw and y4m, as I recall.
I mean, I use the LAVF support patches for my personal builds of x265 CLI, but more often than not, I just use libx265 through FFmpeg, which is probably more what MCW expects people to do if they want all the exotic input file support.
Old 16th May 2019, 01:49   #6818  |  Link
StvG
Last time I tested avs input with this patch was quite slower than avs2yuv+x265.
StvG is offline   Reply With Quote
Old 16th May 2019, 08:08   #6819  |  Link
Blue_MiSfit
Derek Prestegard IRL
Blue_MiSfit's Avatar
+1 for just using ffmpeg
The only downside AFAICT is when you want to use qpfiles, this still requires piping. I'm sure there are other things too, but this is a big one
Old 16th May 2019, 10:14   #6820  |  Link
stax76
stax76's Avatar
How do I use the patch?
x265.exe --crf 18 --output C:\out.hevc C:\test.avs
[avs2 @ 0000000002763500] Format avs2 detected only with low score of 1, misdetection possible!
[avs2 @ 0000000002763500] Could not find codec parameters for stream 0 (Video: avs2, none): unspecified size
Consider increasing the value for the 'analyzeduration' and 'probesize' options
[NULL @ 0000000002747480] No codec provided to avcodec_open2()
lavf [error]: could not find decoder for video stream
x265 [error]: unable to open input file <C:\Users\frank\Daten\Samples\test_temp\test.avs>
