Old 22nd June 2009, 12:55   #1  |  Link
MPAA
Poor and angry.
merging fraps files ?
fraps splits recorded files at 4gb.
what is the easiest/good way to merge these fraps files together to be able to view the footage as a continuous video ?
and i mean before shrinking them or whatever...
say i record about 5 minutes of hd footage and i end up with 5x4gb files. i then want to merge them together to create a 20gb file, and after this is done start shrinking it et al.
up until recently i only ever recorded reasonably short clips. usually less then 30 seconds, so they never exceeded 4gb. but i'm going to start recording longer clips and want/need to know.
ps: please hurry with the answer!!
§ Pimp of Mario's World. Hater of society. §
MPAA is offline   Reply With Quote
Old 22nd June 2009, 15:34   #2  |  Link
poisondeathray
try virtualdub in direct stream copy mode to append
Old 22nd June 2009, 15:46   #3  |  Link
Keiyakusha
契約者
Keiyakusha's Avatar
Or use avisynth. Then there is no need to "physically" append anything before shrinking them or whatever...
fraps
